User-specific real-time registration and tracking applied to anatomy learning.
Modélisation anatomique utilisateur-spécifique et animation temps-réel : Application à l'apprentissage de l'anatomie
To ease the complex task of anatomy learning, there exist many ways to represent and structure anatomy : illustrations, books, cadaver dissections and 3d models. However, it is difficult to understand and analyse anatomy motion, which is essential for medicine students. We present the "Living Book of Anatomy" (LBA), an original and innovative tool to learn anatomy. For a specific user, we superimpose a 3d anatomical model (skin, skeleton, muscles and visceras) onto the user’s color map and we animate it following the user’s movements. We present a real-time mirror-like augmented reality (AR) system. A Kinect is used to capturebody motions.The first innovation of our work is the identification of the user’s body measurements to register our 3d anatomical model. We propose two different methods to register anatomy.The first one is real-time and use affine transformations attached to rigid positioned on each joint given by the Kinect body tracking skeleton in order to deform the 3d anatomical model using skinning to fit the user’s measurements.The second method needs a few minutes to register the anatomy and is divided in 3 parts : skin deformation (using Kinect body tracking skeleton and the Kinect partial point cloud), with it and strict anatomical rules we register the skeleton. Lastly we deformm the soft tissues to completly fill the space inbetween the registered skeleton and skin.Secondly, we want to capture realistically and in real-time the user’s motion. To do that we need to reproduce anatomical structure motion but it is a complex task due to the noisy and often partial Kinect data. We propose here the use of anatomical rules concerning body articulations (angular limits and degrees of freedom) to constraint Kinect captured motion in order to obtain/gain plausible motions. a kalman filter is used to smooth the obtaiined motion capture.Lastly, to embed visual style and interaction, we use a full body reproduction to show general knowledge on human anatomy and its differents joints. We also use a lower-limb as structure of interest to higlight specific anatomical phenomenon, as muscular activity.All these tools have been integrated in a working system detailed in this thesis.We validated our tool/system by presenting it as a live demo during different conferences and through user studies done with students and professionnals from different backgrounds
La complexité de l’anatomie fait de son apprentissage une tâche difficile. Au fil des années, différents supports de connaissances ont vu le jour dans le but de représenter et structurer l’anatomie : des dessins au tableau, aux livres d’anatomie, en passant par l’étape incontournable de la dissection, et des travaux pratiques sur maquettes 3d. Il est néanmoins difficile d’appréhenderla dimension dynamique de l’anatomie avec les outils d’apprentissage conventionnels ; connaissance qui est pourtant essentielle à la formation des médecins. A travers ces travaux de thèse nous proposons un système original et innovant pour l’apprentissage de l’anatomie intitulé « Living Book of Anatomy » (LBA). L’idée étant, pour un utilisateur donné, de superposer à sa propre image une maquette anatomique 3d (peau, squelette, muscles et viscères) et del’animer en mimant les mouvements de celui-ci. Nous parlons ici d’une application temps-réel de type « miroir augmenté ». Nous utilisons la Kinect comme capteur de mouvement.Le premier défi à relever est l’identification de caractéristiques morphologiques qui nous permettront de recaler notre maquette anatomique 3d sur l’utilisateur. Nous proposons ici deux technologies interchangeables en fonction des besoins. La première méthode, temps-réel, est basée sur l’utilisation de transformations affines attachées entre les repères positionnés à chaque articulation du squelette donné par la Kinect pour déformer la maquette 3d à l’aide de poids de skinning prédéfinis. La seconde méthode, plus couteuse en temps (de l’ordre de quelques minutes), se découpe en trois parties : dans un premier temps nous déformons la peau à l’aide de la position des articulations du squelette d’animation Kinect et du nuage de pointpartiel de l’utilisateur ; à partir de cela et de règles anatomiques strictes nous déformons le squelette ; pour finir nous déformons les tissus mous pour qu’ils comblent l’espace entre le squelette et la peau. Le second défi concerne la capture réaliste et temps-réel des mouvements utilisateurs. Reproduire le comportement des structures anatomiques est une tâche complexe due aux informations Kinect souvent partielles et très bruitées. Nous proposons ici l’utilisation de règles anatomiques concernant les articulations du corps (axes de rotation et butées articulaires) pour contraindre les mouvements donnés par la Kinect et obtenir des mouvements réalistes. Pour obtenir des mouvements fluides nous nous proposons d’utiliser des filtrages, notamment le filtre de Kalman. Le dernier défi concerne la dominante de retour visuel et d’interaction.Lors de ces travaux nous nous sommes tout particulièrement intéressés à un renducorps complet pour montrer le fonctionnement général du corps humain et de ces différentes articulations. Nous avons également choisi le membre inférieur comme structure anatomique d’intérêt avec pour but la mise en avant de phénomènes anatomiques spécifiques, comme l’activité musculaire.Les différents éléments ont été intégrés dans un système opérationnel présenté en détails dans ce manuscrit de thèse. Grâce à des expérimentations - avec des étudiants et des professionnels de différents domaines - et la présentation de ces travaux sous forme de démonstrations lors de différents congrès, nous avons validé cet outil
