List processing in real time on a serial computer, Communications of the ACM, vol.21, issue.4, p.21 ,
DOI : 10.1145/359460.359470
Mathematizing C++ concurrency, Proceedings of the 38th Annual ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, pp.55-66, 2011. ,
DOI : 10.1145/1925844.1926394
URL : http://www.cl.cam.ac.uk/%7Ess726/papers/c%2B%2B-popl11.pdf
Library abstraction for C/C++ concurrency, Proceedings of the 40th Annual ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, POPL '13, pp.235-248 ,
DOI : 10.1145/2429069.2429099
URL : http://kar.kent.ac.uk/50270/1/POPL.13.library_abstraction_c_cpp.pdf
Scheduling multithreaded computations by work stealing, Journal of the ACM, vol.46, issue.5, pp.720-748, 1999. ,
DOI : 10.1145/324133.324234
URL : http://csdl.computer.org/comp/proceedings/sfcs/1994/6580/00/0365680.pdf
Cilk: An efficient multithreaded runtime system, Proceedings of the Fifth ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, PPOPP '95, pp.207-216, 1995. ,
DOI : 10.1006/jpdc.1996.0107
URL : http://www.lcs.mit.edu/publications/pubs/pdf/MIT-LCS-TM-548.pdf
Drop the anchor, Proceedings of the 25th ACM symposium on Parallelism in algorithms and architectures, SPAA '13, pp.33-42 ,
DOI : 10.1145/2486159.2486184
A class of parallel tiled linear algebra algorithms for multicore architectures, Parallel Computing, vol.35, issue.1, pp.38-53, 2009. ,
DOI : 10.1016/j.parco.2008.10.002
LUSTRE: a declarative language for real-time programming, Proceedings of the 14th ACM SIGACT-SIGPLAN symposium on Principles of programming languages , POPL '87, pp.178-188, 1987. ,
DOI : 10.1145/41625.41641
Dynamic circular work-stealing deque, Proceedings of the 17th annual ACM symposium on Parallelism in algorithms and architectures , SPAA'05, pp.21-28, 2005. ,
DOI : 10.1145/1073970.1073974
YAPI, Proceedings of the 37th conference on Design automation , DAC '00, pp.402-405, 2000. ,
DOI : 10.1145/337292.337511
User-Level Implementations of Read-Copy Update, IEEE Transactions on Parallel and Distributed Systems, vol.23, issue.2, pp.375-382, 2012. ,
DOI : 10.1109/TPDS.2011.159
Solution of a problem in concurrent programming control, Communications of the ACM, vol.8, issue.9, p.569, 1965. ,
DOI : 10.1145/365559.365617
A Practical Multi-word Compare-and-Swap Operation, Proceedings of the 16th International Conference on Distributed Computing, DISC '02, pp.265-279, 2002. ,
DOI : 10.1007/3-540-36108-1_18
URL : http://www.cl.cam.ac.uk/Research/SRG/netos/papers/2002-casn.ps
The Repeat Offender Problem: A Mechanism for Supporting Dynamic-Sized, Lock-Free Data Structures, 2002. ,
DOI : 10.1007/3-540-36108-1_23
Impossibility and universality results for wait-free synchronization, Proceedings of the seventh annual ACM Symposium on Principles of distributed computing , PODC '88, pp.276-290, 1988. ,
DOI : 10.1145/62546.62593
URL : http://repository.cmu.edu/cgi/viewcontent.cgi?article=2796&context=compsci
A methodology for implementing highly concurrent data structures, Proceedings of the Second ACM SIGPLAN Symposium on Principles &Amp; Practice of Parallel Programming, PPOPP '90, pp.197-206, 1990. ,
DOI : 10.1145/99163.99185
URL : http://www.cs.utexas.edu/~lorenzo/corsi/cs380d/papers/p745-herlihy.pdf
Axioms for concurrent objects, Proceedings of the 14th ACM SIGACT-SIGPLAN Symposium on Principles of Programming Languages, pp.13-26, 1987. ,
DOI : 10.21236/ada200584
URL : http://www.dtic.mil/dtic/tr/fulltext/u2/a200584.pdf
Obstruction-free synchronization: double-ended queues as an example, 23rd International Conference on Distributed Computing Systems, 2003. Proceedings., p.522, 2003. ,
DOI : 10.1109/ICDCS.2003.1203503
URL : http://research.sun.com/people/moir/Papers/ICDCS2003.pdf
The semantics of a simple language for parallel programming, Proceedings of IFIP 74, pp.471-475, 1974. ,
Coroutines and networks of parallel processes, Proceedings of IFIP 77, pp.993-998, 1977. ,
URL : https://hal.archives-ouvertes.fr/inria-00306565
Owicki-Gries Reasoning for Weak Memory Models, Proceedings , Part II of the 42Nd International Colloquium on Automata, Languages, and Programming, pp.311-323, 2015. ,
DOI : 10.1007/978-3-662-47666-6_25
