Abstract : In the latest years, the Web has shifted from a read-only medium where most users could only consume information to an interactive medium allowing every user to create, share and comment information. The downside of social media as an information source is that often the texts are short, informal and lack contextual information. On the other hand, the Web also contains structured Knowledge Bases (KBs) that could be used to enrich the user-generated content.
This dissertation investigates the potential of exploiting information from the Linked Open Data KBs to detect, classify and track events on social media, in particular Twitter. More specifically, we address 3 research questions: i) How to extract and classify messages related to events? ii) How to cluster events into fine-grained categories? and 3) Given an event, to what extent user-generated contents on social medias can contribute in the creation of a timeline of sub-events?
We provide methods that rely on Linked Open Data KBs to enrich the context of social media content; we show that supervised models can achieve good generalisation capabilities through semantic linking, thus mitigating overfitting; we rely on graph theory to model the relationships between NEs and the other terms in tweets in order to cluster fine-grained events. Finally, we use in-domain ontologies and local gazetteers to identify relationships between actors involved in the same event, to create a timeline of sub-events. We show that enriching the NEs in the text with information provided by LOD KBs improves the performance of both supervised and unsupervised machine learning models.
Résumé : Les réseaux sociaux ont transformé le Web d'un mode lecture, où les utilisateurs pouvaient seulement consommer les informations, à un mode interactif leur permettant de les créer, partager et commenter. Un défi majeur du traitement d'information dans les médias sociaux est lié à la taille réduite des contenus, leur nature informelle et le manque d'informations contextuelles. D'un autre côté, le web contient des bases de connaissances structurées à partir de concepts d'ontologies, utilisables pour enrichir ces contenus.
Cette thèse explore le potentiel d'utiliser les bases de connaissances du Web de données, afin de détecter, classifier et suivre des événements dans les médias sociaux, particulièrement Twitter. On a abordé 3 questions de recherche: i)Comment extraire et classifier les messages qui rapportent des événements? ii)Comment identifier des événements précis? iii)Étant donné un événement, comment construire un fil d'actualité représentant les différents sous-événements?
Les travaux de la thèse ont contribué à élaborer des méthodes pour la généralisation des entités nommées par des concepts d'ontologies pour mitiger le sur-apprentissage dans les modèles supervisés; une adaptation de la théorie des graphes pour modéliser les relations entre les entités et les autres termes et ainsi caractériser des événements pertinents; l'utilisation des ontologies de domaines et les bases de connaissances dédiées, pour modéliser les relations entre les caractéristiques et les acteurs des événements. Nous démontrons que l'enrichissement sémantique des entités par des informations du Web de données améliore la performance des modèles d'apprentissages supervisés et non supervisés.
