Mechanics of composite materials : a unified micromechanical approach, 2013. ,
A Fully Asynchronous Multifrontal Solver Using Distributed Dynamic Scheduling, SIAM Journal on Matrix Analysis and Applications, vol.23, issue.1, pp.15-41, 2001. ,
DOI : 10.1137/S0895479899358194
URL : https://hal.archives-ouvertes.fr/hal-00808293
Realisation of gyrators using operational amplifiers, and their use in RC-active-network synthesis, Proceedings of the Institution of, pp.1838-1850, 1969. ,
DOI : 10.1049/piee.1969.0339
Passive damping of composite blades using embedded piezoelectric modules or shape memory alloy wires: a comparative study, Smart Materials and Structures, p.75027, 2012. ,
DOI : 10.1088/0964-1726/21/7/075027
Response-based tuning of a negative capacitance shunt for vibration control, Journal of Intelligent Material Systems and Structures, vol.5056, issue.12, pp.13-1585, 2014. ,
DOI : 10.1177/1045389X9800901204
Advances in piezoelectric finite element modeling of adaptive structural elements: a survey, Computers & Structures, vol.76, issue.1-3, pp.347-363, 2000. ,
DOI : 10.1016/S0045-7949(99)00151-0
Uniform fields and universal relations in piezoelectric composites, Journal of the Mechanics and Physics of Solids, vol.40, issue.6, pp.1295-1312, 1992. ,
DOI : 10.1016/0022-5096(92)90016-U
Improved resistive shunt by means of negative capacitance: new circuit, performances and multi-mode control, Smart Materials and Structures, vol.25, issue.7, p.75033, 2016. ,
DOI : 10.1088/0964-1726/25/7/075033
URL : https://hal.archives-ouvertes.fr/hal-01392666
An analytical and numerical approach for calculating effective material coefficients of piezoelectric fiber composites, International Journal of Solids and Structures, vol.42, issue.21-22, pp.5692-5714, 2005. ,
DOI : 10.1016/j.ijsolstr.2005.03.016
Homogénéisation en mécanique des matériaux, Matériaux aléatoires élastiques et milieux périodiques ,
Etude des effets de la friction en pied d'aube sur la dynamique des roues aubagées, 2006. ,
Optimal topology and experimental evaluation of piezoelectric materials for actively shunted general electric polymer matrix fiber composite blades ,
Modal Synthesis and Dynamical Condensation Methods for Accurate Piezoelectric Systems Impedance Computation, Journal of Intelligent Material Systems and Structures, vol.35, issue.4, 2008. ,
DOI : 10.1016/j.ijsolstr.2004.02.058
URL : https://hal.archives-ouvertes.fr/hal-00347775
Generic formalism for homogenization of coupled behavior: Application to magnetoelectroelastic behavior, Physical Review B, vol.78, issue.21, p.214110, 2008. ,
DOI : 10.1063/1.1367293
URL : https://hal.archives-ouvertes.fr/hal-00354428
Introduction à l'électrotechnique (introduction to electrotechnics ), 1989. ,
Turbomachine blade, in particular a fan blade, and its method of manufacture, p.112, 2007. ,
Simulation et expérimentation en mise en forme de renforts composites 3D interlocks, 2009. ,
Blade made of composite material comprising a damping device, US Patent, vol.8500, p.410, 2013. ,
Structures composites, Hermes Science Publication, 2000. ,
Numerical evaluation of the equivalent properties of Macro Fiber Composite (MFC) transducers using periodic homogenization, International Journal of Solids and Structures, vol.47, issue.24, pp.3272-3285, 2010. ,
DOI : 10.1016/j.ijsolstr.2010.08.006
Free-vibration analysis of laminated plates with embedded shear-mode piezoceramic layers, International Journal of Solids and Structures, vol.42, issue.7, pp.2059-2088, 2005. ,
DOI : 10.1016/j.ijsolstr.2004.09.003
Propriétés effectives de matériaux architecturés, 2012. ,
Développement et caractérisations de fibres piezoélectriques à âme métallique pour applications aéronautiques, 2013. ,
Modélisation et optimisation de dispositifs non-linéaires d'amortissement de structures par systémes piézoélectriques commutés, 2009. ,
Optimisation de dispositif passif d'atténuation de vibration par shunt piézoélectrique, Actes du 8ème colloque national en calcul de structures, pp.519-524, 2007. ,
Micromechanics predictions of the effective electroelastic moduli of piezoelectric composites, International Journal of Solids and Structures, vol.30, issue.2, pp.161-175, 1993. ,
DOI : 10.1016/0020-7683(93)90058-F
Modélisation du comportement élastique endommageable de matériaux composites à renfort tridimensionnel, 2006. ,
Piezoelectric ceramics properties & applications. Tutorial , Morgan Electroceramics?Philips components, 2009. ,
