Specific properties of supercritical fluids for fast and exothermic reactive systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Les propriétés spécifiques des fluides supercritiques au service des systèmes réactifs contraignants
The development of new catalysts for propyne and propadiene (MAPD) hydrogenation is a complex process, because it is a fast reaction performed in gas-liquid-solid. Indeed, in these conditions, the hydrogen flux (G/L and L/S) transported to the reaction sites controls the overall reaction rate, particularly at pilot scale. To avoid this limitation, the MAPD selective hydrogenation was performed in single-phase, using a single pellet string reactor (SPSR) at high-pressure and supercritical conditions. For both conditions, the literature is scarce. Thus, the first step was to develop and validate a microfluidic experimental apparatus and a methodology based on “design of experiments”, in order to obtain PT miscibility diagrams and critical coordinates. These methods combined allowed a fast PT screening compared to conventional phase behavior cells, being around 5 times higher. In parallel, the SPSR was characterized by computational fluid dynamics (CFD) for flow and mass transfer. It was shown that the hydrodynamic inside the reactor can be modeled as a plug flow reactor with low axial dispersion, and a LS mass transfer correlation was proposed. After the fluid and reactor characterization, the MAPD hydrogenation was performed at 303 K and from 20 to 120 bar. At these conditions, several parameters were tested, such as WHSV (weight hourly space velocity), pressure and solvent fraction. The results showed that high-pressure and supercritical conditions offer better reaction performance, which is due to the suppression of the gas-liquid limitation and to the diffusivity enhancements (more than 5 times faster than conventional conditions). With this thesis, it was possible, for the first time, to estimate the intrinsic kinetics parameters of a dense C3 cut mixture hydrogenation, allowing a deeper understanding of the involved mechanism. Thus, the use of unconventional conditions has opened a door to new forms of catalyst screening and new ways to study kinetics.
Le développement de nouveaux catalyseurs pour l’hydrogénation sélective du propyne et du propadiène (MAPD) est un processus complexe, puisqu’il s’agit d’une réaction rapide effectuée en gaz-liquide-solide. Dans ces conditions, le flux d'hydrogène transporté aux sites actifs du catalyseur contrôle la vitesse de la réaction, particulièrement à l’échelle pilote. Cela rend difficile la comparaison des performances des différents catalyseurs (conversion et sélectivité). Afin d’améliorer la discrimination des solides, l’hydrogénation sélective du MAPD a été étudiée en monophasique (fluide/solide) dans un réacteur filaire à haute pression et en supercritique.La première partie de la thèse a eu pour objectif de déterminer les conditions de fonctionnement adéquates : un dispositif expérimental microfluidique et une méthodologie associée ont été développés et validés pour obtenir les diagrammes P-T de miscibilité et les coordonnées critiques des systèmes réactionnels mis en jeu. En parallèle, le réacteur a été caractérisé en utilisant des outils numériques (CFD) appliqués à l’hydrodynamique et au transfert de masse. Les tests expérimentaux ont alors pu être menés, dans la seconde partie de la thèse, afin d’étudier l'hydrogénation du MAPD à 303 K entre 20 et 120 bar. Dans ces conditions, plusieurs paramètres ont été étudiés, tels que la PPH (vitesse spatiale horaire, ou WHSV en anglais), la pression et la fraction de solvant. Les résultats montrent un gain important de conversion du MAPD à haute pression et en conditions supercritiques par rapport aux conditions classiques (>5 fois plus). Cela peut s’expliquer par la suppression de l’interface gaz-liquide et l’amélioration des diffusivités. Les variations de sélectivité observées en parallèle montre sa dépendance au flux d’hydrogène amené. Ces résultats prometteurs permettent une meilleure discrimination des catalyseurs ainsi qu’une meilleure compréhension du système réactif. Ainsi, pour la première fois, en utilisant ces données non classiques, il a au final été possible d'estimer des paramètres cinétiques intrinsèques pour l’hydrogénation sélective des coupes C3.
DA_SILVA_PINHO_BRUNO_MIGUEL_2015.pdf (10.9 Mo) Télécharger le fichier
tel-01683247 , version 1 (13-01-2018)
  • HAL Id : tel-01683247 , version 1
Bruno Miguel da Silva Pinho. Specific properties of supercritical fluids for fast and exothermic reactive systems. Material chemistry. Université de Bordeaux, 2015. English. ⟨NNT : 2015BORD0229⟩. ⟨tel-01683247⟩
245 Consultations
504 Téléchargements
