Formation et devenir de l'empreinte parentale chez la levure S. pombe - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Formation and maintenance of the parental imprint in the yeast S. pombe
Genetic and molecular studies have indicated that an epigenetic imprint at mat1, the sexual locus of fission yeast, initiates mating type switching. The polar DNA replication of mat1 generates an imprint on the Watson strand. The process by which the imprint is formed and maintained through the cell cycle remains unclear. To understand better the mechanism of imprint formation and stability, we characterized the recruitment of early players of mating type switch at the mat1 region. We found that the switching activating protein 1 (Sap1) is preferentially recruited inside the mat1M allele on a sequence (SS13) that enhances the imprint. The lysine specific demethylases, Lsd1/2, that control the replication fork pause at MPS1 and the formation of the imprint are specifically drafted inside of mat1, regardless of the allele. The CENP-B homolog, Abp1, is highly enriched next to mat1 but it is not required in the process. Additionally, we established the computational signature of the imprint. Using this signature, we show that both sides of the imprinted molecule are bound by Lsd1/2 and Sap1, suggesting a nucleoprotein protective structure defined as imprintosome.
Des études moléculaires et génétiques ont montré qu'une empreinte épigénétique, située au niveau du locus sexuel (mat1) de la levure Schizosaccharomyces pombe, initie le changement de type sexuel. La réplication unidirectionnelle du locus mat1 permet la formation de l'empreinte sur le brin Watson. Les éléments moléculaires qui forment et protègent l'empreinte durant le cycle cellulaire restent peu connus. Afin de mieux comprendre le mécanisme de formation et de maintien de l'empreinte, j'ai caractérisé le recrutement au niveau du locus mat1 d'acteurs précoces dans le changement de type sexuel. J'ai montré que la protéine Sap1 (switch activating protein 1) est préférentiellement recrutée à l'intérieur de la séquence SS13, une séquence qui stabilise l'empreinte. Les protéines Lsd1/2 (lysine specific demethylases) qui contrôlent la pause de la fourche de réplication à mat1 et la formation de l'empreinte sont spécialement recrutées au niveau de mat1 indépendamment de l'allèle présent. La protéine Abp1 (homologue de CENP-B) est enrichie à côté de mat1 mais n'est pas impliquée dans la formation/maintien de l'empreinte. De plus, j'ai établi la signature de l'empreinte par séquençage à haut débit. En utilisant cette signature, j'ai mis en évidence que les protéines Lsd1/2 et Sap1 immunoprécipitent les deux côtés de la chromatide qui porte l'empreinte ce qui suggère la formation d'une structure protective définie comme l'imprintosome.
2017PA066187.pdf (25.73 Mo) Télécharger le fichier
tel-01663600 , version 1 (14-12-2017)
  • HAL Id : tel-01663600 , version 1
Célia Raimondi. Formation et devenir de l'empreinte parentale chez la levure S. pombe. Génétique. Université Pierre et Marie Curie - Paris VI, 2017. Français. ⟨NNT : 2017PA066187⟩. ⟨tel-01663600⟩
288 Consultations
41 Téléchargements
