Taking advantage of correlation in stochastic computing, 2017 IEEE International Symposium on Circuits and Systems (ISCAS), pp.1-4, 2017. ,
DOI : 10.1109/ISCAS.2017.8050807
Pushing the limits of voltage over-scaling for error-resilient applications, Design, Automation & Test in Europe Conference & Exhibition (DATE), 2017, pp.476-481, 2017. ,
DOI : 10.23919/DATE.2017.7927036
URL : https://hal.archives-ouvertes.fr/hal-01417665
Low complexity on-chip distributed DC-DC converter for low power WSN nodes, 2015 IEEE 13th International New Circuits and Systems Conference (NEWCAS), pp.1-4, 2015. ,
DOI : 10.1109/NEWCAS.2015.7182118
URL : https://hal.archives-ouvertes.fr/hal-01196987
Adaptive Overclocking and Error Correction Based on Dynamic Speculation Window, 2016 IEEE Computer Society Annual Symposium on VLSI (ISVLSI), pp.325-330, 2016. ,
DOI : 10.1109/ISVLSI.2016.13
URL : https://hal.archives-ouvertes.fr/hal-01416945
The efficiency can be further improved to 82% with BER of 20% at V dd = ,
Variable supply-voltage scheme for low-power high-speed CMOS digital design, IEEE Journal of Solid-State Circuits, vol.33, issue.3, pp.454-462, 1998. ,
DOI : 10.1109/4.661211
URL : http://www.ece.ncsu.edu/asic/ece733/papers/LowPower/DualSupply98.pdf
Dynamic voltage and frequency scaling: The laws of diminishing returns, Proc. of the 2010 Intl. Conf. on Power Aware Computing and Systems, pp.1-8, 2010. ,
Variation and Reliability in FPGAs, IEEE Design & Test, vol.30, issue.6, pp.50-59, 2013. ,
DOI : 10.1109/MDAT.2013.2266652
Double-Sampling Design Paradigm—A Compendium of Architectures, IEEE Transactions on Device and Materials Reliability, vol.15, issue.1, pp.10-23, 2015. ,
DOI : 10.1109/TDMR.2014.2388358
Timing Fault Detection in FPGA-Based Circuits, 2014 IEEE 22nd Annual International Symposium on Field-Programmable Custom Computing Machines, pp.96-99 ,
DOI : 10.1109/FCCM.2014.32
Safe Overclocking of Tightly Coupled CGRAs and Processor Arrays using Razor, 2013 IEEE 21st Annual International Symposium on Field-Programmable Custom Computing Machines, pp.37-44, 2013. ,
DOI : 10.1109/FCCM.2013.63
URL : http://www.ece.ubc.ca/~lemieux/publications/brant-fccm2013.pdf
Online measurement of timing in circuits: For health monitoring and dynamic voltage & frequency scaling, IEEE 20th Annual International Symposium on Field-Programmable Custom Computing Machines (FCCM), pp.109-116, 2012. ,
Embedded computing: a VLIW approach to architecture, compilers and tools, 2005. ,
Cramming more components onto integrated circuits, Electronics, vol.38, issue.8, pp.114-117, 1965. ,
Why is CMOS scaling coming to an end? In International Design and Test Workshop, pp.98-103, 2008. ,
Sources of variation In Variation Aware Adaptive Voltage Scaling For Digital CMOS Circuits, Springer series in advanced microelectronics, 2013. ,
Low power design In Power optimization and synthesis at behavioral and system levels using formal methods, chapter 1, 2012. ,
DOI : 10.1007/978-1-4615-5199-7
Handling inverted temperature dependence in static timing analysis, ACM Transactions on Design Automation of Electronic Systems, vol.11, issue.2, pp.306-324, 2006. ,
DOI : 10.1145/1142155.1142158
URL : http://ziyang.eecs.umich.edu/~dickrp/talp/papers/dasdan-temperature.pdf
Dynamic voltage frequency scaling (DVFS) for microprocessors power and energy reduction, International Conference on Electrical and Electronics Engineering, 2005. ,
A fine-grain variation-aware dynamic vdd-hopping AVFS architecture on a 32 nm GALS MPSoC, IEEE Journal of Solid-State Circuits, vol.49, issue.7, pp.1475-1486, 2014. ,
A 460MHz at 397mV, 2.6 GHz at 1.3 V, 32b VLIW DSP, embedding fmax tracking, IEEE Intl. Solid-State Circuits Conf. Digest of Technical Papers (ISSCC), pp.452-453, 2014. ,
