Abstract : Data structured in the Resource Description Framework (RDF) are increasingly available in large volumes. This leads to a major need and research interest in novel methods for query analysis and compilation for making the most of RDF data extraction. SPARQL is the widely used and well supported standard query language for RDF data. In parallel to query language evolutions, schema languages for expressing constraints on RDF datasets also evolve. Shape Expressions (ShEx) are increasingly used to validate RDF data, and to communicate expected graph patterns. Schemas in general are important for static analysis tasks such as query optimisation and containment. Our purpose is to investigate the means and methodologies for SPARQL query static analysis and optimisation in the presence of ShEx schema constraints.
Our contribution is mainly divided into two parts. In the first part we consider the problem of SPARQL query containment in the presence of ShEx constraints. We propose a sound and complete procedure for the problem of containment with ShEx, considering several SPARQL fragments. Particularly our procedure considers OPTIONAL query patterns, that turns out to be an important feature to be studied with schemas. We provide complexity bounds for the containment problem with respect to the language fragments considered. We also propose alternative method for SPARQL query containment with ShEx by reduction into First Order Logic satisfiability, which allows for considering SPARQL fragment extension in comparison to the first method. This is the first work addressing SPARQL query containment in the presence of ShEx constraints.
In the second part of our contribution we propose an analysis method to optimise the evaluation of conjunctive SPARQL queries, on RDF graphs, by taking advantage of ShEx constraints. The optimisation is based on computing and assigning ranks to query triple patterns, dictating their order of execution. The presence of intermediate joins between the query triple patterns is the reason why ordering is important in increasing efficiency. We define a set of well-formed ShEx schemas, that possess interesting characteristics for SPARQL query optimisation. We then develop our optimisation method by exploiting information extracted from a ShEx schema. We finally report on evaluation results performed showing the advantages of applying our optimisation on the top of an existing state-of-the-art query evaluation system.
Résumé : La disponibilité de gros volumes de données structurées selon le modèle Resource Description Framework (RDF) est en constante augmentation. Cette situation implique un intérêt scientifique et un besoin important de rechercher de nouvelles méthodes d’analyse et de compilation de requêtes pour tirer le meilleur parti de l’extraction de données RDF. SPARQL est le plus utilisé et le mieux supporté des langages de requêtes sur des données RDF. En parallèle des langages de requêtes, les langages de définition de schéma d’expression de contraintes sur des jeux de données RDF ont également évolués. Les Shape Expressions (ShEx) sont de plus en plus utilisées pour valider des données RDF et pour indiquer les motifs de graphes attendus. Les schémas sont importants pour les tâches d’analyse statique telles que l’optimisation ou l’injection de requêtes. Notre intention est d’examiner les moyens et méthodologies d’analyse statique et d’optimisation de requêtes associés à des contraintes de schéma.
Notre contribution se divise en deux grandes parties. Dans la première, nous considérons le problème de l’injection de requêtes SPARQL en présence de contraintes ShEx. Nous proposons une procédure rigoureuse et complète pour le problème de l’injection de requêtes avec ShEx, en prenant en charge plusieurs fragments de SPARQL. Plus particulièrement, notre procédure gère les patterns de requêtes OPTIONAL, qui s’avèrent former un important fonctionnalité à étudier avec les schémas. Nous fournissons ensuite les limites de complexité de notre problème en considération des fragments gérés. Nous proposons également une méthode alternative pour l’injection de requêtes SPARQL avec ShEx. Celle-ci réduit le problème à une satisfiabilité de Logique de Premier Ordre, qui permet de considérer une extension du fragment SPARQL traité par la première méthode. Il s’agit de la première étude traitant l’injection de requêtes SPARQL en présence de contraintes ShEx.
Dans la seconde partie de nos contributions, nous proposons une méthode d’analyse pour optimiser l’évaluation de requêtes SPARQL groupées, sur des graphes RDF, en tirant avantage des contraintes ShEx. Notre optimisation s’appuie sur le calcul et l’assignation de rangs aux triple patterns d’une requête, permettant de déterminer leur ordre d’exécution. La présence de jointures intermédiaires entre ces patterns est la raison pour laquelle l’ordonnancement est important pour gagner en efficicacité. Nous définissons un ensemble de schémas ShEx bien- formulés, qui possède d’intéressantes caractéristiques pour l’optimisation de requêtes SPARQL. Nous développons ensuite notre méthode d’optimisation par l’exploitation d’informations extraites d’un schéma ShEx. Enfin, nous rendons compte des résultats des évaluations effectuées, montrant les avantages de l’application de notre optimisation face à l’état de l’art des systèmes d’évaluation de requêtes.
