Communication- Based Power Modelling for Heterogeneous Multiprocessor Architectures, IEEE 10th International Symposium on Embedded Multicore/Many-core Systems-on-Chip, 2016. ,
Fast and Energy-Driven Design Space Exploration for Heterogeneous Architectures, IEEE 25th International Symposium on Field-Programmable Custom Computing Machines (FCCM), Poster, 2017. ,
Regression-based rtl power modeling, In: ACM Transactions on Design Automation of Electronic Systems, 2000. ,
Validity of the single processor approach to achieving large scale computing capabilities, Proceedings of the April 18-20, 1967, spring joint computer conference on, AFIPS '67 (Spring), 1967. ,
DOI : 10.1145/1465482.1465560
On Exploiting Energy-Aware Scheduling Algorithms for MDE-Based Design Space Exploration of MP2SoC, 2016 24th Euromicro International Conference on Parallel, Distributed, and Network-Based Processing (PDP), 2016. ,
DOI : 10.1109/PDP.2016.110
URL : https://hal.archives-ouvertes.fr/hal-01305971
The Time Model of Logical Clocks available in the OMG MARTE proole In: Synthesis of Embedded Software Design of EEcient Linear Feedback Shift Register for BCH Encoder, Journal of Electrical & Electronic Systems, 2010. ,
The landscape of parallel computing research: A view from berkeley An EEcient Framework for Power-Aware Design of Heterogeneous MPSoC, IEEE Transactions on Industrial Informatics, 2006. ,
The uniied modeling language, Unix Review, 1996. ,
Hardware-software co-design of embedded systems: the POLIS approach, 1997. ,
DOI : 10.1007/978-1-4615-6127-9
Code generation in the polyhedral model is easier than you think, Proceedings. 13th International Conference on Parallel Architecture and Compilation Techniques, 2004. PACT 2004., 2004. ,
DOI : 10.1109/PACT.2004.1342537
URL : https://hal.archives-ouvertes.fr/hal-00017260
OOcial QEMU git repository ,
QEMU, a Fast and Portable Dynamic Translator The Spice page, Annual Conference on USENIX, 2005. ,
Compiler transformations for high-performance computing, In: ACM Computing Surveys (CSUR), 1994. ,
The PARSEC benchmark suite, Proceedings of the 17th international conference on Parallel architectures and compilation techniques, PACT '08, 2008. ,
DOI : 10.1145/1454115.1454128
SystemC: From the Ground Up, Second Edition Hybrid functional-and instruction-level power modeling for embedded and heterogeneous processor architectures, Journal of Systems Architecture, 2007. ,
A Practical Automatic Polyhedral Parallelizer and Locality Optimizer, 29th ACM SIGPLAN Conference on Programming Language Design and Implementation Coarse- Grained Array Accelerator for Software-Deened Radio Baseband Processing, 2008. ,
DOI : 10.1145/1375581.1375595
URL : http://www.cse.ohio-state.edu/~bondhugu/publications/uday-pldi08.pdf
A Codesign Approach to Software Power Estimation for Embedded Systems Power estimation on a functional level for programmable processor, TI Devel Conference, 2000. ,
Adapting to Thrive in a New Economy of Memory Abundance, 2015. ,
Wattch: a Framework for Architectural-level Power Analysis and Optimizations, International Symposium on Computer Architecture (ISCA), 2000. ,
DOI : 10.1109/isca.2000.854380
Modeling and Simulation in SCILAB MAPS: An Integrated Framework for MPSoC Application Parallelization, 45th Annual Design Automation Conference, 2006. ,
Single-Chip Heterogeneous Computing: Does the Future Include Custom Logic, FPGAs, and GPGPUs?, 2010 43rd Annual IEEE/ACM International Symposium on Microarchitecture, 2010. ,
DOI : 10.1109/MICRO.2010.36
URL : http://www.ece.cmu.edu/%7Eechung/MICRO43-ucores.pdf
Multi-objective aware extraction of task-level parallelism using genetic algorithms, 2012 Design, Automation & Test in Europe Conference & Exhibition (DATE), 2012. ,
DOI : 10.1109/DATE.2012.6176503