DOI : 10.1109/isscc.2014.6757509
Ivan Miro-Panades, and Edith Beignè. 193 MOPS/mW@ 162 MOPS, 0.32 V to 1.15 V voltage range multi-core accelerator for energy efficient parallel and sequential digital processing, IEEE Symposium in Low-Power and High-Speed Chips (COOL CHIPS XIX), pp.1-3 ,
Near-threshold computing: Reclaiming moore's law through energy efficient integrated circuits, Proceedings of the IEEE, pp.253-266, 2010. ,
Can subthreshold and near-threshold circuits go mainstream?, IEEE Micro, vol.30, issue.4, pp.80-85, 2010. ,
VARIUS-NTV: A microarchitectural model to capture the increased sensitivity of manycores to process variations at near-threshold voltages, IEEE/IFIP International Conference on Dependable Systems and Networks (DSN), pp.1-11, 2012. ,
Energy Efficient Design for Subthreshold Supply Voltage Operation, 2006 IEEE International Symposium on Circuits and Systems, p.4, 2006. ,
DOI : 10.1109/ISCAS.2006.1692514
Extremely thin SOI (ETSOI) CMOS with record low variability for low power system-on-chip applications, 2009 IEEE International Electron Devices Meeting (IEDM), pp.1-4, 2009. ,
DOI : 10.1109/IEDM.2009.5424422
A simple and efficient concept for setting up multi-VT devices in thin BOX fullydepleted SOI technology, Proceedings of the European Solid State Device Research Conference (ESSDERC), pp.137-140, 2009. ,
Ultra-Wide Voltage Range Designs in Fully-Depleted Silicon-On-Insulator FETs, Design, Automation & Test in Europe Conference & Exhibition (DATE), 2013, pp.613-618, 2013. ,
DOI : 10.7873/DATE.2013.135
Fine grain multi-VT co-integration methodology in UTBB FD-SOI technology, IFIP/IEEE 21st International Conference on Very Large Scale Integration (VLSI-SoC), pp.168-173, 2013. ,
DOI : 10.1109/vlsi-soc.2013.6673270
Power management through DVFS and dynamic body biasing in FD-SOI circuits, Proceedings of the 51st Annual Design Automation Conference, pp.1-6, 2014. ,
DOI : 10.1109/dac.2014.6881510
URL : https://hal.archives-ouvertes.fr/lirmm-01421009
FD-SOI offers alternative to FINFET, 2016. ,
Exploring back biasing opportunities in 28nm UTBB FD-SOI technology for subthreshold digital design, 2014 IEEE 28th Convention of Electrical & Electronics Engineers in Israel (IEEEI) ,
DOI : 10.1109/EEEI.2014.7005822
Variability Mitigation in Nanometer CMOS Integrated Systems: A Survey of Techniques From Circuits to Software, Proceedings of the IEEE, pp.1410-1448, 2016. ,
DOI : 10.1109/JPROC.2016.2518864
Standby power reduction using dynamic voltage scaling and canary flip-flop structures, IEEE Journal of Solid-State Circuits Bibliography, vol.39, issue.158, pp.1504-1511, 2004. ,
Razor: circuit-level correction of timing errors for low-power operation, IEEE Micro, vol.24, issue.6, 2004. ,
DOI : 10.1109/MM.2004.85
Possibilities to miss predicting timing errors in canary flip-flops, 2011 IEEE 54th International Midwest Symposium on Circuits and Systems (MWSCAS), pp.1-4, 2011. ,
DOI : 10.1109/MWSCAS.2011.6026656
RazorII: In Situ Error Detection and Correction for PVT and SER Tolerance, IEEE Journal of Solid-State Circuits, vol.44, issue.1, pp.32-48, 2009. ,
DOI : 10.1109/JSSC.2008.2007145
Bubble Razor: Eliminating Timing Margins in an ARM Cortex-M3 Processor in 45 nm CMOS Using Architecturally Independent Error Detection and Correction, IEEE Journal of Solid-State Circuits, vol.48, issue.1, pp.66-81, 2013. ,
DOI : 10.1109/JSSC.2012.2220912
GRAAL: a new fault tolerant design paradigm for mitigating the flaws of deep nanometric technologies, 2007 IEEE International Test Conference, pp.1-10, 2007. ,
DOI : 10.1109/TEST.2007.4437666
URL : https://hal.archives-ouvertes.fr/hal-00226406
