Fire endurance of concrete slabs as influenced by thickness, aggregate type and moisture Journal PCA Research Development Laboratories, pp.9-24, 1968. ,
Guide for Structural Lightweight Aggregate Concrete Reported by ACI Committee 213, p.3, 2003. ,
Guide to curing concrete Reported by ACI Committee 308, p.1, 2001. ,
Béton léger considéré comme un matériau porteur : technologie du béton léger, 1968. ,
Effect of distribution of lightweight aggregates on internal curing of concrete Cement and, Concrete Research, vol.32, pp.611-616, 2010. ,
Les milieux granulaires CNRS Editions, 15 rue Malebranche, 75005 Paris ARGEX Fabricant de granulats d'argile expansée par four rotatif www, 2011. ,
Granulats et Bétons Légers Édition, 1986. ,
Evaluation of static stability of self consolidating concrete ACI, Materials Journal, vol.101, issue.3, pp.207-215, 2004. ,
Standard test method of air content of freshly mixed concrete by the volumetric method, 2009. ,
Additivity effects in the rheology of fresh concrete containing water-reducing admixtures, Construction and Building Materials, vol.25, issue.6, pp.2955-2960, 2011. ,
DOI : 10.1016/j.conbuildmat.2010.12.001
Steel corrosion monitoring in normal and total-lightweight concretes exposed to chloride and sulphate solutions part II: Polarisation resistance measurements, Cement and Concrete Research, vol.26, issue.5, pp.691-696, 1996. ,
DOI : 10.1016/S0008-8846(96)85005-8
Cement paste content and water absorption of recycled concrete coarse aggregates Materials and Structures DOI 10, pp.11527-11540, 1617. ,
Prevention of autogenous shrinkage in high-strength concrete by internal curing using wet lightweight aggregates, Cement and Concrete Research, vol.31, issue.11, pp.1587-1591, 2001. ,
DOI : 10.1016/S0008-8846(01)00608-1
Influence of internal curing using lightweight aggregates on interfacial transition zone percolation and chloride ingress in motars, Cement & Concrete Composites, pp.31-285, 2009. ,
Mixture proportioning for internal curing, Concrete International, vol.27, issue.2, pp.35-40, 2005. ,
Formulation des bétons, pp.210-2009, 2009. ,
Lightweight concrete: A proven material for two millennia Proceedings of Advances in Cement and Concrete, pp.37-41, 1994. ,
Elastic compatibility and the behavior of concrete ACI journal, Proceedings V. 83 N. 2, pp.244-250, 1986. ,
Self-Compacting Concrete: Theoretical and experimental study, Cement and Concrete Research, vol.35, issue.11, pp.2116-2136, 2005. ,
DOI : 10.1016/j.cemconres.2005.06.002
The resistivity of mortars immersed in sea-water, Cement and Concrete Research, vol.16, issue.4, pp.511-524, 1986. ,
DOI : 10.1016/0008-8846(86)90089-X
Mixture proportioning method for self-compacting high performance concrete with minimum paste volume Proceedings of the 1st international RILEM Symposium, pp.373-384, 1999. ,
Absorption and desorption properties of fine lightweight aggregate for application to internally cured concrete mixtures, Cement and Concrete Composites, vol.33, issue.10, pp.1001-1008, 2011. ,
DOI : 10.1016/j.cemconcomp.2011.07.006
Lightweight self-consolidating concrete: systematic approach and case study BFT International 08, 2009. ,
Producing synthetic lightweight aggregates from reservoir sediments, Construction and Building Materials, vol.28, issue.1, pp.387-394, 2012. ,
DOI : 10.1016/j.conbuildmat.2011.08.051
Stability of fresh lightweight aggregate concrete under vibration ACI, Materials Journal, vol.102, issue.5, pp.347-354, 2005. ,
An experimental research on the fluidity and mechanical properties of high-strength lightweight selfcompacting concrete Cement and Concrete research, pp.36-1596, 2006. ,
Effet du taux de saturation des granulats sur le retrait du béton XXVIIIième Rencontres, pp.642-651, 2010. ,
Structures granulaires et formulation des bétons Collection Études et Recherches des Laboratoires des Ponts et Chaussées, OA, vol.34, 1999. ,
La nouvelle méthode des coulis de l'AFREM pour la formulation des bétons à hautes performances Bulletin des Laboratoires des Ponts et Chaussées n°202, pp.61-69, 1996. ,
Une approche de la formulation des bétons légers de structure Bulletin de Liaison des Laboratoire des Ponts et Chaussées, pp.39-47, 1995. ,
Sur la contribution de la topologie du squelette granulaire ?? la r??sistance en compression du b??ton, Materials and Structures, vol.20, issue.1, pp.505-516, 1993. ,
DOI : 10.1680/macr.1973.24.80.127
