Déterminants Psychosociaux et Culturels du Burnout Maternel et des Symptômes Dépressifs Périnataux - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Psychosocial and Cultural Determinants of Maternal Burnout and Perinatal Depressive Symptoms
Déborah Loyal
Whereas a happy motherhood is a collective aspiration, it is known that many women are reporting psychological distress during the perinatal period. Yet, women’s psychological health can not be considered regardless of their roles in society and norms associated. This research work aims to test a psychosocial and cultural model to understand adjustment disorder regarding motherhood (postpartum depressive symptoms and burnout). In a first study, various steps with different populations (N = 250, 22, 474, 249 and 231) have led to the validation in French of a scale assessing beliefs associated with the maternal role. Then, a longitudinal follow up was settled with women who were seen during late pregnancy and at 2 and 4 months postpartum (N = 129). This work has served to demonstrate the convergent, predictive and construct validity of maternal burnout. Furthermore, the impact of motherhood psychosocial and normative characteristics in the development of depressive and burnout symptoms have been explored. Finally, cluster analyses were conducted to identify more or less adaptive patterns regarding articulation of investment in motherhood and working life. This research work has opened research avenues regarding maternal burnout in the postpartum period and considerations of socio-normative aspects of the mothering role regarding prevention and care of those troubles.
Alors qu’une maternité heureuse est une aspiration collective, il est établi que de nombreuses femmes souffrent de détresse psychologique dans la période périnatale. Or, la santé psychologique des femmes ne peut être considérée indépendamment de leurs rôles au sein de la société et des normes qui y sont attachées. Ce travail de recherche vise à tester un modèle psychosocial et culturel de compréhension des troubles de l'adaptation à la maternité, (symptômes dépressifs postpartum et burnout). Dans une première étude, différentes étapes auprès de plusieurs populations (N = 250, 22, 474, 249 et 231) ont mené à la validation en langue française d’une échelle de mesure des croyances associées au rôle maternel. Dans un second temps, un suivi longitudinal a été mis en place auprès de femmes rencontrées en fin de grossesse puis à 2 et 4 mois postpartum (N = 129). Ces travaux ont permis d’établir la validité convergente, prédictive et de construit du concept de burnout maternel. Par ailleurs, le poids des caractéristiques psychosociales et normatives du rôle maternel dans le développement de symptômes dépressifs et de burnout a été exploré. Pour finir, des analyses en cluster ont permis de dégager des profils d’articulation, plus ou moins adaptatifs, entre investissement dans la maternité et dans la vie professionnelle. Ces travaux ouvrent des perspectives de recherche concernant le concept de burnout maternel dans la période postpartum et la prise en compte des aspects socio-normatifs du rôle maternel dans la prévention et la prise en charge de ces troubles.
Psychologie
LOYAL_DEBORAH_2017.pdf (2.8 Mo) Télécharger le fichier
tel-01687441 , version 1 (18-01-2018)
  • HAL Id : tel-01687441 , version 1
Déborah Loyal. Déterminants Psychosociaux et Culturels du Burnout Maternel et des Symptômes Dépressifs Périnataux. Psychologie. Université de Bordeaux, 2017. Français. ⟨NNT : 2017BORD0821⟩. ⟨tel-01687441⟩
1196 Consultations
2905 Téléchargements
