28 3.4.1 Solution admissible, p.29 ,
Rewriting integer variables into zero-one variables: Some guidelines for the integer quadratic multi-knapsack problem, Soutif (30%), pp.299-314, 2007. ,
DOI : 10.1007/BF02942392
URL : https://hal.archives-ouvertes.fr/hal-00178949
Upper bounds for large scale integer quadratic multidimensional knapsack, Soutif (25%) and P. Tolla (5%), pp.146-154, 2007. ,
DOI : 10.1007/s10878-007-9105-1
URL : https://hal.archives-ouvertes.fr/hal-01125250
Energy-Efficient Downlink Resource Allocation, LTE Heterogeneous Networks ,
A branch-and-price algorithm for the Consistent Vehicle Routing Problem CONFÉRENCESCONF´ CONFÉRENCES INTERNATIONALES AVEC ACTES 1, Brotcorne : Mathematical Programming with Stochastic Equilibrium Constraints applied to Last-mile Delivery Services, International Network Optimization Conference, 2015. ,
Last-mile delivery services design under stochastic user, INFORMS Transportation Science and Logistics Society Workshop, 2015. ,
Brotcorne A Game Theoretical Model for Freight Transportation invited paper, International Conference on Analytic and Stochastic Modelling Techniques and Applications (ASMTA), p.2012 ,
Unsupervised Concept Annotation using Latent Dirichlet Allocation and Segmental Methods, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01314555
Concept Discovery for Language Understanding in an Information-Query Dialogue, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-01314539
A t-linearization to exactly solve 0-1 quadratic knapsack problems, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01320150
On a class of periodic scheduling problems: Models, lower bounds and heuristics, 2008 International Multiconference on Computer Science and Information Technology, pp.899-906, 2008. ,
DOI : 10.1109/IMCSIT.2008.4747349
URL : https://hal.archives-ouvertes.fr/hal-01318570
A branch-and-bound algorithm to solve large scale integer quadratic multidimensional knapsack problems, LNCS, vol.4362, pp.456-464, 2007. ,
DOI : 10.1007/978-3-540-69507-3_39
Integer quadratic knapsack problems, chapter 9 of Combinatorial Optimization and Theoretical Computer Science, pp.267-295, 2010. ,
An Upper Bound for the Integer Quadratic Multi-knapsack Problem, chapter 19 of Combinatorial optimization -Theoretical computer science : interfaces and perspectives, pp.495-505, 2008. ,
Lesprobì emes de sac-` a-dos quadratiques en variablesentì eres, Optimisation combinatoire, Hermès-Sciences, vol.4, pp.191-211, 2007. ,
Programmation Quadratique en Entiers : un majorant pour le multisac-` a-dos quadratique séparable entier, Annales du Lamsade, issue.4, pp.411-422, 2007. ,
Two np-complete problems in nonnegative integer programming, 1975. ,
Best network flow bounds for the quadratic knapsack problem, Lecture Notes in Mathematics, vol.5, pp.226-235, 1986. ,
DOI : 10.1002/net.3230050405
Knapsack Problems : Algorithms and Computer Implementations, 1990. ,
Capital Budgeting of Interrelated Projects: Survey and Synthesis, Management Science, vol.12, issue.7, pp.485-516, 1966. ,
DOI : 10.1287/mnsc.12.7.485
Branch-and-Bound Strategies for Dynamic Programming, Operations Research, vol.24, issue.4, pp.611-627, 1976. ,
DOI : 10.1287/opre.24.4.611
URL : http://dspace.mit.edu/bitstream/1721.1/46916/1/branchandboundstx00mori.pdf
An Algorithm for Nonlinear Knapsack Problems, Management Science, vol.22, issue.10, pp.1147-1158, 1976. ,
DOI : 10.1287/mnsc.22.10.1147
An Integer Programming Algorithm for Portfolio Selection, Management Science, vol.20, issue.10, pp.1376-1384, 1974. ,
DOI : 10.1287/mnsc.20.10.1376
Portfolio selection, Journal of Finance, vol.7, issue.1, pp.77-91, 1952. ,
OPTIMAL LOT SOLUTION TO CARDINALITY CONSTRAINED MEAN-VARIANCE FORMULATION FOR PORTFOLIO SELECTION, Mathematical Finance, vol.44, issue.1, pp.83-101, 2006. ,
DOI : 10.1007/s002450010003
Heuristic and exact solution method for convex nonlinear knapsack problem, CEPR Discussion Pape, vol.4022, 2003. ,
Optimal solutions for unrelated parallel machines scheduling problems using convex quadratic reformulations, European Journal of Operational Research, vol.201, issue.3, pp.729-736, 2010. ,
