Modélisation de la rupture par forces cohésives : formulations et exemples d'applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Modeling of the rupture by cohesive forces : formulations and examples of applications
In the context of industrial applications, the linear fracture mechanics theory is not sufficient to account for various aspects of the crack propagation and it becomes necessary to use more sophisticated models like cohesive force models. The goal of the present thesis is to develop such a model in order to account for all the process of the crack propagation, from the nucleation in a sound structure to the final failure of that structure. Specifically, we use Dugdale model which contains both the concept of critical stress and of internal length. The presence of a critical stress allows us to account for the nuckleation of a crack even if the body is initially sound, in contrast with Griffith theory which require the existence of preexisting cracks. The presence of an internal length allows us to account for pertinent scale effects, once again in contrast with Griffith theory in which the predicted scale effects are only correct for large specimen, not for small specimen. This approach is used to describe the full process of cracking in several cases, either by purely analytical methods when the geometry is simple enough, or by the finite element method with the code Cast3M in the case of complex geometry.
Dans le contexte industriel actuel, l'utilisation du modèle de forces cohésives en milieu solide revêt d'une importance capitale dans des nombreux domaines d'applications dont en particulier le domaine du transport, du nucléaire ou du génie-civil. En conséquence, la présente étude propose une modélisation numérique de la rupture fragile d'une plaque en acier en présence des forces cohésives. Le logiciel Cast3M est utilisé pour la mise en œuvre numérique. Le modèle de type Dugdale est utilisé et permet de calculer dans le cas d'une plaque élasto-plastique la distribution de contraintes à la pointe de fissure. Le modèle suppose, qu'à la pointe de fissure sur une longueur cohésive Lzc, les contraintes cohésives σc (x1), suivant l'axe Ox1 restent constante avec une amplitude égale à σc. Le domaine de rupture élastique et le domaine de ruine plastique a été prisent en compte. L'approche peut être considérée comme une extension de la mécanique linéaire de ruptures dans laquelle est introduite la notion de contrainte critique, ce qui permet en particulier de mieux rendre compte des effets d'échelle. A partir du principe de superposition des contraintes en mode I de rupture, les calcules dans la configuration déformée de la plaque fissurée a été étendue à d'autres géométries plus simples : une plaque avec fissure sans force cohésive, mais avec charge extérieure appliquée, une plaque avec une fissure purement cohésive et une plaque avec une fissure partiellement cohésive et sans charge extérieure. Ces différentes formes géométriques ont été prises en compte dans la modélisation numérique ainsi que la création de la fissure et le démarrage de la propagation. Le paramètre énergétique calculé selon la formule de l'intégrale J de Rice (1968) est également prise en compte et est comparé avec les résultats analytiques de Ferdjani et al. (2007).
2016PA066616.pdf (5.28 Mo) Télécharger le fichier
tel-01658919 , version 1 (08-12-2017)
  • HAL Id : tel-01658919 , version 1
Fidèle Massamba. Modélisation de la rupture par forces cohésives : formulations et exemples d'applications. Mécanique des matériaux [physics.class-ph]. Université Pierre et Marie Curie - Paris VI, 2016. Français. ⟨NNT : 2016PA066616⟩. ⟨tel-01658919⟩
443 Consultations
430 Téléchargements