The Determination of the Elastic Field of an Ellipsoidal Inclusion, and Related Problems, Proceedings of the Royal Society A: Mathematical, Physical and Engineering Sciences, vol.241, issue.1226, pp.376-396, 1957. ,
DOI : 10.1098/rspa.1957.0133
Electronic damping of vibrations in optical structures, Applied Optics, vol.18, issue.5, pp.690-697, 1979. ,
DOI : 10.1364/AO.18.000690
On the electromechanical response of active composite materials with piezoelectric inclusions, Computers & Structures, vol.65, issue.2, pp.157-168, 1997. ,
DOI : 10.1016/S0045-7949(96)00375-6
Gmsh: A 3-D finite element mesh generator with built-in pre- and post-processing facilities, International Journal for Numerical Methods in Engineering, vol.69, issue.4, pp.11-1309, 2009. ,
DOI : 10.1007/978-3-642-59223-2
Composite turbomachine blade with metal reinforcement, US Patent, vol.8137, p.73, 1920. ,
Dynamique non-linéaire d'une roue de turbine Basse Pression soumise à des excitations structurales d'un turboréacteur, 2012. ,
Sound Wave Transmission Reduction through a Plate using Piezoelectric Synchronized Switch Damping Technique, Journal of Intelligent Material Systems and Structures, vol.3672, issue.6, 2007. ,
DOI : 10.1088/0964-1726/15/6/045
Damping of structural vibrations with piezoelectric materials and passive electrical networks, Journal of Sound and Vibration, vol.146, issue.2, pp.243-268, 1991. ,
DOI : 10.1016/0022-460X(91)90762-9
Determination of the size of the representative volume element for random composites: statistical and numerical approach, International Journal of Solids and Structures, vol.40, issue.13-14, pp.13-3647, 2003. ,
DOI : 10.1016/S0020-7683(03)00143-4
Damping device for composite blade, US Patent, vol.8, p.61997, 2011. ,
Numerical and experimental optimized shunted piezoelectric circuit for turbomachinery blades, 12th IFToMM World Congress, 2007. ,
Structural multi-modal damping by optimizing shunted piezoelectric transducers, Revue europ??enne de m??canique num??rique, vol.20, issue.1-4, pp.1-4, 2011. ,
DOI : 10.3166/ejcm.20.73-102
Multimodal coupling of periodic lattices and application to rod vibration damping with a piezoelectric network, Smart Materials and Structures, vol.24, issue.4, p.45018, 2015. ,
DOI : 10.1088/0964-1726/24/4/045018
Robustness of a multimodal piezoelectric damping involving the electrical analogue of a plate, SPIE Smart Structures and Materials+ Nondestructive Evaluation and Health Monitoring International Society for Optics and Photonics, pp.97992-97992, 2016. ,
Wave propagation in coupled periodic lattices and application to vibration attenuation through a piezoelectric network, ISMA2014 International Conference on Noise and Vibration Engineering, 2014. ,
Comparison of passive inductor designs for piezoelectric shunt damping, SPIE Smart Structures and Materials+ Nondestructive Evaluation and Health Monitoring International Society for Optics and Photonics, pp.97991-97991, 2016. ,
Integrity of graphite/epoxy laminate embedded with piezoelectric sensor/actuator under monotonic and fatigue loads*, Smart Materials and Structures, vol.11, issue.4, p.527, 2002. ,
DOI : 10.1088/0964-1726/11/4/307
Electromechanical fatigue behavior of graphite/epoxy laminate embedded with piezoelectric actuator, Smart Materials and Structures, vol.9, issue.1, p.78, 2000. ,
DOI : 10.1088/0964-1726/9/1/308
Fatigue of metals subjected to varying stress, pp.37-40, 1968. ,
Vibration damping of turbomachinery components with piezoelectric transducers : Theory and experiment, ISMA2012 International Conference on Noise and Vibration Engineering, 2012. ,
Synchronized switch damping on inductor and negative capacitance, Journal of Intelligent Material Systems and Structures, vol.3989, issue.4, pp.1045389-11433493, 2012. ,
DOI : 10.1088/0964-1726/17/3/035003
Modélisation du frottement en pied d'aube par une approche fréquentielle, 2002. ,
Connectivity and piezoelectric-pyroelectric composites, Materials Research Bulletin, vol.13, issue.5, pp.525-536, 1978. ,
DOI : 10.1016/0025-5408(78)90161-7
Reliability investigation of piezoelectric macro fiber composite (mfc) actuators, Adaptronic Congress, 2007. ,
Atténuation du bruit et des vibrations de structures minces par dispositifs piézoélectriques passifs : modèles numériques d'ordre réduit et optimisation, 2014. ,
