Stochastic models for resource allocation in large distributed systems
Modèles stochastiques pour l'allocation des ressources dans les grands systèmes distribués
This PhD thesis investigates four problems in the context of Large Distributed Systems. This work is motivated by the questions arising with the expansion of Cloud Computing and related technologies. The present work investigates the efficiency of different resource allocation algorithms in this framework. The methods used involve a mathematical analysis of several stochastic models associated to these networks. Chapter 1 provides an introduction to the subject in general, as well as a presentation of the main mathematical tools used throughout the subsequent chapters. Chapter 2 presents a congestion control mechanism in Video on Demand services delivering files encoded in various resolutions. We propose a policy under which the server delivers the video only at minimal bit rate when the occupancy rate of the server is above a certain threshold. The performance of the system under this policy is then evaluated based on both the rejection and degradation rates. Chapters 3, 4 and 5 explore problems related to cooperation schemes between data centres on the edge of the network. In the first setting, we analyse a policy in the context of multi-resource cloud services. In second case, requests that arrive at a congested data centre are forwarded to a neighbouring data centre with some given probability. In the third case, requests blocked at one data centre are forwarded systematically to another where a trunk reservation policy is introduced such that a redirected request is accepted only if there are a certain minimum number of free servers at this data centre.
Cette thèse traite de quatre problèmes dans le contexte des grands systèmes distribués. Ce travail est motivé par les questions soulevées par l'expansion du Cloud Computing et des technologies associées. Le présent travail étudie l'efficacité de différents algorithmes d'allocation de ressources dans ce cadre. Les méthodes utilisées impliquent une analyse mathématique de plusieurs modèles stochastiques associés à ces réseaux. Le chapitre 1 fournit une introduction au sujet, ainsi qu'une présentation des principaux outils mathématiques utilisés dans les chapitres suivants. Le chapitre 2 présente un mécanisme de contrôle de congestion dans les services de Video on Demand fournissant des fichiers encodés dans diverses résolutions. On propose une politique selon laquelle le serveur ne livre la vidéo qu'à un débit minimal lorsque le taux d'occupation du serveur est supérieur à un certain seuil. La performance du système dans le cadre de cette politique est ensuite évaluée en fonction des taux de rejet et de dégradation. Les chapitres 3, 4 et 5 explorent les problèmes liés aux schémas de coopération entre centres de données (CD) situés à la périphérie du réseau. Dans le premier cas, on analyse une politique dans le contexte des services de cloud multi-ressources. Dans le second cas, les demandes arrivant à un CD encombré sont transmises à un CD voisin avec une probabilité donnée. Au troisième, les requêtes bloquées dans un CD sont transmises systématiquement à une autre où une politique de réservation (trunk) est introduite tel qu'une requête redirigée est acceptée seulement s'il y a un certain nombre minimum de serveurs libres dans ce CD.