DOI : 10.1016/j.ejor.2009.03.049
Convex quadratic and semidefinite programming relaxations in scheduling, Journal of the ACM, vol.48, issue.2, pp.206-242, 2001. ,
DOI : 10.1145/375827.375840
URL : http://www.core.ucl.ac.be/services/psfiles/dp9963.pdf
The quadratic knapsack problem???a survey, Discrete Applied Mathematics, vol.155, issue.5, pp.623-648, 2007. ,
DOI : 10.1016/j.dam.2006.08.007
URL : https://doi.org/10.1016/j.dam.2006.08.007
Quadratic knapsack problems, Mathematical Programming Study, vol.12, pp.132-149, 1980. ,
DOI : 10.1007/BFb0120892
Exact Solution of the Quadratic Knapsack Problem, INFORMS Journal on Computing, vol.11, issue.2, pp.125-137, 1999. ,
DOI : 10.1287/ijoc.11.2.125
Lagrangean methods for the 0???1 Quadratic Knapsack Problem, European Journal of Operational Research, vol.92, issue.2, pp.326-341, 1996. ,
DOI : 10.1016/0377-2217(94)00286-X
An exact method based on Lagrangian decomposition for the 0???1 quadratic knapsack problem, European Journal of Operational Research, vol.157, issue.3, pp.565-575, 2004. ,
DOI : 10.1016/S0377-2217(03)00244-3
URL : https://hal.archives-ouvertes.fr/hal-01124918
Reoptimization in Lagrangian methods for the 0???1 quadratic knapsack problem, Computers & Operations Research, vol.39, issue.1, pp.12-18, 2012. ,
DOI : 10.1016/j.cor.2010.10.027
Solution of Large Quadratic Knapsack Problems Through Aggressive Reduction, INFORMS Journal on Computing, vol.19, issue.2, pp.280-290, 2007. ,
DOI : 10.1287/ijoc.1050.0172
Improved Linear Integer Programming Formulations of Nonlinear Integer Problems, Management Science, vol.22, issue.4, pp.455-460, 1975. ,
DOI : 10.1287/mnsc.22.4.455
A reformulation technique for solving discrete and continuous non convex problems, 1999. ,
DOI : 10.1007/978-1-4757-4388-3
Decomposition and linearization for 0-1 quadratic programming, Annals of Operations Research, vol.99, issue.1/4, pp.79-93, 2000. ,
DOI : 10.1023/A:1019236832495
URL : https://hal.archives-ouvertes.fr/hal-01124548
A new linearization technique for multi-quadratic 0???1 programming problems, Operations Research Letters, vol.32, issue.6, pp.517-522, 2004. ,
DOI : 10.1016/j.orl.2004.03.005
Nonstandard semidefinite bounds for solving exactly 0-1 quadratic problems, EURO XXV, 2012. ,
Algorithmes combinatoires et relaxations par programmation linéaire et semidéfinie. applicationàplication`plicationà la résolution deprobì emes quadratiques et d'optimisation dans les graphes, 2006. ,
Nonlinear 0???1 programming: I. Linearization techniques, Mathematical Programming, pp.1-21, 1984. ,
DOI : 10.1287/mnsc.18.6.B328
Nonlinear 0???1 programming: II. Dominance relations and algorithms, Mathematical Programming, pp.22-45, 1984. ,
???Miniaturized??? Linearizations for Quadratic 0/1 Problems, Annals of Operations Research, vol.79, issue.1, pp.235-261, 2005. ,
DOI : 10.1002/j.1538-7305.1970.tb01770.x
A linearization framework for unconstrained quadratic (0-1) problems, Discrete Applied Mathematics, vol.157, issue.6, pp.1255-1266, 2009. ,
DOI : 10.1016/j.dam.2008.01.028
URL : https://hal.archives-ouvertes.fr/hal-01317480
Application de l'algèbre de boole en recherche opérationelle. Revue Française de la Recherche Opérationelle, pp.17-25, 1960. ,
Improved compact linearizations for the unconstrained quadratic 0???1 minimization problem, Discrete Applied Mathematics, vol.157, issue.6, pp.1267-1290, 2009. ,
DOI : 10.1016/j.dam.2007.12.008
Comparisons and enhancement strategies for linearizing mixed 0-1 quadratic programs, Discrete Optimization, vol.1, issue.2, pp.99-120, 2004. ,
DOI : 10.1016/j.disopt.2004.03.006
URL : https://doi.org/10.1016/j.disopt.2004.03.006
Improving the performance of standard solvers for quadratic 0-1 programs by a tight convex reformulation: The QCR method, Discrete Applied Mathematics, vol.157, issue.6, pp.1185-1197, 2009. ,
DOI : 10.1016/j.dam.2007.12.007
URL : https://hal.archives-ouvertes.fr/hal-01125253
Compact linearization for binary quadratic problems, 4OR, vol.68, issue.10, pp.231-245, 2007. ,
DOI : 10.1007/978-1-4613-1379-3
A Branch and Bound Algorithm for Integer Quadratic Knapsack Problems, ORSA Journal on Computing, vol.7, issue.1, pp.109-116, 1995. ,