Comparison of finite element formulations for the dynamic analysis of elastic structures with piezoelectric patches, 6th ECCOMAS Thematic Conference on Smart Structures and Materials, 2013. ,
Experimental assessment and further development of amplified piezo actuators for active flap devices. ONERA- PUBLICATIONS-TP, p.154, 2002. ,
Effective properties of composites with embedded piezoelectric fibres, Computational Materials Science, vol.16, issue.1-4, pp.89-97, 1999. ,
DOI : 10.1016/S0927-0256(99)00050-6
Identification of electromechanical modal parameters of linear piezoelectric structures, Smart Materials and Structures, vol.16, issue.2, p.323, 2007. ,
DOI : 10.1088/0964-1726/16/2/010
Vibration control of active structures : an introduction, 2011. ,
Method of fabricating a test blade of composite material, US Patent, vol.7850, p.892, 2010. ,
Fatigue performance of macro-fiber piezoelectric composite actuator with respect to variable beam geometry, 2012. ,
Modélisation vibro-acoustique de structures sandwich munies de matériaux visco-élastiques, Conservatoire national des arts et métiers, 2013. ,
Interface finite elements for parametric study of structures with thin constrained layer damping, 2nd ECCOMAS Young Investigators Conference, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00855920
A COMPONENT MODE SYNTHESIS APPROACH FOR DYNAMIC ANALYSIS OF VISCOELASTICALLY DAMPED STRUCTURES, Proceedings of 10th World Congress on Computational Mechanics, p.231, 2012. ,
DOI : 10.5151/meceng-wccm2012-18496
Réduction de vibrations de structure complexe par shunts piézoélectriques : Application aux turbomachines, Conservatoire national des arts et métiers, 2011. ,
Optimization of Shunted Piezoelectric Patches for Vibration Reduction of Complex Structures: Application to a Turbojet Fan Blade, Volume 5: 22nd International Conference on Design Theory and Methodology; Special Conference on Mechanical Vibration and Noise, 2010. ,
DOI : 10.1115/DETC2010-28737
Atténuation des vibrations de structures complexes par shunt piézoélectrique application à un modèle simplifié d'aube de turbomachine, Neuvième colloque national en calcul des structures, 2009. ,
Piezoelectricity in polyvinylidenefluoride, The Journal of the Acoustical Society of America, vol.70, issue.6, pp.1596-1608, 1981. ,
DOI : 10.1121/1.387225
Modeling 1-3 composite piezoelectrics: thickness-mode oscillations, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, vol.38, issue.1, pp.40-47, 1991. ,
DOI : 10.1109/58.67833
Vibration and Shock in Damped Mechanical Systems, Journal of Applied Mechanics, vol.36, issue.2, 0200. ,
DOI : 10.1115/1.3564684
[78] Suquet, P. Local and global aspects in the mathematical theory of plasticity. Plasticity today : modelling, methods and applications, pp.176-1987, 1985. ,
Dynamique linéaire et non linéaire de structures élastiques et piézoélectriques . instruments de musique, micro/nano systèmes électromécaniques, 2011. ,
Vibrations of an elastic structure with shunted piezoelectric patches: efficient finite element formulation and electromechanical coupling coefficients, International Journal for Numerical Methods in Engineering, vol.265, issue.5, pp.235-268, 2009. ,
DOI : 10.1007/978-1-4899-6453-3
URL : https://hal.archives-ouvertes.fr/hal-01572491
Performance of piezoelectric shunts for vibration reduction, Smart Materials and Structures, vol.21, issue.1, p.15008, 2012. ,
DOI : 10.1088/0964-1726/21/1/015008
URL : https://hal.archives-ouvertes.fr/hal-01082925
Asymmetric non-linear forced vibrations of free-edge circular plates. Part II: experiments, Journal of Sound and Vibration, vol.265, issue.5, pp.1075-1101, 2003. ,
DOI : 10.1016/S0022-460X(02)01564-X
URL : https://hal.archives-ouvertes.fr/hal-00830696
The effect of stress ratio during crack propagation and fatigue for 2024- t3 and 7075-t6 aluminum. In Effects of environment and complex load history on fatigue life, 1970. ,
Reliability testing of nasa piezocomposite actuators, 2002. ,
Etude de l'amortissement piézoélectrique shunté appliqué aux roues aubagées désaccordées, 2012. ,
An adaptive control strategy based on passive piezoelectric shunt techniques applied to mistuned bladed disks, Journal of Computational and Applied Mathematics, vol.246, pp.289-300, 2013. ,
DOI : 10.1016/j.cam.2012.06.023
On the problem of improvement of the damping ability of rotor blades of contemporary gas-turbine engines, Strength of materials, pp.368-375, 2003. ,
