Elaboration de liquides ioniques (chiraux) réversibles et applications en catalyse organique et en glycochimie. Carbènes N-hétérocycliques chiraux : synthèse et application dans la réaction d'addition conjuguée - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Elaboration of reversible (chiral) ionic liquids and applications in organic catalysis and in glycochemistry. Chiral N-heterocyclic carbenes : synthesis and application in the conjugate addition reaction
At first, this work deals with the synthesis of a novel class of single-component reversible chiral ionic liquids derived from natural aminoacids. Reversibility was demonstrated by NMR, thermogravimetric analysis and differential scanning calorimetry. These compounds were tested as organocatalysts in an asymmetric Michael addition leading to the formation of expected product in moderate yields. Chiral silylamines, precursors to reversible ionic liquids were also evaluated in the synthesis of Warfarin through an asymmetric Michael addition. Good yields were obtained. However, these catalysts have resulted in only low enantioselectivity. Moreover, the use of reversible ionic liquid as a temporary protecting group in glycochemistry, for the synthesis of disaccharides was also implemented. Secondly, some new chiral imidazolinium salts, precursors to NHCs, were synthesized from (S)-pyroglutamic acid, for copper-catalyzed conjugate addition of Grignard reagents to α,β-unsaturated ketones applications. The results have shown moderate enantioselectivity with very good catalytic activity and excellent regioselectivity.
Ce travail de thèse porte, dans un premier temps, sur le développement d'une nouvelle synthèse de liquides ioniques chiraux réversibles, en système mono-composant, à partir d'aminoacides naturels. La réversibilité a été démontrée par RMN, par analyse thermogravimétrique et par calorimétrie différentielle à balayage. Ces composés ont été testés comme catalyseurs organiques dans la réaction d’addition de Michael asymétrique. Des rendements modérés ont été obtenus. Les silylamines chirales, précurseurs des liquides ioniques chiraux réversibles, ont été évaluées dans la synthèse de Warfarine via une addition de Michael asymétrique. De bons rendements ont été obtenus. Toutefois, ces catalyseurs n'ont permis de conduire qu'à de faibles énantiosélectivités. L'utilisation de liquides ioniques réversibles comme groupements protecteurs temporaires en glycochimie, pour la synthèse de disaccharides, a été mise en œuvre. Dans un second temps, de nouveaux sels d'imidazolinium chiraux précurseurs de NHCs ont été synthétisés, à partir de l'acide (S)-pyroglutamique en vue de leur application dans la réaction d'addition conjuguée de cétones α, β-insaturées catalysée au cuivre avec des réactifs de Grignard. Les excès énantiomériques sont modestes mais de bons résultats en termes d’activité catalytique et de régiosélectivité ont été obtenus.
75799_BOUCHARDY_2016_diffusion.pdf (10.11 Mo) Télécharger le fichier
tel-01683248 , version 1 (13-01-2018)
  • HAL Id : tel-01683248 , version 1
Lucie Bouchardy. Elaboration de liquides ioniques (chiraux) réversibles et applications en catalyse organique et en glycochimie. Carbènes N-hétérocycliques chiraux : synthèse et application dans la réaction d'addition conjuguée. Chimie organique. Université Paris Saclay (COmUE), 2016. Français. ⟨NNT : 2016SACLS400⟩. ⟨tel-01683248⟩
422 Consultations
1106 Téléchargements