Soft Errors in Advanced Computer Systems, IEEE Design and Test of Computers, vol.22, issue.3, pp.258-266, 2005. ,
DOI : 10.1109/MDT.2005.69
Using Run-Time Reconfiguration to Implement Fault-Tolerant Coarse Grained Reconfigurable Architectures, 2012 IEEE 26th International Parallel and Distributed Processing Symposium Workshops & PhD Forum, pp.320-327, 2012. ,
DOI : 10.1109/IPDPSW.2012.39
Low-Cost TMR for Fault-Tolerance on Coarse-Grained Reconfigurable Architectures, 2011 International Conference on Reconfigurable Computing and FPGAs, pp.135-140, 2011. ,
DOI : 10.1109/ReConFig.2011.57
Timing error handling on CGRAs, 2013 International Conference on Reconfigurable Computing and FPGAs (ReConFig), pp.1-6 ,
DOI : 10.1109/ReConFig.2013.6732333
A design diversity metric and analysis of redundant systems, IEEE Transactions on Computers, vol.51, issue.5, pp.498-510, 2002. ,
DOI : 10.1109/TC.2002.1004589
Diverse Double Modular Redundancy: A New Direction for Soft-Error Detection and Correction, IEEE Design & Test, vol.30, issue.2, pp.87-95, 2013. ,
DOI : 10.1109/MDT.2012.2232964
Structural DMR: A Technique for Implementation of Soft-Error-Tolerant FIR Filters, IEEE Transactions on Circuits and Systems II: Express Briefs, vol.58, issue.8, pp.58512-516, 2011. ,
DOI : 10.1109/TCSII.2011.2158750
Inexact computing for ultra low-power nanometer digital circuit design, IEEE/ACM International Symposium on Nanoscale Architectures, pp.24-31, 2011. ,
An Approximate Computing Technique for Reducing the Complexity of a Direct-Solver for Sparse Linear Systems in Real-Time Video Processing, Proceedings of the The 51st Annual Design Automation Conference on Design Automation Conference, DAC '14, pp.1-6, 2014. ,
DOI : 10.1145/2593069.2593082
Approximate computing: An emerging paradigm for energy-efficient design, 2013 18TH IEEE EUROPEAN TEST SYMPOSIUM (ETS), pp.1-6, 2013. ,
DOI : 10.1109/ETS.2013.6569370
Lazy Pipelines: Enhancing Quality in Approximate Computing, Proceedings of the 2016 Design, Automation & Test in Europe Conference & Exhibition (DATE), pp.1381-1386, 2016. ,
DOI : 10.3850/9783981537079_0673
Axilog: Language Support for Approximate Hardware Design, Design, Automation & Test in Europe Conference & Exhibition (DATE), 2015, pp.812-817, 2015. ,
DOI : 10.7873/DATE.2015.0513
Time redundancy based soft-error tolerance to rescue nanometer technologies, Proceedings 17th IEEE VLSI Test Symposium (Cat. No.PR00146), pp.86-94, 1999. ,
DOI : 10.1109/VTEST.1999.766651
URL : https://hal.archives-ouvertes.fr/hal-00013764
Self-measurement of combinatorial circuit delays in FPGAs, ACM Trans. on Reconfigurable Technology and Systems (TRETS), vol.2, issue.2, p.10, 2009. ,
Characterisation of FPGA Clock Variability, 2008 IEEE Computer Society Annual Symposium on VLSI, pp.322-328, 2008. ,
DOI : 10.1109/ISVLSI.2008.48
URL : http://cas.ee.ic.ac.uk/people/nps/papers/sedcole08isvlsi.pdf
VC707 Evaluation Board for the Virtex-7 FPGA User Guide, v1, 2015. ,
Robustness of timing in-situ monitors for AVS management, 2016 IEEE International Reliability Physics Symposium (IRPS), p.4, 2016. ,
DOI : 10.1109/IRPS.2016.7574593
URL : https://hal.archives-ouvertes.fr/hal-01474794
In-situ slack monitors: taking up the challenge of on-die monitoring of variability and reliability, 2016 1st IEEE International Verification and Security Workshop (IVSW), pp.1-5, 2016. ,
DOI : 10.1109/IVSW.2016.7566606
URL : https://hal.archives-ouvertes.fr/hal-01474807
Near-threshold computing for very wide frequency scaling: Approximate adders to rescue performance, 2015 IEEE 13th International New Circuits and Systems Conference (NEWCAS), pp.1-4, 2015. ,
DOI : 10.1109/NEWCAS.2015.7182030
