Compréhension des mécanismes de biodétérioration des matériaux cimentaires dans les réseaux d'assainissement : étude expérimentale et modélisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Understanding of cementitious materials biodeterioration in sewer networks : experimental study and modelling
Important deteriorations have been observed in concrete sewers, due to hydrogen sulfide (H2S) presence. H2S is used as nutrients for sulfur-oxidizing bacteria (bacteria able to oxidize the reduced sulfur compounds) and is oxidized into sulfuric acid. This acid attack of concrete leads to cementitious matrix dissolution and expansive products formation (gypsum and ettringite). This phenomenon disturbs the sewer system and conducts to expensive works of rehabilitation. In order to avoid this degradation, a French project named “FUI Duranet” was initiated to propose more efficient solutions. The aim of this thesis is to define a representative and accelerated test as well as a predictive model.Abiotic tests allow stating that this first stage of the biodeterioration mechanisms is not the limiting stage. Indeed, the adapted surface pH of the cementitious materials to bacteria development is quickly reached with a high H2S concentration (100 ppm), whatever the cementitious materials considered (mortars based on CEM I, CEM III, CEM IV, CEM V, CAC, and SSC cements). The chemical-transport modeling of the sulfuric acid attack of cementitious materials and the establishment of a representative and accelerated test have been proposed to predict their service life in these conditions. For the test, different seeding technics have been compared in order to determine which one lead to the better reproduction and acceleration of biodeterioration mechanisms. This test allows recommending the sludge use, which contains a microorganism’s consortium, rather than a collection strain use, whose activity is too dependent on environmental conditions. With the experimental test and the model, the better resistance of the calcium aluminate cement and the important degradation of the Portland cements are quickly confirmed, as highlighted during the field tests
Des détériorations importantes sont observées dans les réseaux d’assainissement en béton en raison de la présence d’hydrogène sulfuré (H2S). Différentes études ont montré qu’un environnement riche en hydrogène sulfuré entraîne, au contact de surfaces cimentaires, la sélection de bactéries sulfo-oxydantes (bactéries capables d’oxyder des composés soufrés réduits), menant à la production d’acide sulfurique. Cet acide détériore localement les réseaux par dissolution et recomposition minéralogique de la matrice cimentaire (formation de gypse et d’ettringite). Les réseaux ne collectent alors plus correctement les eaux usées et ce phénomène provoque donc des travaux de rénovation onéreux. Dans ce contexte, des solutions plus performantes que celles mises en place actuellement doivent être étudiées. L’objectif du projet FUI DURANET dans lequel s’inscrit cette thèse vise à proposer un essai accéléré et à développer un modèle.La mise en place d’essais abiotiques a permis de démontrer que cette première étape n’est pas l’étape limitante du phénomène de biodétérioration. En effet, le pH de surface des matériaux cimentaires adapté au développement microbien est rapidement atteint lorsqu’ils sont mis au contact de l’hydrogène sulfuré à une concentration élevée (100 ppm), quel que soit le matériau cimentaire considéré (mortiers à base de ciments CEM I, CEM III, CEM IV, CEM V, CAC et CSS). La modélisation de l’attaque par l’acide sulfurique et la mise en place d’un essai représentatif et accéléré ont ensuite été abordées pour prédire la durabilité des différents matériaux cimentaires de l’étude. Pour l’essai, différentes techniques d’ensemencement des microorganismes à la surface des matériaux cimentaires ont été comparées, afin de déterminer laquelle mène à la meilleure reproduction des conditions d’un réseau d’assainissement et à l’accélération des mécanismes de biodétérioration la plus importante. Ces essais permettent de préconiser l’utilisation de boues activées contenant un consortium de microorganismes, par rapport à l’utilisation de souches de collection, dont l’activité dépend trop fortement de leur adaptabilité aux conditions environnementales. L’ensemble des résultats, obtenus expérimentalement et par modélisation, montre une meilleure résistance des ciments d’aluminate de calcium et une dégradation très importante des ciments Portland face aux mécanismes mis en jeu, en accord avec les essais in-situ
TH2017PESC1089.pdf (20.82 Mo) Télécharger le fichier
tel-01685132 , version 1 (16-01-2018)
  • HAL Id : tel-01685132 , version 1
Anais Grandclerc. Compréhension des mécanismes de biodétérioration des matériaux cimentaires dans les réseaux d'assainissement : étude expérimentale et modélisation. Matériaux. Université Paris-Est, 2017. Français. ⟨NNT : 2017PESC1089⟩. ⟨tel-01685132⟩
484 Consultations
404 Téléchargements