Relation entre formulation et quelques propri??t??s m??caniques des b??tons ?? hautes performances, Materials and Structures, vol.14, issue.1, pp.464-475, 1992. ,
DOI : 10.1007/BF02472636
Developments of two-point workability test for high-performance concrete Magazine Concrete, Research, vol.51, pp.171-180, 1999. ,
Influence of lightweight aggregate on the microstructure and durability of mortar, Cement and Concrete Research, vol.35, issue.7, pp.1368-1376, 2005. ,
DOI : 10.1016/j.cemconres.2004.07.011
A study on lightweight aggregate Engineering Experiment Station Bulletin n° 169 part II Testing and Modelling of Fresh Concrete Rheology NISTIR 6094, National Institute of Standards and Technology Microstructure and mineralogy of lightweight aggregates produced from washing aggregate sludge, fly ash and used motor oil, Cement & Concrete Composites, vol.59, issue.332, pp.21-45, 1958. ,
Pumice aggregates for structural lightweight and internally cured concrete New Zealand Concrete Industry Conference, 2009. ,
The effects of pumice aggregate/cement ratios on the low-strength concrete properties, Construction and Building Materials, vol.22, issue.5, pp.721-728, 2008. ,
DOI : 10.1016/j.conbuildmat.2007.01.030
Retrofitting of building structures using pumpable self-compacting lightweight concrete Proceedings of the third international RILEM conference on SCC, pp.776-785, 2003. ,
Strength and durability of lightweight concrete in hot marine exposure conditions Materials and Structures, Matériaux et Constructions, vol.32, pp.533-538, 1999. ,
Structural LWAC. Specification and guideline for materials and production Edition 2nd International symposium on Structural lightweight aggregate concrete, 2000. ,
Volume change and cracking in internally cured mixtures made with satured lightweight aggregate under sealed and unsealed conditions, Cement & Concrete Composites, pp.31-427, 2009. ,
Water absorption in internally cured mortar made with water-filled lightweight aggregate, Cement and Concrete Research, vol.39, issue.10, pp.883-892, 2009. ,
DOI : 10.1016/j.cemconres.2009.06.009
Lightweight aggregate concrete subject to severe weathering ACI Concrete International, pp.49-54, 1984. ,
Rhéologie des bétons fluides Études et recherches des Laboratoires des Ponts et Chaussées, p.203, 1995. ,
The effect of metakaolin and silica fume on the properties of lightweight self-compacting concrete ACI International Conference on Recent Advances in Concrete Technology, pp.35-48, 2007. ,
A new mix design concept for earth-moist concrete: A theoretical and experimental study, Cement and Concrete Research, vol.38, issue.10, pp.1246-1259, 2008. ,
DOI : 10.1016/j.cemconres.2008.04.002
Durability design and performance of self-consolidating lightweight concrete, Construction and Building Materials, vol.19, issue.8, pp.619-626, 2005. ,
DOI : 10.1016/j.conbuildmat.2005.01.003
Autogenous deformation and RH-change in perspective, Cement and Concrete Research, vol.31, issue.12, pp.1859-1865, 2001. ,
DOI : 10.1016/S0008-8846(01)00501-4
A method to determine water retainability of porous fine aggregate for design and quality control of fresh concrete, Construction and Building Materials, vol.21, issue.6, pp.1322-1334, 2007. ,
DOI : 10.1016/j.conbuildmat.2006.01.009
Effect of aggregate mix composition on lightweight self-consolidating concrete International Rilem Conference on Self Compacting Concrete, Canada, pp.203-210, 2010. ,
Caractérisation du comportement mécanique des bétons de granulats légers : Expérience et modélisation Thèse de doctorat de l, 2008. ,
Comparaison of field-oriented test methods to assess dynamic stability of self-consolidating lightweight concrete ACI, Materials Journal, vol.101, issue.2, pp.168-176, 2004. ,
Characteristics of self-consolidating concrete using two types of lightweight coarse aggregates, Construction and Building Materials, vol.24, issue.1, pp.11-16, 2010. ,
DOI : 10.1016/j.conbuildmat.2009.08.004
Characteristics of lightweight fly ash aggregates produced with different binders and heat treatments Cement and Concrete Composites, pp.33-61, 2011. ,
Influence of the type of coarse lightweight aggregate on fresh properties of semi-lightweight self consolidating concrete International Rilem Conference on Self Compacting Concrete, Canada, pp.233-242, 2010. ,
Steel-concrete bond strength of lightweight self-consolidating concrete Materials and Structures 42, pp.1015-1023, 2009. ,
DOI : 10.1617/s11527-008-9440-4