Three approaches one tool Research Poster at The Designing for Embedded Parallel Computing Platforms (DEPCP) Automatic parallelization of embedded software using hierarchical task graphs and integer linear programming PARADE: A cycle-accurate full-system simulation Platform for Accelerator-Rich Architectural Design and Exploration, PaxES: PArallelism eXtraction for Embedded Systems 8th International Conference on Hardware/Software Codesign and System Synthesis (CODES+ISSS IEEE/ACM International Conference on Computer-Aided Design (ICCAD). Nov. 2015. [Cor+11] Daniel Cordes Automatic Extraction of Pipeline Parallelism for Embedded Software Using Linear Programming " . In: IEEE 17th International Conference on Parallel and Distributed Systems (ICPADS), 2010. ,
Automatic extraction of multi-objective aware pipeline parallelism using genetic algorithms, IFIP international conference on Hardware/software codesign and system synthesis (CODES+ISSS), p.8, 2011. ,
Automatic Extraction of pipeline parallelism for embedded heterogeneous multi-core platforms, 2013 International Conference on Compilers, Architecture and Synthesis for Embedded Systems (CASES), 2013. ,
DOI : 10.1109/CASES.2013.6662508
Automatic Extraction of Task-Level Parallelism for Heterogeneous MPSoCs, 2013 42nd International Conference on Parallel Processing, 2013. ,
DOI : 10.1109/ICPP.2013.113
Automatic Parallelization for Embedded Multi-Core Systems using High-Level Cost Models Accurate estimation of power dissipation in cmos sequential circuits, IEEE Transaction VLSI System, 1996. ,
QBox: an industrial solution for virtual platform simulation using QEMU and SystemC TLM-2.0, 8th European Congress on Embedded Real Time Software and Systems (ERTS), 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01292317
Design of ion-implanted MOSFET's with very small physical dimensions, IEEE Journal of Solid-State Circuits, 1974. ,
A clustered manycore processor architecture for embedded and accelerated applications, 2013. ,
Dataaow language compilation for a single chip massively parallel processor, IEEE 6th International Workshop on Multi-/Many-core Computing Systems (MuCoCoS), 2013. ,
TimeSquare: Treat Your Models with Logical Time, 50th International Conference on Objects, Models, Components, Patterns (TOOLS). May 2012. [DT01] Philips Electronic Design and Philips Research Tools Group. DIESEL, 2001. ,
DOI : 10.1007/978-3-642-30561-0_4
URL : https://hal.archives-ouvertes.fr/hal-00688590
System-level modelling and design space exploration for multiprocessor embedded system-on-chip architectures, 2007. ,
DOI : 10.5117/9789056294557
Dark Silicon and the End of Multicore Scaling, 38th Annual International Symposium on Computer Architecture (ISCA), pp.365-376, 2011. ,
GeCoS: A framework for prototyping custom hardware design flows, 2013 IEEE 13th International Working Conference on Source Code Analysis and Manipulation (SCAM), 2008. ,
DOI : 10.1109/SCAM.2013.6648190
URL : https://hal.archives-ouvertes.fr/hal-00921370
The program dependence graph and its use in optimization, In: ACM Transactions on Programming Languages and Systems (TOPLAS), 1987. ,
Low-density parity-check codes, IEEE Transactions on Information Theory, vol.8, issue.1, 1962. ,
DOI : 10.1109/TIT.1962.1057683
The CompSOC Design Flow for Virtual Execution Platforms ?C: A Programming Model and Language for Embedded Manycores, 10th FPGAworld Conference 11th International Conference Algorithms and Architectures for Parallel Processing, 2011. ,
The hierarchical task graph as a universal intermediate representation, International Journal of Parallel Programming, vol.25, issue.7, 1994. ,
DOI : 10.1016/S0022-0000(74)80049-8
Lsim power analyst : Transistor-level simulation. [GS08] Sébastien Gérard and Bran Selic, The UML ? MARTE Standardized Proole " . In: IFAC Proceedings Volumes, 2008. ,