Designing approximate circuits using clock overgating, Proceedings of the 53rd Annual Design Automation Conference on, DAC '16, p.15, 2016. ,
DOI : 10.1145/2744769.2744863
URL : http://dl.acm.org/ft_gateway.cfm?id=2898005&type=pdf
Decoupled Control and Data Processing for Approximate Near-Threshold Voltage Computing, IEEE Micro, vol.35, issue.4, pp.70-78, 2015. ,
DOI : 10.1109/MM.2015.85
Joint precision optimization and high level synthesis for approximate computing, Proceedings of the 52nd Annual Design Automation Conference on, DAC '15, p.104, 2015. ,
DOI : 10.1109/TCAD.2006.873887
Energy parsimonious circuit design through probabilistic pruning, 2011 Design, Automation & Test in Europe, pp.1-6 ,
DOI : 10.1109/DATE.2011.5763130
Near/Sub-Threshold Circuits and Approximate Computing: The Perfect Combination for Ultra-Low-Power Systems, 2015 IEEE Computer Society Annual Symposium on VLSI ,
DOI : 10.1109/ISVLSI.2015.41
URL : https://infoscience.epfl.ch/record/213495/files/ISVLSI_paper.pdf
Designing Energy-Efficient Arithmetic Operators Using Inexact Computing, Journal of Low Power Electronics, vol.9, issue.1, pp.141-153, 2013. ,
DOI : 10.1166/jolpe.2013.1249
CMOS VLSI Design: A Circuits And Systems Perspective, 2006. ,
Accuracy-configurable adder for approximate arithmetic designs, Proc. of the Annual Design Automation Conference, pp.820-825, 2012. ,
?-VEX: A reconfigurable and extensible softcore VLIW processor, International Conference on Electrical and Computer Engineering (ICECE), pp.369-372, 2008. ,
DOI : 10.1109/fpt.2008.4762420
Support for Dynamic Issue Width in VLIW Processors Using Generic Binaries, Design, Automation & Test in Europe Conference & Exhibition (DATE), 2013, pp.827-832, 2013. ,
DOI : 10.7873/DATE.2013.175
Application processor description, 2016. ,
?-VEX: A reconfigurable and extensible softcore VLIW processor, 2008. ,
VEX toolchain, HP, 2011. ,
Instruction level power model of microcontrollers, ISCAS'99. Proceedings of the 1999 IEEE International Symposium on Circuits and Systems VLSI (Cat. No.99CH36349), pp.76-79, 1999. ,
DOI : 10.1109/ISCAS.1999.777809
URL : http://www.cc.gatech.edu/systems/architecture/adibrh/papers/instruction-level-power-model.pdf
Instruction level power analysis and optimization of software, Technologies for Wireless Computing, pp.139-154, 1996. ,
DOI : 10.1109/icvd.1996.489624
Instruction level power profiling, 1996 IEEE International Conference on Acoustics, Speech, and Signal Processing Conference Proceedings, pp.3326-3329, 1996. ,
DOI : 10.1109/ICASSP.1996.550589
Power estimation and optimization methodologies for VLIW-based embedded systems, 2007. ,
A power modeling and estimation framework for vliw-based embedded systems, Proc. Intl. Workshop on Power And Timing Modeling, Optimization and Simulation PATMOS, pp.2-3, 2001. ,
Power-aware microarchitecture: Design and modeling challenges for next-generation microprocessors, IEEE Micro, vol.20, issue.6, pp.26-44, 2000. ,
Rapid and accurate energy estimation of vector processing in VLIW ASIPs, 2013 2nd Mediterranean Conference on Embedded Computing (MECO), pp.33-37, 2013. ,
DOI : 10.1109/MECO.2013.6601350
An Accurate Energy Estimation Framework for VLIW Processor Cores, 2006 International Conference on Computer Design, pp.464-469, 2007. ,
DOI : 10.1109/ICCD.2006.4380857
URL : http://www.cecs.uci.edu/%7Epapers/iccd2006/papers/paper_71.pdf
Energy estimation and optimization of embedded VLIW processors based on instruction clustering, Proceedings of the annual Design Automation Conference, pp.886-891, 2002. ,
Limits of gate-level power estimation considering real delay effects and glitches, 2014 International Symposium on System-on-Chip (SoC), pp.1-7, 2014. ,
DOI : 10.1109/ISSOC.2014.6972437