Essais de compacité des fractions granulaires à la table à secousses Laboratoire Central des Ponts et Chaussée ? IST Diffusion des éditions, 2004. ,
Effects of CaO addition on lightweight aggregates produced from water reservoir sediment, Construction and Building Materials, vol.25, issue.6, pp.2997-3002, 2011. ,
DOI : 10.1016/j.conbuildmat.2010.12.034
Development of lightweight concrete with high resistance to water and chloride-ion penetration, Cement and Concrete Composites, vol.32, issue.10, pp.757-766, 2010. ,
DOI : 10.1016/j.cemconcomp.2010.08.005
Permeability of high-performance concrete incorporating presoaked lightweight aggregates for internal curing Magazine of Concrete Research, pp.79-89, 2010. ,
Comparison of workability and mechanical properties of self-compacting lightweight concrete and normal self-compacting concrete, Materials Research Innovations, vol.2004, issue.34, pp.45-50, 2007. ,
DOI : 10.1016/j.wasman.2003.06.003
A simple and significant segregation test for SCC Proceedings of the third international RILEM conference on SCC, pp.356-366, 2003. ,
An investigation on the fresh properties of self-compacted lightweight concrete containing expanded polystyrene, Construction and Building Materials, vol.25, issue.9, pp.3721-3731, 2011. ,
DOI : 10.1016/j.conbuildmat.2011.04.018
Pâtes de ciment : Résultats des essais mécaniques à 28 jours Rapport interne, 1992. ,
Self-compacting lightweight concrete ? A new high-performance building material, Ozawa K. and Ouchi M. Edition 2nd International Symposium on Self-compacting Concrete COMS Engineering Corporation, pp.21-28, 2001. ,
Determining the specific gravities of coarse aggregates utilizing vacuum saturation approach, Construction and Building Materials, vol.23, issue.3, pp.1316-1322, 2009. ,
DOI : 10.1016/j.conbuildmat.2008.07.025
The viscosity of a concentrated suspension of spherical particles, Journal of Colloid Science, vol.6, issue.2, p.162, 1951. ,
DOI : 10.1016/0095-8522(51)90036-0
Quels outils pour caractériser la ségrégation statique ? Les bétons auto-plaçants ? Presses des ponts ?, pp.53-74, 2011. ,
Properties of concrete Fourth and Final Edition, 1995. ,
Properties of structural lightweight concrete Structural Lightweight Concrete, pp.1-17, 1993. ,
Durability of lightweight aggregate concrete after 10 years in marine and acid environments International Symposium on Structural Lightweight Aggregate Concrete, pp.591-603, 1995. ,
Development of High Performance Concrete Journal of the Faculty of Engineering, pp.381-439, 1992. ,
Examination of effective parameters for the production of expanded clay aggregate, Cement and Concrete Composites, vol.34, issue.6, pp.781-787, 2012. ,
DOI : 10.1016/j.cemconcomp.2012.02.007
Lightweight Aggregate Self-Compacting Concrete: State-of-the-Art & Pumice Application Journal of Advanced Concrete Technology, pp.15-29, 2011. ,
Assessing Lightweight Aggregate Efficiency for Maximizing Internal curing Performance ACI Materails Journal, pp.385-393, 2011. ,
A model for Self-Compacting Concrete International Rilem Conference on "Production Methods and Workability of Concrete, RILEM Proceedings, 1996. ,
Concrete science and reality Materials Science of Concrete II American Society Relation of chemical properties to the bloating of clays, Journal of American Ceramic Society, vol.30, issue.4, pp.121-128, 1950. ,
Determination of elastic properties of lightweight aggregate by ultrasonic pulse velocity measurement The International Journal of lightweight concretes 1, pp.78-90, 1979. ,
Interdependence of microstructure and strength of structural lightweight aggregate concrete, Cement and Concrete Composites, vol.14, issue.4, pp.239-248, 1992. ,
DOI : 10.1016/0958-9465(92)90022-N
Rhéologie et rhéomètrie des bétons. Application aux bétons autonivelants Thèse de l'École Nationale des Ponts et Chaussées, 1999. ,
Logiciel René, 1999. ,
René LCPC: Un logiciel pour optimiser la granularité des matériaux de génie civil Bulletin de Liaison des Laboratoires des Ponts et Chaussées n°194, 1994. ,
Recherche sur le processus de gonflement des argiles Liegelind 24 n°12, pp.899-905, 1963. ,
Mixture proportioning and properties of self-consolidating lightweight concrete containing glass powder ACI, Materials Journal, vol.102, issue.5, pp.355-363, 2005. ,
Compatibilité élastique, comportement mécanique et optimisation des bétons de granulats légers Thèse de la Faculté des Sciences et de Génie de l, 2003. ,
