In vitro study of the MAP6 effects on the microtubules
Etude in vitro des effets de la protéine MAP6 sur le cytosquelette
The eukaryotic cell's cytoskeleton is constitued by three types of different polymers which are the actin filaments, the intermediate filaments and the microtubules. These elements confer on the cell the main part of its mechanical properties such as the architecture preservation or the modification of its shape to allow the cellular movement. They are also involved in the organelles or nutrients transport throughout the cell, in the chromosomes segregation during mitosis or still in the cellular division process. To answer the cell's various needs, these filaments are extremly dynamics and are able to dis-assemblate to re-assemblate in another place of the cell. Tis dynamic is regulated ny numerous proteins which are going to be capable of modifiying the intrinsic properties of the different filaments (dynamic, mechanic and structure). Among them are present the MAPs, for Microtubule-Associated Proteins, which will be able to influence the microtubule dynamics and structure. MAP6, also known as STOP for Stable Tubule Only Peptide, is a neuronal MAP which was initially described for its capacity to protect microtubule from cold or nocodazole exposure. KO MAP6 mice display cognitive and behavioral disorders close to patient with schyzophrenia, involving at least partially microtubules stabilization defects. However, the effects of the protein on the microtubules still remained to determine. In this context, using diverse biochemical and cideomicroscopy technics, we showed that MAP6 is able to directly interact in vitro with the microtubules and stabilizes them. It also regulates the microtubule dynamics by increasing the microtubule growth rate of the plus end extremity, decreases the shrinkage frequency and allows rescue of shrinking microtubules, similarly to other MAPs like Tau or MAP2. However, contrary to the other MAPs, we showed that MAP6 has another effect on the microtubule (-) end by decreazing and freezing its dynamics. This dual effect could confer to MAP6 an essential role of microtubules nucleation by stabilizing the new formed microtubule (-) end and by stabilizing and increasing the (+) end microtubule growth rate. Furthermore, MAP6 is also able to strongly modify the microtubule structure. Microtubules are the stiffest elements of the cytoskeleton and naturally form due to their composition linear hollow tubes. Yet in presence of MAP6, microtubules lose their usual shape and adopt a helical structure (4,5 μm pitch and approximatly 1 μm thickness) which had never been observed until now. The presence of such a population of microtubules in the neuron could thus provide a mechanical strength and allow the preservation of the axon architecture. Finally, we showed that MAP6 can also directly interact with the actin filaments to associate them and form bundles. In neurons, several molecules have been identified as key regulators in the " crosstalk " between actin filaments and microtubules. The interaction and coordination between the different cytoskeletal elements play a vital role in the synaptic transmission. MAP6 may be important for all these mechanisms which would explain the synaptic plasticity and cognitive defects observed in KO MAP6 mice.
Le cytosquelette d'une cellule eucaryote est constitué de trois types de polymères différents qui sont l'actine, les filaments intermédiaires et les microtubules. Ces éléments confèrent à la cellule l'essentiel de ses propriétés mécaniques telles que le maintien de l'architecture ou la modification de sa forme pour permettre le déplacement cellulaire. Ils sont également impliqués dans le transport d'organites ou de nutriments d'un bout à l'autre de la cellule, dans la ségrégation des chromosomes lors de la mitose ou encore dans le processus de division cellulaire. Pour répondre aux différents besoins de la cellule, ces filaments sont extrêmement dynamiques et peuvent se désassembler pour se réassembler à un autre endroit de la cellule. Cette dynamicité est régulée par de nombreuses protéines accessoires qui vont être capables de modifier les propriétés intrinsèques des différents filaments (dynamique, mécanique et organisatrice). Parmi ces protéines régulatrices, l'on distingue tout particulièrement les MAPs, pour Microtubule Associated Proteins, capables de modifier la dynamique et la structure des microtubules. MAP6, ou encore STOP pour Stable Tubule Only Peptide, est une MAP neuronale qui fut initialement décrite pour sa capacité à protéger les microtubules d'une exposition au froid ou encore de drogues dépolymérisantes comme le nocodazole. Des souris délétées pour le gène MAP6 montrent des troubles cognitifs et comportementaux proches des patients atteints de schizophrénie, impliquant au moins en partie des défauts de stabilisation des microtubules. Cependant, les effets de la protéine sur les microtubules restaient encore à déterminer. Dans ce contexte, à l'aide de diverses approches biochimiques et vidéomicroscopiques, nous avons montré que la protéine MAP6 est capable d’interagir de façon directe avec les microtubules in vitro et permet leur stabilisation. Elle permet aussi de réguler la dynamique des microtubules en augmentant la vitesse de polymérisation de l'extrémité (+), de diminuer la fréquence de catastrophe et l'apparition d’événements de sauvetage, de façon similaire à d'autres MAPs comme Tau ou MAP2. Cependant, contrairement aux autres MAPs, nous avons montré que MAP6 présente une dualité d'action sur le bout (-) des microtubules en diminuant et figeant très rapidement la dynamique de cette extrémité. Cette dualité pourrait ainsi conférer à MAP6 un rôle essentiel de nucléateur de microtubules en figeant l'extrémité (-) du microtubule et en favorisant la polymérisation et la stabilisation de l'extrémité (+). De plus, la protéine MAP6 est capable de modifier fortement la structure des microtubules. De part leur composition et leur rôle, les microtubules sont les éléments les plus rigides du cytosquelette et forment naturellement un tube creux linéaire. Or en présence de MAP6, les microtubules perdent cet aspect linéaire et adoptent une structure hélicoïdale (avec un pas d'environ 4,5 μm et une hauteur d'environ 1 μm) qui n'avait encore jamais été observée jusqu'à présent. La présence d'une telle population de microtubules dans la cellule pourrait ainsi apporter une certaine résistance mécanique ou encore permettre le maintien de l'architecture de l'axone. Enfin, nous avons montré que MAP6 peut aussi interagir de façon directe avec les filaments d'actines et les associer entre eux pour former des faisceaux. Dans les neurones, de nombreuses molécules ont été identifiées comme étant des régulateurs clés dans le « crosstalk » entre les filaments d'actines et les microtubules. L'interaction et la coordination entre les différents éléments du cytosquelette jouent un rôle essentiel dans la transmission et le relais du message synaptique. MAP6 pourrait être importante pour l'ensemble de ces mécanismes ce qui expliquerait les défauts de plasticité synaptique ainsi que les défauts cognitifs observés chez les souris KO MAP6.
