Study of integrated devices for coherent light analysis and control : co-design of opto-eletronic integrated circuits and optical systems
Nouveaux dispositifs intégrés pour l'analyse et le contrôle de lumière cohérente : conception conjointe de circuits opto-électroniques et systèmes optiques
Among the optical medical imaging techniques used in medicine, the main limitation is the low resolution at a penetration depth greater than a few mm. This limitation does not allows competing with the standard imaging techniques such as X rays or RMI based imaging. In that scope, the acousto-optical imaging features several advantages: it allows measuring an optical contrast useful to detect tumors, in conjunction with the spatial resolution of ultrasound. However, the state of the art detecting devices feature a lack of sensitivity, which prevent its transfer to medical practitioners.This leads us to study the intrinsic features of the acousto-optical signal in order to propose two CMOS pixel architectures. The first one, fully analog, is compliant with the correlation time of biological tissue (1 ms typ.) and features an analog processing of the relevant signal. The second one is based on a digital pixel which contains an analog to digital converter, allowing simplifying the optical setup and increasing the robustness of the processing.In addition, related to the recent progress in wavefront control, an opto-electronic device, coupled with the first pixel architecture, has been proposed. It allows performing an optical phase operation (e.g. phase conjugation) in parallel on a pixels array, within the correlation time of biological media. Thus, this monolithic device circumvents the speed limitations of state of the art setup by a physical stacking of a liquid crystals spatial light modulator over a CMOS image sensor.
Parmi les techniques d'imagerie optiques utilisées en milieu clinique, la principale limitation est la faible résolution lorsque la profondeur d'examen dépasse quelques mm. Cette limite de résolution ne permet pas à l'heure actuelle de concurrencer les techniques d'imagerie médicales permettant de réaliser un examen du corps dans son intégralité (Rayons X, IRM, Scanner). Dans ce cadre, l'imagerie acousto-optique présente plusieurs avantages: elle permet de mesurer des propriétés optiques utiles pour la détection de tumeur, à la résolution spatiale des ultrasons. Cependant, les dispositifs de détection utilisés présentent un manque de sensibilité et de rapidité qui freinent le transfert de cette technique en milieu clinique.Ce constat nous a conduit à étudier les caractéristiques intrinsèques du signal acousto-optique afin de proposer deux architectures de pixels basées sur des technologies CMOS. La première architecture, totalement analogique, présente des caractéristiques de vitesse d'acquisition compatibles avec le temps de corrélation des milieux biologiques (<1 ms)et un pré-traitement du signal utile. La seconde architecture intègre une fonction de conversion analogique-numérique de manière à simplifier le montage optique, et traiter le signal plus efficacement.Par ailleurs, le contrôle de la phase en plusieurs points du front est essentiel pour refocaliser les signaux lumineux. Pour contourner les limitations de vitesse des dispositifs de contrôle adaptatif de phase de l'état de l'art, nous avons développé un dispositif monolithique constitué de l'empilement physique d'un modulateur de lumière en phase, à cristaux liquides, sur un circuit CMOS constitué d'une matrice de photo-détecteurs et de circuits de traitement afin de permettre le contrôle de front d'onde dès son acquisition. Le dispositif opto-électronique a été proposé et couplé à la première architecture électronique. Il permet de réaliser une opération sur la phase de l'onde lumineuse en chaque pixel (conjugaison de phase par ex.) en parallèle sur les pixels d'une matrice, dans un intervalle de temps inférieur au temps de corrélation des milieux biologiques.