Linear Packing Density of Grain Mixture Powder Technology, 1986. ,
A new method for the mix design of medium strength flowing concrete with low cement content Cement & Concrete Composites, pp.215-222, 2003. ,
Rheometric and ultrasonic investigations of viscoelastic properties of fresh Portland cement pastes, Cement and Concrete Research, vol.36, issue.2, pp.278-287, 2005. ,
DOI : 10.1016/j.cemconres.2005.08.007
The microstructure of Lytag aggregate, International Journal of Cement Composites and Lightweight Concrete, vol.3, issue.4, pp.273-282, 1981. ,
DOI : 10.1016/0262-5075(81)90038-5
Development and Utilisation of High-Performance Concrete for the Construction of the Akashi Kaikyo Bridge High Performance Concrete in Severe Environnements, pp.25-51, 1993. ,
Production of synthetic lightweight aggregate using reservoir sediments for concrete and masonry, Cement and Concrete Composites, vol.33, issue.2, pp.292-300, 2011. ,
DOI : 10.1016/j.cemconcomp.2010.10.008
Blocking criteria for Aggregate Phase of Self-compacting High Performance, Concrete Proceedings of Regional Symposium on Infrastructures Development in Civil Engineering, SC-4, pp.58-69, 1995. ,
Effect of aggregate type on properties of hardened self-consolidating lightweight concrete (SCLC), Construction and Building Materials, vol.24, issue.7, pp.1286-1295, 2010. ,
DOI : 10.1016/j.conbuildmat.2009.12.007
Effects of lightweight fly ash aggregate properties on the behavior of lightweight concretes, J Hazard Mater, vol.179, pp.1-3954, 2010. ,
Properties of Self-Consolidating Lightweight Aggregate Concrete PhD thesis, 2008. ,
Calculation of U-Values of hollow concrete masonry Concrete International, pp.40-63, 1980. ,
Etude des migrations de l'eau dans les bétons légers extrait de « Granulats et Bétons Légers, Presse de l'École Nationale des Ponts et Chaussées, pp.247-254, 1986. ,
Généralités sur les caractères des bétons légers, extrait de « Granulats et Bétons Légers, Presse de l'École Nationale des Ponts et Chaussées, pp.111-246, 1986. ,
Design, production and mechanical properties of expanded slate lightweight self-consolidating concrete Proceedings SCC, pp.187-193, 2005. ,
Rheology as a tool in concrete science: The use of rheographs and workability boxes, Cement and Concrete Research, vol.41, issue.12, pp.1279-1288, 2011. ,
DOI : 10.1016/j.cemconres.2011.01.009
Durability of self-consolidating lightweight aggregate concrete using dredged silt Construction and Building Materials 23, pp.2332-2337, 2009. ,
DOI : 10.1016/j.conbuildmat.2008.11.006
Effect of lightweight fly ash aggregate microstructure on the strength of concretes, Cement and Concrete Research, vol.27, issue.4, pp.525-537, 1997. ,
DOI : 10.1016/S0008-8846(97)00019-7
An experimental study on the workability of self-compacting lightweight concrete, Construction and Building Materials, vol.23, issue.5, pp.2087-2092, 2009. ,
DOI : 10.1016/j.conbuildmat.2008.08.023
Modeling of internal curing in maturing mortar, Cement and Concrete Research, vol.41, issue.12, pp.1349-1356, 2011. ,
DOI : 10.1016/j.cemconres.2011.04.013
Study on mix proportion for self compacting high performance lightweight aggregate, concrete Eds 2nd International Symposium on Structural Lightweight Aggregate, pp.18-22, 2000. ,
Development of thermal energy storage concrete, Cement and Concrete Research, vol.34, issue.6, pp.927-934, 2004. ,
DOI : 10.1016/j.cemconres.2003.10.022
Penetration of cement paste into lightweight aggregate, Cement and Concrete Research, vol.22, issue.1, pp.47-55, 1992. ,
DOI : 10.1016/0008-8846(92)90135-I
Characteristics of lightweight aggregate for high strength To be published in ACI, Materials Journal, vol.88, issue.2, pp.150-158, 1991. ,
Microstructure of the interfacial zone between lightweight aggregate and cement paste, Cement and Concrete Research, vol.20, issue.4, pp.610-618, 1990. ,
DOI : 10.1016/0008-8846(90)90103-5
Backsscattered electron imaging on the interfacial zone between high strength lightweight aggregate and cement paste Advanced Cement Research, pp.141-146, 1989. ,
DOI : 10.1680/adcr.1989.2.8.141
Valorisation des fines de concassage de béton pour la fabrication de mortiers Thèse de doctorat de l'Ecole des Mines de Douai et de l, 2014. ,
Revisiting the protected paste volume concept for internal curing of high-strength concretes, Cement and Concrete Research, vol.41, issue.9, pp.981-986, 2011. ,
DOI : 10.1016/j.cemconres.2011.05.007
