CARACTERISATION DE LA B-GLYCOSIDASE DE LA BLATTE PERIPLANETA AMERICANA : APPLICATION A LA VALORISATION DES GLYCOALCALOÏDES DE LA POMME DE TERRE EN DECOMPOSITION - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
CHARACTERIZATION OF BETA-GLUCOSIDASE FROM COCKROACH, PERIPLANETA : AMERICANA APPLICATION TO THE VALORIZATION OF GLYCOALCALOIDS FROM DECAYED POTATOES
Potato produce glycoalkaloids as most plants of Solanaceae family. The principal glycoalkaloids, α-chaconine and α-solanine are produced in greater quantities when potato tubers are exposed to light and are subject to deteriorations. These compounds are toxic and can represent a real danger for the consumer and the environment where they are discharged during their degradation. In this work, the estimation of glycoalkaloids in the flesh of different types of decayed potatoes usually found in different market places of Abidjan (Ivory Coast) was evaluated. The results showed that turned green and also sprouting or rotting potato flesh contain high amounts of toxic solanine and chaconine, exceeding by 2 to 5-fold the recommended limit. For safety consideration, these decayed potatoes should be systematically set aside. The accumulation of α-chaconine and solanine in potatoes can be seen as an attractive source of solanidine that is an important precursor for hormone synthesis and some pharmacologically active compounds. To this end, we proposed herein a simple chemo-enzymatic protocol comprising a partial acidic hydrolysis followed by an enzymatic treatment with the β-glycosidase from Periplaneta americana whose gene was isolated from a cDNA genomic library in order to detoxify these compounds and produce solanidine.
La pomme de terre produit des glycoalcaloïdes comme la plupart des Solanacées. Deux composés, en particulier, l’α-solanine et l’α-chaconine, sont produits en plus grande quantité lorsque le tubercule est exposé à la lumière et subit des dégradations. Ces molécules sont toxiques et peuvent représenter un danger pour le consommateur et des nuisances pour l’environnement. Dans le cadre de cette thèse, les teneurs en α-solanine et α-chaconine dans la chaire de pomme de terre verdie, en germination ou en décomposition retrouvées sur les marchés d’Abidjan (Côte d'Ivoire) ont été analysées. Les résultats ont montré que la chaire de ces pommes de terre contient des quantités élevées de ces deux composés, dépassant 2 à 5 fois la limite recommandée. Pour des raisons de sécurité sanitaire, ces pommes de terre doivent être proscrites de l’alimentation humaine. En revanche, la teneur élevée en glycoalcaloïdes dans ces pommes de terre représente une source de solanidine, un précurseur pour la synthèse d'hormones et de composés pharmacologiquement actifs, qui mérite d’être exploitée. Dans cet objectif, nous avons développé une méthode chimio-enzymatique simple, comprenant un traitement acide partiel suivi d’une hydrolyse enzymatique par la β-glycosidase de la blatte Periplaneta americana dont le gène a été isolé à partir d’une librairie génomique de cDNA afin de détoxifier ces composés et produire la solanidine.
2016KoffiYvonne.pdf (17.02 Mo) Télécharger le fichier
tel-01687832 , version 1 (18-01-2018)
  • HAL Id : tel-01687832 , version 1
Grokore Yvonne Koffi. CARACTERISATION DE LA B-GLYCOSIDASE DE LA BLATTE PERIPLANETA AMERICANA : APPLICATION A LA VALORISATION DES GLYCOALCALOÏDES DE LA POMME DE TERRE EN DECOMPOSITION. Microbiologie et Parasitologie. INSA de Toulouse, 2016. Français. ⟨NNT : 2016ISAT0040⟩. ⟨tel-01687832⟩
650 Consultations
188 Téléchargements
