Beyond standard models in cosmology
Au-delà des modèles standards en cosmologie
The current description of fundamental interactions is based on two theories with the status of standard models. The electromagnetic and nuclear interactions are described at a quantum level by the Standard Model of particle physics, using tools like gauge theories and spontaneous symmetry breaking by the Higgs mechanism. The gravitational interaction is described on the other hand by general relativity, based on a dynamical description of space-time at a classical level.Although these models are verified to high precision in the solar system experiments, they suffer from several theoretical weaknesses and a lack of predictive power at the Planck scale as well as at cosmological scales; they are thus not viewed anymore as fundamental theories. As its phenomenology involves both these extreme scales, cosmology is then a good laboratory to probe theories going beyond these standard models.The first part of this thesis focus on cosmic strings, topological defects forming during the spontaneous symmetry breaking of grand unified theories in the early universe. I show especially how to study these defects while taking into account the complete structure of the particles physics models leading to their formation, going beyond the standard descriptions in terms of simplified toy-models. The second part is devoted to the construction and the examination of different theories of modified gravity related to the Galileon model, a model which tries in particular to explain the dark energy phenomenology.
La description actuelle des interactions fondamentales repose sur deux théories ayant le statut de modèle standard. Les interactions électromagnétiques et nucléaires sont décrites à un niveau quantique par le Modèle Standard de la physique des particules, alliant théories de jauge et brisures spontanées de symétrie par le mécanisme de Higgs. À l'opposé, l'interaction gravitationnelle est décrite par la relativité générale,basée sur une description dynamique de l'espace-temps dans un cadre classique.Bien que ces deux modèles soient vérifiés avec une grande précision dansle système solaire, ils sont affligés d’un certain nombre de problèmes théoriques et manquent de force prédictive aussi bien à l'échelle de Planck qu’à l'échelle cosmologique ;ils ne sont par conséquent plus perçus comme fondamentaux. La cosmologie, dont la phénoménologie fait apparaitre ces deux échelles extrêmes, apparaît alors comme un laboratoire privilégié pour tester les théories au delà de ces modèles standards.La première partie de cette thèse concerne l'étude des cordes cosmiques, défauts topologiques se formant lors de la brisure spontanée de théories de grande unification dans l'univers primordial.J’y montre notamment comment étudier ces défauts en prenant en compte la structure complète des théories de physique des particules dont ils sont issus, ce qui représente une avancée importante par rapport à la description courante en termes de modèles ”jouets”très simplifiés. La deuxième partie de cette thèse consiste en la construction et l'étude de différentes théories de gravité modifiée liées au modèle de Galiléon, un modèle tentant notamment d'expliquer la phénoménologie liée à l'énergie noire.