Proving the Correctness of Multiprocess Programs, IEEE Transactions on Software Engineering, vol.3, issue.2, pp.125-143, 1977. ,
DOI : 10.1109/TSE.1977.229904
Correct and Efficient Bounded FIFO Queues, 2013 25th International Symposium on Computer Architecture and High Performance Computing, pp.144-151, 2013. ,
DOI : 10.1109/SBAC-PAD.2013.8
Correct and efficient work-stealing for weak memory models, Proceedings of the 18th ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, PPoPP '13, pp.69-80 ,
Static Scheduling of Synchronous Data Flow Programs for Digital Signal Processing, IEEE Transactions on Computers, vol.36, issue.1, pp.24-35, 1987. ,
DOI : 10.1109/TC.1987.5009446
A lock-free, cache-efficient shared ring buffer for multi-core architectures, Proceedings of the 5th ACM/IEEE Symposium on Architectures for Networking and Communications Systems, ANCS '09, pp.78-79, 2009. ,
DOI : 10.1145/1882486.1882508
Read-copy-update: Using execution history to solve concurrency problems, Proceedings of the 10th IASTED International Conference on Parallel and Distributed Computing and Systems, PDCS '98, pp.509-518, 1998. ,
Safe memory reclamation for dynamic lock-free objects using atomic reads and writes, Proceedings of the twenty-first annual symposium on Principles of distributed computing , PODC '02, pp.21-30, 2002. ,
DOI : 10.1145/571825.571829
Simple, fast, and practical non-blocking and blocking concurrent queue algorithms, Proceedings of the Fifteenth Annual ACM Symposium on Principles of Distributed Computing, PODC '96, pp.267-275, 1996. ,
DOI : 10.1145/248052.248106
URL : https://www.researchgate.net/profile/Michael_Scott6/publication/2804621_Simple_Fast_and_Practical_Non-Blocking_and_Blocking_Concurrent_Queue_Algorithms/links/00b7d5143281ae37fa000000.pdf
Resources, concurrency, and local reasoning, Theor. Comput. Sci, vol.375, issue.1-3, pp.271-307, 2007. ,
Verifying linearizability with hindsight, Proceedings of the 29th ACM SIGACT-SIGOPS Symposium on Principles of Distributed Computing, pp.85-94 ,
Myths about the mutual exclusion problem, Information Processing Letters, vol.12, issue.3, pp.115-116, 1981. ,
DOI : 10.1016/0020-0190(81)90106-X
Hierarchical Task-Based Programming With StarSs, The International Journal of High Performance Computing Applications, vol.17, issue.1, pp.284-299, 2009. ,
DOI : 10.1109/5.476078
OpenStream, ACM Transactions on Architecture and Code Optimization, vol.9, issue.4, pp.1-53, 2013. ,
DOI : 10.1145/2400682.2400712
URL : https://hal.archives-ouvertes.fr/hal-00786675
StreamIt: A Language for Streaming Applications, Proceedings of the 11th International Conference on Compiler Construction, CC '02, pp.179-196, 2002. ,
DOI : 10.1007/3-540-45937-5_14
URL : http://www.cag.lcs.mit.edu/~thies/papers/streamit-cc.pdf
A practical wait-free simulation for lock-free data structures, Proceedings of the 19th ACM SIGPLAN Symposium on Principles and Practice of Parallel Programming, pp.357-368 ,
DOI : 10.1145/2692916.2555261
Systems programming: Coping with parallelism, 1986. ,
GPS: Navigating weak memory with ghosts, protocols, and separation, Proceedings of the 2014 ACM International Conference on Object Oriented Programming Systems Languages & Applications, OOPSLA '14, pp.691-707 ,
Relaxed Separation Logic: A program logic for C11 concurrency, Proceedings of the 2013 ACM SIGPLAN International Conference on Object Oriented Programming Systems Languages & Applications, OOPSLA '13, pp.867-884 ,
DOI : 10.1145/2509136.2509532
Common compiler optimisations are invalid in the C11 memory model and what we can do about it, Proceedings of the 42Nd Annual ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, POPL '15, pp.209-220 ,
URL : https://hal.archives-ouvertes.fr/hal-01089047
Lock-free linked lists using compare-and-swap, Proceedings of the fourteenth annual ACM symposium on Principles of distributed computing , PODC '95, pp.214-222, 1995. ,
DOI : 10.1145/224964.224988
URL : http://www.cs.brown.edu/courses/cs295h/valois.ps
Deterministic scale-free pipeline parallelism with hyperqueues Networking, Storage and Analysis, SC '13, Proceedings of the International Conference on High Performance Computing, pp.1-32 ,
DOI : 10.1145/2503210.2503233
URL : https://pure.qub.ac.uk/portal/files/11663999/postprint.pdf
