From Images and Sounds to Face Localization and Tracking
Localisation et suivi de visages à partir d'images et de sons
In this thesis, we address the well-known problem of head-pose estimation in the context of human-robot interaction (HRI). We accomplish this task in a two step approach. First, we focus on the estimation of the head pose from visual features. We design features that could represent the face under different orientations and various resolutions in the image. The resulting is a high-dimensional representation of a face from an RGB image. We propose to solve the head-pose estimation problem by building a link between the head-pose parameters and the high-dimensional features perceived by a camera. This link is learned using a high-to-low probabilistic regression built using probabilistic a mixture of affine transformations. With respect to classic head-pose estimation methods we extend the head-pose parameters by adding some variables to take into account variety in the observations (e.g. misaligned face bounding-box), to obtain a robust method under realistic conditions. Evaluation of the methods shows that our approach achieve better results than classic regression methods and similar results than state of the art methods in head pose that use additional cues to estimate the head pose (e.g depth information). Secondly, we propose a temporal model by using tracker ability to combine information from both the present and the past. Our aim through this is to give a smoother estimation output, and to correct oscillations between two consecutive independent observations. The proposed approach embeds the previous regression into a temporal filtering framework. This extension is part of the family of switching dynamic models and keeps all the advantages of the mixture of affine regressions used. Overall the proposed tracker gives a more accurate and smoother estimation of the head pose on a video sequence. In addition, the proposed switching dynamic model gives better results than standard tracking models such as Kalman filter. While being applied to the head-pose estimation problem the methodology presented in this thesis is really general and can be used to solve various regression and tracking problems, e.g. we applied it to the tracking of a sound source in an image.
Dans cette thèse, nous abordons le problème de l'estimation de pose de visage dans le contexte des interactions homme-robot. Nous abordons la résolution de cette tâche à l'aide d'une approche en deux étapes. Tout d'abord nous proposons une nouvelle façon d'estimer la pose d'un visage, en apprenant un lien entre deux espaces, l'espace des paramètres de pose et un espace de grande dimension représentant les observations perçues par une caméra. L'apprentissage de ce lien se fait à l'aide d'une approche probabiliste, utilisant un mélange de regressions affines. Par rapport aux méthodes d'estimation de pose de visage déjà existantes, nous incorporons de nouvelles informations à l'espace des paramètres de pose, ces additions sont nécessaires afin de pouvoir prendre en compte la diversité des observations, comme les differents visages et expressions mais aussi les décalages entre les positions des visages détectés et leurs positions réelles, cela permet d'avoir une méthode robuste aux conditions réelles. Les évaluations ont montrées que cette méthode permettait d'avoir de meilleurs résultats que les méthodes de regression standard et des résultats similaires aux méthodes de l'état de l'art qui pour certaines utilisent plus d'informations, comme la profondeur, pour estimer la pose.
Dans un second temps, nous développons un modèle temporel qui utilise les capacités des traqueurs pour combiner l'information du présent avec celle du passé. Le but à travers cela est de produire une estimation de la pose plus lisse dans le temps, mais aussi de corriger les oscillations entre deux estimations consécutives indépendantes. Le modèle proposé intègre le précédent modèle de régression dans une structure de filtrage de Kalman. Cette extension fait partie de la famille des modèles dynamiques commutatifs et garde tous les avantages du mélange de regressions affines précédent. Globalement, le modèle temporel proposé permet d'obtenir des estimations de pose plus précises et plus lisses sur une vidéo. Le modèle dynamique commutatif donne de meilleurs résultats qu'un modèle de suivi utilsant un filtre de Kalman standard. Bien qu'appliqué à l'estimation de pose de visage le modèle presenté dans cette thèse est très général et peut être utilisé pour résoudre d'autres problèmes de régressions et de suivis.