The Mälardalen WCET benchmarks: Past, present and future, OASIcs-OpenAccess Series in Informatics, 2010. ,
CoMPSoC, ACM Transactions on Design Automation of Electronic Systems, vol.14, issue.1, 2009. ,
DOI : 10.1145/1455229.1455231
Chstone: A benchmark program suite for practical c-based high-level synthesis, Circuits and Systems ISCAS 2008. IEEE International Symposium on, 2008. ,
A Low Power Hardware/Software Partitioning Approach for Core-based Embedded Systems, 36th Annual ACM/IEEE Design Automation Conference (DAC), 1999. ,
DOI : 10.1145/309847.309896
URL : http://www.cs.ucr.edu/~vahid/courses/269_s01/dac99_henkel_hwswpartpower.pdf
The design and implementation of PowerMill, Proceedings of the 1995 international symposium on Low power design , ISLPED '95, 1995. ,
DOI : 10.1145/224081.224100
Transaction Level eMulator (TLMu) git repository. https://github Parmibench-an open-source benchmark for embedded multiprocessor systems, IEEE Computer Architecture Letters, 2010. ,
Vivado Design Suite -HLX edition, 2015. ,
Zynq-7000 All Programmable SoC: Technical Reference Manual, 2016. ,
Generic Compiler Suite. http://gecos.gforge.inira.fr. [Iri91] François Irigoin et al. PIPS: Automatic Parallelizer and Code Transformation Framework Increasing Temporal Locality with Skewing and Recursive Blocking, 1991. ,
OSCI TLM-2.0 Language reference manual, Open SystemC Initiative (OSCI), 2009. ,
The Semantics of Simple Language for Parallel Programming In: International Federation for Information Processing (IFIP) Aug Execution of heterogeneous models for thermal analysis with a multi-view approach, Proceedings of the 2014 Forum on Speciication and Design Languages (FDL), 1974. ,
Coroutines and networks of parallel processes International Federation for Information Processing (IFIP) Aug Functional Level Power Analysis: An EEcient Approach for Modeling the Power Consumption of Complex Processors FLPA-based power modeling and power aware code optimization for a Trimedia DSP, Design, Automation Test in Europe Conference and Exhibition (DATE). Feb. 2004. [LBN05] J. von Livonius, H. Blume, and, 1977. ,
MPSoC programming using the MAPS compiler, 2010 15th Asia and South Pacific Design Automation Conference (ASP-DAC), 2010. ,
DOI : 10.1109/ASPDAC.2010.5419677
A framework for estimating and minimizing energy dissipation of embedded HW/SW systems Mc- PAT: An integrated power, area, and timing modeling framework for multicore and manycore architectures, 35th Annual ACM/IEEE Design Automation Conference (DAC) 42nd Annual IEEE/ACM International Symposium on Microarchitecture (MICRO, 1998. ,
Mixed simulation kernels for high performance virtual platforms, In: Forum on Speciication Design Languages (FDL ,
Software radios: Survey, critical evaluation and future directions, IEEE Aerospace and Electronic Systems Magazine, 1993. ,
DOI : 10.1109/ntc.1992.267870
Cramming more components onto integrated circuits, 1965. ,
The sandblaster 2.0 architecture and SB3500 implementation, Software Deened Radio Technical Forum, 2008. ,
Gurobi Optimizer Reference Manual Automatic Thread Extraction with Decoupled Software Pipelining, www. gurobi.com. [Ott+05] 38th Annual IEEE/ACM International Symposium on Microarchitecture, 2005. ,
DOI : 10.1109/micro.2005.13
Liesbet Van der Perre, and Francky Catthoor Future Software-Deened Radio Platforms and Mapping Flows, IEEE Signal Processing Magazine, 2010. ,
DOI : 10.1109/msp.2009.935386
A systematic approach to exploring embedded system architectures at multiple abstraction levels, IEEE Transactions on Computers, vol.55, issue.2, 2006. ,
DOI : 10.1109/TC.2006.16
BEEBS: Open benchmarks for energy measurements on embedded platforms, 2013. ,
Exploring embedded-systems architectures with Artemis, Computer, vol.34, issue.11, p.Computer, 2001. ,
