Abstract : Code modularity is important for code reuse. Language designers mainly focused on method code modularity. On the
contrary, initialization code modularity has usually been neglected. The initialization code of many class-based object-oriented
languages becomes cumbersome in different situations: for example, when some fields have multiple initialization
options (e.g., a rectangle can be positioned by providing Cartesian or polar coordinates), have optional initialization (e.g., a
rectangle can be positioned in the origin (0,0) if no other coordinates are provided), or have superclass initialization (e.g., a
colored rectangle must redefine all the constructors of its rectangle superclass to add the notion of color). In such cases, the
number of constructors increases exponentially in the size of the initialization options, since the initialization approach lacks
modularity.
We propose a novel approach to field initialization, inspired by the prototypical language Magda. This approach is based on
easy-to-compose initialization modules, which result to be smaller compared to classical constructors. Moreover, their
number grows linearly in the size of the initialization options. We apply such approach to Pharo, a dynamically-typed object-oriented
programming language inspired by Smalltalk. The adaptation to Pharo of Magda’s initialization approach implies
solving some new challenges related to moving from a statically typed context to a dynamically typed one.
Résumé : La modularité du code favorise la réutilisation. Les concepteurs de langages de programmation se sont principalement
consacrés à la modularité des méthodes. À l’inverse, la modularité du code d’initialisation a souvent été négligé. Le code
d’initialisation de beaucoup de langages orientés objets à classe est laborieux dans plusieurs cas: par exemple, quand
quelques champs (i.e., variables d’instances) ont plusieurs options d’initialisation (e.g., un rectangle peut être initialisé avec
des coordonnées Cartésiennes ou polaires), ont une initialisation optionnelle (e.g., un rectangle peut être positionné à une
coordonnée fournie ou à l’origine (0,0) si aucune coordonnée n’est fournie) ou héritent d’une initialisation de la super classe
(e.g., un rectangle coloré doit redéfinir tous les constructeurs de sa super classe pour ajouter la notion de couleur). Dans de
telles circonstances, le nombre de constructeurs augmente exponentiellement avec les options d’initialisation car l’approche
d’initialisation manque de modularité.
Nous proposons une approche d’initialisation novatrice s’inspirant du langage prototypique Magda. Cette approche est basée
sur des modules d’initialisation composables plus petits que les constructeurs classiques. De plus, le nombre de ces modules
augmente linéairement avec les options d’initialisation. Nous appliquons cette approche à Pharo, un langage orienté objets
dynamiquement typé inspiré de Smalltalk. L’adaptation à Pharo de l’approche d’initialisation de Magda implique la résolution
de nouveaux défis issus du passage d’un contexte statiquement typé à un contexte dynamique.
