Nucleoside diphosphate kinase D : a bifunctional mitochondrial protein
Nucléoside diphosphate kinase D : une protéine mitochondriale bifonctionnelle
The nucleoside diphosphate kinases (NDPK) are essential for generation of nucleoside triphosphates (NTPs) using ATP and NDPs. The mitochondrial NDPK isoform (NDPK-D) located in the mitochondrial intermembrane space is found to have two modes of function. First, the phosphotransfer mode in which the protein has a kinase activity like other NDPK enzymes. In this mode, NDPK-D produces GTP for the optic atrophy 1 protein (OPA1), a GTPase involved in mitochondrial fusion, and ADP for the adenylate translocator (ANT) and the mitochondrial ATPase for ATP regeneration. The second mode of function is called lipid transfer and is related to the capacity of NDPK-D to bind anionic phospholipids, especially cardiolipin (CL). In this mode, the protein can cross-link the two mitochondrial membranes and transfer CL from the inner to the outer mitochondrial membrane, which can serve as a signal for mitophagy and apoptosis. This work aims to study these NDPK-D functions in more detail. With the use of HeLa cells stably expressing the wild-type, kinase inactive (H151N mutation) or lipid binding deficient (R90D mutation) NDPK-D and mouse lung epithelial cells, we show (i) the close proximity between NDPK-D and OPA1 that leads to GTP channeling from NDPK-D to OPA1, (ii) the essential role of NDPK-D for CL externalization to the mitochondrial surface during mitophagy, serving as a recognition signal for LC3-II-autophagosomes to eliminate damaged mitochondria, (iii) the possible inhibition of CL externalization due to the presence of NDPK-D/OPA1 complexes, and (iv) a pro-metastatic phenotype of HeLa cells expressing either of the NDPK-D mutants (H151N or R90D), characterized by high invasive and migratory potential, altered proteomic profile and changed mitochondrial network structure and function. Finally, a first bacterial expression and purification strategy for full-length OPA1 has been established for future in vitro studies of NDPK-D/OPA1 complexes.
Les nucléosides diphosphate kinases (NDPK) sont essentielles pour la génération des nucléosides triphosphates (NTPs) en utilisant l’ATP et des NDPs. L’isoforme mitochondriale de NDPK (NDPK-D), située dans l’espace intermembranaire des mitochondries, possède deux modes de fonctionnement. Dans le premier mode (« phosphotransfert »), la protéine a une activité de kinase comme les autres enzymes NDPK. Dans ce mode de fonctionnement, NDPK-D produit du GTP pour la protéine optique atrophy 1 (OPA1), une GTPase impliquée dans la fusion des mitochondries, et de l’ADP pour le translocateur à adénine (ANT) et l’ATPase mitochondriale pour la régénération d’ATP. Le second mode de fonctionnement est appelé « transfert de lipide » et est lié à la capacité de la protéine à se lier aux phospholipides anioniques, particulièrement la cardiolipine (CL). Dans ce mode NDPK-D peut réticuler les deux membranes mitochondriales et transférer CL de la membrane interne vers la membrane externe des mitochondries, pouvant servir de signal pour la mitophagie et l’apoptose. Ce travail a pour objectif d’étudier plus en détails ces différentes fonctions de NDPK-D. En utilisant des cellules HeLa exprimant de façon stable la protéine sauvage, kinase inactive (mutation H151N) ou incapable de se lier aux lipides (mutation R90D) et des cellules épithéliales de poumons de souris, nous montrons (i) une grande proximité entre NDPK-D et OPA1 qui conduit au channeling de GTP par NDPK-D pour OPA1, (ii) le rôle essentiel de NDPK-D pour l’externalisation de CL vers la surface des mitochondries pendant la mitophagie, servant de signal de reconnaissance pour le complexe LC3-II-autophagosomes afin d’éliminer les mitochondries endommagées, (iii) la possible inhibition de l’externalisation de CL par la présence de complexes NDPK-D/OPA1, et (iv) un phénotype pro-métastatique des cellules HeLa exprimant la NDPK-D mutée (H151N ou R90D), caractérisé par un fort potentiel invasif et migratoire, un profil protéique altéré, et des modifications au niveau structural et fonctionnel du réseau mitochondrial. Finalement, une première stratégie d’expression et de purification de la protéine OPA1 entière a été établie pour de futures études in vitro des complexes NDPK-D/OPA1.
