Conception neutronique de configurations expérimentales à forte adaptation spectrale en réacteur de puissance nulle pour des applications multi-filières Gen-II,III & IV - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Neutronics design of zero power reactor experimental configurations with high spectral adaptation for Gen-II, III & IV reactors applications
This PhD thesis focuses on the neutronics design of experimental configurations to improve knowledge on neutronical parameters, in particular nuclear data in enlarged spectrum energy domains, in the future Zero Power Reactor ZEPHYR. Its awaited high spectral flexibility faces a major challenge due to the presence of a peripheral water zone. Answering the needs of current and future electronuclear reactor fleet requires a faithful reproduction of their neutronical characteristics in the measurement zone. Then, the issue is to understand how to design an efficient spectral adaptation between the periphery and the experimental zone, and to apply it on Generations II, III and IV dedicated configurations.As a first step, fast-thermal coupled cores were studied in order to support the development of Generation IV fast reactors. Such configurations had been previously realized, but our work intends to provide a rigorous design approach to insure the neutronical independence of the fast central zone regarding the peripheral thermal zone. An optimized configuration has been defined; some adaptations allow to target either absorption or scattering cross-sections during dedicated sample oscillation campaigns. Preliminary safety studies associated to the safe operation of this optimized configuration have also been realized in order to justify its practical feasibility.A second step used the spectral adaptation principles to target the 10 eV to 10 keV energy domain. Even though this domain is not directly related to a concept of reactor, it suffers from a lack of dedicated experiments despite several applications, in particular for criticality/safety issues.Finally, the sensitivity calculations of reactivity effects to nuclear data measured in the centers of these configurations still remains an unresolved problem to which this PhD thesis brings a contribution thanks to a theoretical modelling.
Les travaux réalisés au cours de cette thèse portent sur la conception neutronique de configurations expérimentale destinées à améliorer la connaissance de paramètres neutroniques, en particulier les données nucléaires dans une gamme de spectres neutroniques élargie, dans le futur réacteur de puissance nulle ZEPHYR. La grande flexibilité expérimentale attendue de ce réacteur présente un défi majeur lié à la présence obligatoire d’une zone en eau périphérique. Or, répondre aux besoins des réacteurs électronucléaires nécessite de reproduire fidèlement leurs caractéristiques neutroniques dans les zones de mesure. L’enjeu est alors de comprendre puis réaliser une adaptation spectrale efficace entre la périphérie et la zone de mesure, et de l’appliquer pour des configurations dédiées aux réacteurs de Générations II, III et IV.Dans un premier temps les couplages thermique-rapides ont été étudiés, stimulés par le développement des réacteurs rapides de Génération IV. De telles configurations ayant été réalisées par le passé, le travail réalisé a visé à produire une démarche rigoureuse de conception permettant de s’assurer de l’indépendance neutronique de la zone centrale rapide vis-à-vis de la zone thermique périphérique. Une configuration optimisée a pu être définie et des déclinaisons permettent de cibler préférentiellement les sections efficaces d’absorption ou de diffusion lors de mesures d’oscillations d’échantillons dans un canal expérimental dédié, situé au centre du massif. Des premières études relatives à la sûreté de cette configuration optimisée ont également été réalisées afin de justifier sa faisabilité pratique.Dans un second temps, les principes d’adaptation spectrale sont appliqués pour cibler le domaine énergétique entre 10 eV et 10 keV. Ce domaine ne vise pas un soutien direct à un concept de réacteur mais à pallier au manque de mesures dans cette zone, notamment pour les aspects de sûreté/criticité.Enfin, l’étude de sensibilité aux données nucléaires des effets en réactivité mesurés au centre de ces configurations reste un problème ouvert auquel cette thèse apporte une contribution au travers d’une modélisation théorique.
ROS_2017_archivage.pdf (8.13 Mo) Télécharger le fichier
tel-01689821 , version 1 (22-01-2018)
  • HAL Id : tel-01689821 , version 1
Paul Ros. Conception neutronique de configurations expérimentales à forte adaptation spectrale en réacteur de puissance nulle pour des applications multi-filières Gen-II,III & IV. Micro et nanotechnologies/Microélectronique. Université Grenoble Alpes, 2017. Français. ⟨NNT : 2017GREAI045⟩. ⟨tel-01689821⟩
Collections
CEA UGA STAR DEN
195 Consultations
667 Téléchargements