DOI : 10.1287/ijoc.7.1.109
A surrogate relaxation based algorithm for a general quadratic multi-dimensional knapsack problem, Operations Research Letters, vol.7, issue.5, pp.253-257, 1988. ,
DOI : 10.1016/0167-6377(88)90041-7
Exact solution method to solve large scale integer quadratic multidimensional knapsack problems, Journal of Combinatorial Optimization, vol.4, issue.3, pp.157-167, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00917814
HEURISTIC AND EXACT SOLUTION METHOD FOR CONVEX NONLINEAR KNAPSACK PROBLEM, Asia-Pacific Journal of Operational Research, vol.74, issue.05 ,
DOI : 10.1016/j.ijpe.2008.10.003
An approximate dynamic programming approach to convex quadratic knapsack problems, Computers & Operations Research, vol.33, issue.3, pp.660-673, 2006. ,
DOI : 10.1016/j.cor.2004.07.012
Simple solution methods for separable mixed linear and quadratic knapsack problem, Applied Mathematical Modelling, vol.36, issue.7, pp.3245-3526, 2012. ,
DOI : 10.1016/j.apm.2011.10.017
URL : https://doi.org/10.1016/j.apm.2011.10.017
An enumerative algorithm framework for a class of nonlinear integer programming problems, European Journal of Operational Research, vol.101, issue.1, pp.104-121, 1997. ,
DOI : 10.1016/S0377-2217(96)00164-6
Convex quadratic programming with one constraint and bounded variables, Mathematical Programming, pp.90-104, 1986. ,
DOI : 10.1515/9781400873173
On the solution of concave knapsack problems, Mathematical Programming, pp.397-411, 1991. ,
DOI : 10.1007/BF01588800
A note on adapting methods for continuous global optimization to the discrete case, Annals of Operations Research, vol.10, issue.1, pp.243-252, 1990. ,
DOI : 10.1002/nav.3800260405
An algorithm for indefinite integer quadratic programming, Computers & Mathematics with Applications, vol.21, issue.6-7, pp.99-106, 1991. ,
DOI : 10.1016/0898-1221(91)90164-Y
URL : https://doi.org/10.1016/0898-1221(91)90164-y
Global Optimization : Deterministic Approaches, 1990. ,
An efficient compact quadratic convex reformulation for general integer quadratic programs, Computational Optimization and Applications, vol.32, issue.10, pp.141-162, 2013. ,
DOI : 10.1007/978-1-4757-3532-1
URL : https://hal.archives-ouvertes.fr/hal-01126098
Separable Relaxation for Nonconvex Quadratic Integer Programming: Integer Diagonalization Approach, Journal of Optimization Theory and Applications, vol.28, issue.2, pp.463-489, 2010. ,
DOI : 10.1017/CBO9780511810817
Reducing the number of variables in integer quadratic programming problem, Applied Mathematical Modelling, vol.34, pp.424-436, 2010. ,
Two-stage quadratic integer programs with stochastic right-hand sides, Mathematical Programming, vol.20, issue.2, pp.121-158, 2012. ,
DOI : 10.1007/BF01589344
The Algebraic Eigenvalue Problem, 1965. ,
Upper bounds for large scale integer quadratic multidimensional knapsack, International Journal of Operations Research, vol.4, issue.3, pp.146-154, 2007. ,
A genetic algorithm for the multidimensional knapsack problem, Journal of Heuristics, vol.4, issue.1, pp.63-86, 1998. ,
DOI : 10.1023/A:1009642405419
A new upper bound for the 0-1 quadratic knapsack problem, European Journal of Operational Research, vol.112, issue.3, pp.664-672, 1999. ,
DOI : 10.1016/S0377-2217(97)00414-1
URL : https://hal.archives-ouvertes.fr/hal-01124497
Solution of large quadratic knapsack problems through agressive reduction, INFORMS Journal on Computing, 2006. ,
Linear programming for the 0???1 quadratic knapsack problem, European Journal of Operational Research, vol.92, issue.2, pp.310-325, 1996. ,
DOI : 10.1016/0377-2217(94)00229-0
URL : https://hal.archives-ouvertes.fr/hal-01124499
Constraint and linear programming : Using reduced costs for solving the zero/one multiple knapsack problem, International Conference on Constraint Programming , Proceedings of the workshop on Cooperative Solvers in Constraint Programming, pp.87-98, 2001. ,
Expreriments for qkp. website of the CEDRIC CNAM Paris, 2001. ,
A framework of computational systems and optimization models for the prevention and combat of dengue, 17th IFORS Triennial Conference, 2005. ,