DOI : 10.1109/2.963445
Accurate Power Macro-modeling Techniques for Complex RTL Circuits, Int. Conf. VLSI Design, 2001. ,
A Comparison of Synchronous and Cyclo-Static Dataaow Asilomar Conference on Signals, Systems and Computers Function-level Power Estimation Methodology for Microprocessors, Qu+00] Gang Qu, Naoyuki Kawabe, Kimiyoshi Usami, and Miodrag Potkonjak 37th Annual Design Automation Conference (DAC), 1995. ,
Parallel-stage Decoupled Software Pipelining Software-Deened Radio Prospects for Multistandard Mobile Phones, 6th Annual IEEE/ACM International Symposium on Code Generation and Optimization, p.Computer, 2007. ,
Machsuite: Benchmarks for accelerator design and customized architectures, Workload Characterization (IISWC), 2014 IEEE International Symposium on, 2014. ,
DESSERT: DESign Space ExploRation Tool based on power and energy at System-Level, 27th IEEE International System-on-Chip Conference (SOCC), 2014. ,
VPPET: Virtual platform power and energy estimation tool for heterogeneous MPSoC based FPGA platforms, 2014 24th International Workshop on Power and Timing Modeling, Optimization and Simulation (PATMOS), pp.1-8, 2014. ,
DOI : 10.1109/PATMOS.2014.6951910
A Concurrent Execution Semantics for Parallel Program Graphs and Program Dependence Graphs JouleTrack-a Web based tool for software energy prooling, Proceedings of the 5th International Workshop on Languages and Compilers for Parallel Computing Proceedings of the 38th Design Automation Conference, 1993. ,
DOI : 10.1007/3-540-57502-2_37
Scilab: Le logiciel open source gratuit de calcul numérique. Scilab Enterprises Softexplorer: Estimating and Optimizing the Power and Energy Consumption of a C Program for DSP Applications, Sci12] Scilab Enterprises, 2001. ,
The Aladdin Approach to Accelerator Design and Modeling, IEEE Micro, vol.35, issue.3, p.IEEE Micro, 2015. ,
DOI : 10.1109/MM.2015.50
Compiling Scilab to high performance embedded multicore systems, Microprocessors and Microsystems, 2013. ,
DOI : 10.1016/j.micpro.2013.07.004
URL : https://hal.archives-ouvertes.fr/hal-00921437
Instruction level power analysis and optimization of software An innovative compilation tool-chain for embedded multi-core architectures " . In: Embedded World Conference. 2012. [Tou11] Georgios Tournavitis Proole-driven parallelisation of sequential programs, 9th International Conference on VLSI Design (VLSI)Vac+07] Neil Vachharajani Speculative Decoupled Software Pipelining " . In: 16th International Conference on Parallel Architecture and Compilation Techniques, 1996. ,
isl: An Integer Set Library for the Polyhedral Model, Mathematical Software ? ICMS 2010: Third International Congress on Mathematical Software Proceedings, pp.299-302, 2010. ,
DOI : 10.1007/978-3-642-15582-6_49
A loop transformation theory and an algorithm to maximize parallelism, IEEE Transactions on Parallel and Distributed Systems, vol.2, issue.4, 1991. ,
DOI : 10.1109/71.97902
From SODA to scotch: The evolution of a wireless baseband processor, 2008 41st IEEE/ACM International Symposium on Microarchitecture, 2008. ,
DOI : 10.1109/MICRO.2008.4771787
Lumos+: Rapid, pre-RTL design space exploration on accelerator-rich heterogeneous architectures with reconfigurable logic, 2016 IEEE 34th International Conference on Computer Design (ICCD) ,
DOI : 10.1109/ICCD.2016.7753297
Microblaze processor reference guide, p.reference manual, 2006. ,
The design and use of simple- Power: a cycle-accurate energy estimation tool, 37th Design Automation Conference (DAC), pp.340-345, 2000. ,
EAD and PEBD: Two Energy-Aware Duplication Scheduling Algorithms for Parallel Tasks on Homogeneous Clusters, IEEE Transactions on Computers, 2011. ,
DOI : 10.1109/TC.2010.216
URL : http://www.eng.auburn.edu/users/xzq0001/pubs/ead-pebd-tc11.pdf
