An integrabilist approach of out-of-equilibrium statistical physics models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Approche intégrabiliste des modèles de physique statistique hors d'équilibre
Although statistical physics has been very successful to describe physical systems at thermal equilibrium (thanks to the Boltzmann distribution, which reflects the maximization of the entropy, and allows one to construct in a systematic way thermodynamic potentials), it remains elusive to provide an efficient framework to study phenomena that are out-of-equilibrium, i.e displaying non vanishing current of physical quantities (energy, charge, particles...).The goal of the thesis is to describe such systems with very simple models which retain nevertheless their main physical features. The models consist in particles evolving randomly on a one dimensional lattice connected to reservoirs and subject to hard-core repulsion. The challenge lies in computing exactly the stationary state of the model, especially the particle current, its fluctuations and more precisely its large deviation function (which is expected to play the role of an out-of-equilibrium thermodynamic potential).In the first part of the thesis we construct models, called integrable, in which we can perform exact computations of physical quantities. We introduce several new out-of-equilibrium models that are obtained by solving, in specific cases, the Yang-Baxter equation and the reflection equation. We provide new algebraic structures which allow us to construct the solutions through a Baxterisation procedure.In the second part of the thesis we compute exactly the stationary state of these models using a matrix ansatz. We shed light on the connection between this technique and the integrability of the model by pointing out two key relations: the Zamolodchikov-Faddeev relation and the Ghoshal-Zamolodchikov relation. The integrability is also exploited, through the quantum Knizhnik-Zamolodchikov equations, to compute the fluctuations of the particles current, unrevealing connections with the theory of symmetric polynomials (the Koornwinder polynomials in particular).Finally the last part of the thesis deals with the hydrodynamic limit of the models, i.e when the lattice spacing tends to 0 and the number of particles tends to infinity. The exact results obtained for a finite size system allow us to check the validity of the predictions of the macroscopic fluctuations theory (concerning the fluctuations of the current and the density profile in the stationary state) and to extend the theory to systems with several species of particles.
Malgré son indéniable succès pour décrire les systèmes physiques à l'équilibre thermodynamique (grâce à la distribution de Boltzmann, reflétant la maximisation de l'entropie, et permettant la construction systématique de potentiels thermodynamiques), la physique statistique n'offre pas de cadre général pour étudier les phénomènes hors d'équilibre, i.e dans lesquels on observe un courant moyen non nul d'une grandeur physique (énergie, charge, particules...).L'objectif de la thèse est de décrire de tels systèmes à l'aide de modèles très simples mais qui retranscrivent néanmoins les principales caractéristiques physiques de ceux-ci. Ces modèles sont constitués de particules se déplacant de manière aléatoire sur un réseau unidimensionnel connecté à des réservoirs et soumises à un principe d'exclusion. L'enjeu est de calculer exactement l'état stationnaire du modèle, notamment le courant de particules, ses fluctuations et plus particulièrement sa fonction de grande déviation (qui pourrait jouer le rôle d'un potentiel thermodynamique hors d'équilibre).Une première partie de la thèse vise à construire des modèles dits intégrables, dans lesquels il est possible de mener à bien des calculs exacts de quantités physiques. De nouveaux modèles hors d'équilibre sont proposés grâce à la résolution dans des cas particuliers de l'équation de Yang-Baxter et de l'équation de réflexion. De nouvelles structures algébriques permettant la construction de ces solutions par une procédure de Baxtérisation sont introduites.Une deuxième partie de la thèse consiste à calculer exactement l'état stationnaire de tels modèles en utilisant l'ansatz matriciel. Les liens entre cette technique et l'intégrabilité du modèle ont été mis en lumière au travers de deux relations clef: la relation de Zamolodchikov-Faddeev et la relation de Ghoshal-Zamolodchikov. L'intégrabilité a aussi été exploitée au travers des equations de Knizhnik-Zamolodchikov quantiques, afin de calculer les fluctuations du courant, mettant en lumière des connexions avec la théorie despolynômes symétriques (polynômes de Koornwinder en particulier).Enfin une dernière partie de la thèse porte sur la limite hydrodynamique des modèles étudiés, i.e lorsque la maille du réseau tend vers zero et que le nombre de constituants du système tend vers l'infini. Les résultats exacts obtenus sur les modèles à taille finie ont permis de vérifier les prédictions de la théorie des fluctuations macroscopiques (concernant les fluctuations du courant et du profil de densité dans l'état stationnaire) et de l'étendre à des modèles comprenant plusieurs espèces de particules.
VANICAT_2017_diffusion.pdf (1.93 Mo) Télécharger le fichier
tel-01688587 , version 1 (19-01-2018)
  • HAL Id : tel-01688587 , version 1
Matthieu Vanicat. An integrabilist approach of out-of-equilibrium statistical physics models. Mathematical Physics [math-ph]. Université Grenoble Alpes, 2017. English. ⟨NNT : 2017GREAY029⟩. ⟨tel-01688587⟩
309 Consultations
315 Téléchargements