Vehicle minimization for periodic deliveries, European Journal of Operational Research, vol.165, issue.3, pp.668-684, 2005. ,
DOI : 10.1016/j.ejor.2003.09.036
Search and screening, 1980. ,
Search allocation game, European Journal of Operational Research, vol.172, issue.1, pp.101-119, 2006. ,
DOI : 10.1016/j.ejor.2004.10.003
Synchronization of inventory and transportation under flexible vehicle constraint : A heuristics approach using sliding windows and hierarchical tree structure, Operations Research, vol.28, issue.6, pp.1275-1289, 1980. ,
Optimal Search for a Moving Target in Discrete Time and Space, Operations Research, vol.28, issue.6, pp.824-836, 2009. ,
DOI : 10.1287/opre.28.6.1275
Parcel delivery and urban logistics-changes in urban courier, express and parcel services : the french case, 13th World Conference on Transport Research, 2013. ,
URL : https://hal.archives-ouvertes.fr/halshs-00853932
Economic efficiency and social feasibility in the regulation of road transport externalities, 1996. ,
Bilevel programming: A survey, 4OR, vol.3, issue.2, pp.87-107, 2005. ,
DOI : 10.1007/s10288-005-0071-0
Decentralized optimization of last-mile delivery services with non-cooperative bounded rational customers, Annals of Operations Research, vol.21, issue.6, 2015. ,
DOI : 10.1680/ipeds.1952.11362
URL : https://hal.archives-ouvertes.fr/hal-01053487
Discrete choice analysis : Theory and application to travel demand, 1985. ,
Urban transportation networks : Equilibrium analysis with mathematical programming methods, 1985. ,
Discrete choice theory of product differentiation, 1992. ,
Quantal choice analysis : A survey, Annals of Economic and Social Measurement, vol.5, pp.363-370, 1976. ,
Sensitivity analysis for queuing equilibrium network flow and its application to traffic control, Mathematical and computer modeling, vol.22, issue.4, pp.247-258, 1995. ,
Fundamental trade-offs on green wireless networks, IEEE Communications Magazine, vol.49, issue.6, pp.30-37, 2011. ,
DOI : 10.1109/MCOM.2011.5783982
Energy- and Spectral-Efficiency Tradeoff in Downlink OFDMA Networks, IEEE Transactions on Wireless Communications, vol.10, issue.11, pp.3874-3886, 2011. ,
DOI : 10.1109/TWC.2011.091411.110249
Energy- and Spectral-Efficiency Tradeoff for Distributed Antenna Systems with Proportional Fairness, IEEE Journal on Selected Areas in Communications, vol.31, issue.5, pp.31894-902, 2013. ,
DOI : 10.1109/JSAC.2013.130508
URL : http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.352.4459&rep=rep1&type=pdf
Energy-efficient link adaptation in frequency-selective channels, IEEE Transactions on Communications, vol.58, issue.2, pp.545-554, 2010. ,
DOI : 10.1109/TCOMM.2010.02.080587
Framework for Link-Level Energy Efficiency Optimization with Informed Transmitter, IEEE Transactions on Wireless Communications, vol.11, issue.8, pp.2946-2957, 2012. ,
DOI : 10.1109/TWC.2012.060412.111829
URL : http://arxiv.org/pdf/1110.1990
On Nonlinear Fractional Programming, Management Science, vol.13, issue.7, pp.492-498, 1967. ,
DOI : 10.1287/mnsc.13.7.492
Non-convex mixed-integer nonlinear programming: A survey, Surveys in Operations Research and Management Science, vol.17, issue.2, pp.97-106, 2012. ,
DOI : 10.1016/j.sorms.2012.08.001
URL : http://www.lancaster.ac.uk/staff/letchfoa/articles/minlp-survey.pdf
An algorithmic framework for convex mixed integer nonlinear programs. Discrete Optimization, pp.186-204, 2012. ,
DOI : 10.1016/j.disopt.2006.10.011
URL : https://hal.archives-ouvertes.fr/hal-00421753
Convex reformulations of integer quadratically constrained problems, ISMP (21th International Symposium of Mathematical programming), p.1, 2012. ,
DOI : 10.1007/s10107-015-0921-2
URL : https://hal.archives-ouvertes.fr/hal-01126039
Quadratic resource allocation with generalized upper bounds, Operations Research Letters, vol.20, issue.2, pp.51-57, 1997. ,
DOI : 10.1016/S0167-6377(96)00039-9
Reformulation techniques in mathematical programming. HabilitationàHabilitation`Habilitationà Diriger des Recherches, 2007. ,
DOI : 10.1016/j.dam.2008.10.016
URL : https://hal.archives-ouvertes.fr/hal-00163563
