Designed of electrochemical sensor based on sampled-current voltammetry performed on an electrode array
Développement de capteurs électrochimiques basés sur de la voltammétrie par échantillonnage de courant sur réseau d'électrodes
As in many fields, safety is primarily based on the development of reliable and highly sensitive analytical methods to detect hazardous molecules. Therefore there is a need for developing simple methods for the diagnosis of harmful molecules in our environment. In this context, electrochemical detection systems seems very promising because they are highly sensitive, require short analysis time, are easy to implement and economic to fabricate. Moreover, our team has recently developed a new concept of device based on sampled-current voltammetry performed on an electrode array (EASCV) which is compatible with miniaturization and portability. The system allows the renewal of the electrode surface and of the analytical solution during the analysis. The present project addresses these issues and aims to extend it to methods involving a preconcentration step. A first study, for the detection of phenol, showed that EASCV offers a versatile solution to decrease fouling effect during the analysis. Indeed experimental and theoretical studies show that the renewable of electrode surface and of the solution in the vicinity of the electrode associated with the use of a short sampled time can avoid electrode fouling. For the first time, it was possible to combine sampled-current voltammetry with anodic stripping voltammetry. In this study, we were able to create a calibration curve, for the detection of lead, and we obtained current intensities 300 times higher than with usual linear stripping voltammetry.First attempts to adapt this new concept to pulse methods were promising.. To increase the sensitivity and selectivity of the sensor, the electrode array is chemically modified. The nature of this modification depends on the nature of the analyte. Thus, molecular imprinted polymer (for molecules) or macrocyclic ligands (for ions) are tested In both cases, an electrografting method is achieved to functionalize the surface. The first results are promising since a current-potential curve is obtained with a sensibility ten times higher than with a preconcentration by electrodeposition.
Comme dans beaucoup de domaines, la sécurité dépend du développement de méthodes analytiques très sensibles et fiables pour pouvoir détecter des molécules dangereuses. C'est pourquoi il est important de développer des méthodes simples afin de diagnostiquer rapidement un composé dangereux dans notre environnement. Dans ce contexte, les techniques électrochimiques offrent une alternative intéressante puisqu'elles permettent d'atteindre de grandes sensibilités et une bonne sélectivité, elles sont peu coûteuses et facilement adaptables pour la création de dispositifs portables. Récemment, notre équipe a développé un nouveau concept basé sur de la voltammétrie par échantillonnage de courant sur un réseau d'électrodes (EASCV), lequel est compatible avec la miniaturisation. Ce système permet de renouveler la surface et la solution au voisinage de l'électrode pendant l'analyse. Le projet de cette thèse a été d'étendre l'application de cette technique à des méthodes électrochimiques utilisant une étape de préconcentration. Une première étude, appliquée à la détection du phénol, a permis de montrer que l'EASCV offre une solution intéressante pour diminuer les phénomènes de passivation ayant lieu pendant l'analyse. En effet, une étude expérimentale associée à une étude théorique a montré que si un temps d'échantillonnage court était appliqué, le phénomène de passivation pouvait être évité. Enfin, pour la première fois, il a été possible de coupler la voltammétrie par échantillonnage de courant à la redissolution anodique. Cette étude, appliquée à la détection du plomb, a permis de mettre en place une courbe d'étalonnage et d'obtenir une intensité élevée de courant, 300 fois plus importante qu'avec les techniques classiques de redissolution anodique. Les premiers essais pour adapter ce nouveau concept aux méthodes pulsés se sont également montrés très encourageants. Afin d'améliorer la sensibilité et la sélectivité du capteur, le réseau d'électrodes a été fonctionnalisé. La modification dépend de la nature de l'espèce cible. Ainsi des polymères à empreintes moléculaires (pour des molécules comme la mélamine) ou des ligands (pour des ions comme le plomb) ont été testés. Dans les deux cas, une méthode d'électrogreffage a été mise au point pour fonctionnaliser la surface. Les premiers résultats obtenus sont encourageants puisqu'une courbe courant-potentiel a pu être tracée montrant une sensibilité 10 fois plus grande pour le plomb que celle obtenue avec une préconcentration par électrodépôt.
