Synthesis and formulation of inkjet-printable conductive inks for organic electronics
Synthèse et formulation d’encres conductrices imprimables par jet d’encre pour l’électronique organique
Considering large-scale development and fabrication of organic electronic devices, needs for low cost conductive printable materials are growing. These materials are designed to replace thin metallic layers deposited via gravure or thermal evaporation. The objective of the work presented in this report is to obtain a conductive and inkjet printable aqueous stable dispersion of polyaniline. Originality of this PhD work is to describe all the steps from the chemical synthesis of polyaniline starting from the monomer, until the integration of the conductive ink in an organic solar cell as a conductive top electrode, through formulation of the ink to meet inkjet printing requirements. During the first part of work dedicated to chemical synthesis of PANI, we managed to produce a nanostructured and conductive material, with controlled size and morphology, which was dispersed in water. This aqueous dispersion was formulated to meet inkjet printing requirements and break technological locks such as particle size in the PANI dispersion. Formulation step was then validated during printing trials, which allowed optimising shape of ejected droplets. Printed PANI thin layers showed sheet resistance below 1000 Ω/□ after 20 printing passes. Finally, conductive ink was printed as a top electrode in fully solution–processed printed organic solar cell.
Dans le cadre de la fabrication de dispositifs pour l’électronique organique à grande échelle, les besoins en matériaux conducteurs stables à l’air libre, de coût réduit et compatibles avec les techniques d’impression sont croissants. Ces matériaux sont destinés à remplacer les couches métalliques déposés par des méthodes telles que la gravure ou l’évaporation sous vide. Les travaux présentés dans cette thèse ont pour objectif la mise au point d’une encre imprimable stable à l’air libre, composée de polyaniline dispersée en phase aqueuse. L’originalité de cette thèse est de décrire l’intégralité de ce processus, depuis la synthèse chimique de la charge, à partir du monomère jusqu’à l’intégration de l’encre conductrice dans une cellule solaire organique sous forme d’électrode imprimée, en passant par la formulation de l’encre. La première partie des travaux consacrés à la synthèse chimique de la charge a permis d’obtenir un matériau nano structuré, de taille et morphologie contrôlée, dispersable en phase aqueuse et conducteur. Cette dispersion a ensuite été formulée pour lui conférer des propriétés compatibles avec l’impression jet d’encre et lever des verrous critiques comme la granulométrie. La phase d’essai d’impression jet d’encre a permis de valider l’étape de formulation et d’optimiser la morphologie des gouttelettes éjectées. Les couches minces imprimées ont permis d’atteindre des résistances surfaciques inférieures à 1000 Ω/□. Finalement l’encre conductrice a pu être imprimée en tant qu’électrode supérieure dans des cellules solaires organiques.
