Combined theoretical and experimental study of the ionic conduction in oxide-carbonate composite materials as electrolytes for solid oxide fuel cells (SOFC) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Etude combinée théorique et expérimentale de la conduction ionique dans les matériaux composite oxyde-carbonate comme électrolyte pour les piles à combustible à oxyde solide (SOFC)
Oxide-carbonate composites are promising electrolytes for LT-SOFC, thanks to their high conductivity (0.1-1 S/cm at 600°C). A deeper understanding on the origins of their improved performances is still necessary. For this purpose, a combined theoretical and experimental approach was developed. We first studied systematically the conductivity of the material, measured through EIS, as a function of different oxide or carbonate phases and of the operating atmosphere. Results on YSZ- and CeO2-based materials indicate that by only taking into account the interfaces it is possible to rationalize some surprising observations, while reactivity issues have been observed for TiO2-carbonate composites. We then proposed a computational strategy based on periodic DFT calculations: we first studied the bulk structure of each phase so as to select an adequate computational protocol, which has then been used to identify a suitable model of the most stable surface for each phase. These surface models have thus been combined to obtain a model of the oxide-carbonate interface that through static DFT and MD provides a deeper insight on the interface at the atomic level. This strategy was applied to provide information on the structure, stability and electronic properties of the interface. YSZ-LiKCO3 was used as a case study to investigate the conduction mechanisms of different species. Results showed a strong influence of the interfaces on the transport properties. The TiO2-LiKCO3 model was, instead, used to investigate the reactivity of these materials. Overall, these results pave the way toward a deeper understanding of the basic operating principles of SOFC based on these materials.
Les composites oxyde-carbonate pourraient constituer des électrolytes pour les SOFC fonctionnant entre 400-600°C car ils attendent une conductivité de 0,1 S/cm à 600°C. Une meilleure compréhension de l'origine de leurs performances est à ce jour nécessaire. Pour y parvenir, une approche combinée théorique et expérimentale a été développée. La conductivité, mesurée à travers la SIE, a été étudiée en fonction de la phase oxyde ou carbonate et de l'atmosphère de travail. Les résultats sur les composite de CeO2 ou YSZ ont montré que seule l'interface peut expliquer des observations surprenantes. De la réactivité a été observée dans le cas des composites à base de TiO2. On a donc proposé une stratégie computationnelle qui utilise des calculs DFT périodiques: la structure du bulk de chaque phase a d'abord été étudiée afin de trouver un bon protocole computationnel, qui a été ensuite utilisé pour identifier un modèle pour la surface la plus stable des deux phases. Ces modèles de surfaces ont donc été combinés pour obtenir un modèle de l'interface oxyde-carbonate, utilisable comme structure de départ pour des calculs DFT et de DM. Cette stratégie a permis d'obtenir des informations sur structure, stabilité et propriétés électroniques des composites. YSZ-LiKCO3 a été utilisé pour mieux comprendre l'effet des interfaces sur le transport de différentes espèces, tandis que le modèle de l'interface entre TiO2 et LiKCO3 a été utilisé pour étudier la réactivité entre ces deux matériaux. Finalement, ces résultats ouvrent la voie vers une plus grande compréhension des principes de fonctionnement des SOFC basées sur les électrolytes composites oxyde-carbonate.
2016PA066623.pdf (29.31 Mo) Télécharger le fichier
tel-01638202 , version 1 (20-11-2017)
  • HAL Id : tel-01638202 , version 1
Chiara Ricca. Combined theoretical and experimental study of the ionic conduction in oxide-carbonate composite materials as electrolytes for solid oxide fuel cells (SOFC). Chemical Physics [physics.chem-ph]. Université Pierre et Marie Curie - Paris VI, 2016. English. ⟨NNT : 2016PA066623⟩. ⟨tel-01638202⟩
348 Consultations
129 Téléchargements
