Impact de l’essence forestière sur les processus de dégradation et d’assimilation des polysaccharides végétaux par la communauté fongique des sols forestiers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Impact of tree species on the mechanisms developed by fungal communities to degrade and assimilate plant organic matter in forest soils
The degradation of plant biomass is an essential process for the proper functioning of forest soils and terrestrial carbon cycling. Mechanisms involved in these processes are strongly controlled by saprotrophic fungi which secrete several hydrolytic enzymes to access at their primary nutrient sources found under the form of polysaccharides (cellulose and hemicelluloses). Enzymatic hydrolysis of plant polymers releases a high diversity of low molecular weight compounds (mono- and oligosaccharides). These molecules enter in fungal cell using transmembrane transporter systems. Consequently, the presence/absence and the substrate specificity of these transporters might contribute to the metabolic versatility of soil fungi. Several studies have demonstrated that tree species strongly affect diversity and composition of fungal communities. In this context, we hypothesized that the fungal communities selected by the different tree species expressed specific lignocellulolytic enzymes and sugar transporters; and thereby each fungal community was specifically adapted to the nature of litter produced by the tree species considered. We assessed, by the high-throughput sequencing of gene-fragments amplified from soil cDNA, the impact of tree species (Beech vs Spruce) on the diversity of genes encoding either lignocellulolytic enzymes or sugar porters expressed by soil fungi in two mono-specific forests. Our results revealed that most detected genes, encoding either lignocellulolytic enzymes or sugar transporters, have an unknown origin and are specifically found (for more than 80% of them) in one of the two forest soils. This work showed a significant “tree species effect” on the composition of functional genes expressed by soil fungi and suggests that beyond the species level, functional diversity of fungal communities must be addressed to better understand ecosystem functioning. Moreover, by using a functional metatranscriptomic approach, we identified functional transporter sequences differing with respect to their substrate specificities. From a spruce cDNA library, and for the first time, we identified high affinity or mannose specific transporters. Coincidently, as opposed to beech, spruce is indeed a tree species with a large proportion of mannose in its hemicelluloses
En milieu forestier, la décomposition de la matière organique d’origine végétale et son assimilation par les microorganismes sont des processus essentiels au bon fonctionnement des sols et du cycle du carbone. Les mécanismes impliqués dans ces phénomènes de dégradation sont fortement contrôlés par les champignons saprotrophes qui sécrètent de nombreuses enzymes hydrolytiques afin d’accéder à leur principale source de nutriments qui se trouve sous la forme de polysaccharides (cellulose et hémicelluloses). L’hydrolyse enzymatique de ces polymères végétaux engendre une grande diversité de composés de faible poids moléculaire (mono- et oligosaccharides). Ces molécules pénètrent dans la cellule fongique via des systèmes de transporteurs membranaires dont la présence/absence et la spécificité de substrat contribuent à la versatilité métabolique de ces microorganismes du sol. La nature de l’essence forestière affecte fortement la diversité et la composition des communautés fongiques. Dans ce contexte, nous avons émis l’hypothèse que les communautés fongiques sélectionnées par les différentes essences forestières diffèrent entre elles par la diversité des mécanismes qu’elles mettent en place lors du processus de décomposition de la matière organique d'origine végétale et lors du transport des produits de dégradation ; et que de ce fait chaque communauté fongique est spécifiquement adaptée à la nature de la litière produite par l’espèce végétale considérée. Par des approches de séquençage haut-débit d’amplicons générés à partir d’ADNc environnementaux, nous avons analysé la diversité des transcrits codant des protéines fongiques impliquées à la fois dans la dégradation des polysaccharides végétaux et dans le transport des sucres issus de cette hydrolyse enzymatique au sein de sols localisés sous des forêts de hêtres et d’épicéas. L’analyse des données obtenues a mis en évidence des transcrits jusqu’alors inconnus et spécifiquement retrouvés pour plus 80% d’entre eux sous l’un des deux couverts végétaux conduisant ainsi à un effet significatif de l’essence forestière sur la composition des gènes exprimés par les communautés fongiques. Des transporteurs potentiellement spécifiques du mannose ont été détectés, pour la première fois, sous la forêt d’épicéas par une approche de crible fonctionnel dans la levure de banques d’ADNc environnementaux. Or, cette essence forestière est connue pour posséder d’importantes quantités de mannose au niveau de ses hémicelluloses. Les résultats obtenus au cours de cette thèse soulignent l’importance d’étudier la diversité fonctionnelle des communautés fongiques pour comprendre l’impact du couvert végétal sur leur composition et le fonctionnement des écosystèmes forestiers
TH2015BarbiFlorian.pdf (36.45 Mo) Télécharger le fichier
tel-01666043 , version 1 (18-12-2017)
  • HAL Id : tel-01666043 , version 1
Florian Barbi. Impact de l’essence forestière sur les processus de dégradation et d’assimilation des polysaccharides végétaux par la communauté fongique des sols forestiers. Microbiologie et Parasitologie. Université Claude Bernard - Lyon I, 2015. Français. ⟨NNT : 2015LYO10347⟩. ⟨tel-01666043⟩
277 Consultations
51 Téléchargements
