Modélisation de l'environnement d'un moustique vecteur de maladies : l'exemple d'Aedes aegypti à Delhi (Inde) et Bangkok (Thaïlande) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Modelisation of the environment of a diseases vector mosquito : the example of Aedes aegypti in Delhi (India) and Bangkok (Thailand)
Aedes aegypti is the main vector of dengue and Zika virus. Surveillance and vector control are frontline weapons in the battle against arboviruses transmitted by this mosquito. In this framework, the following thesis introduces a conceptual model (MODE) which can be used to recreate in silico the dynamical environment of Aedes aegypti at scales that match the ones at which vector control campaigns are organised (city scale - MODE-macro) and performed (neighbourhood scale - MODE-micro). The environment thus generated can be integrated with an agent-based model to simulate dengue or Zika complex pathogenic systems (environment - vector - host - virus) and can be used to map the environmental hazard of the vectorial risk in a city. The conceptual model MODE is based on a phenomenological approach that is transferable in time and space : it can be applied in different urban contexts, at different periods of time and at different scales. In order to ensure their spatio-temporal genericity, the computer models MODE-micro (neighbourhood scale) and MODE-macro (city scale) have been implemented for the purpose of generating dynamical environments using open or easily accessible data. In this thesis, MODE's potentials were assessed in Delhi (India), and Bangkok (Thailand).Knowledge resulting from the study of the dynamic, multifactorial and non-linear relationships between the environment and the vector should lead to the improvement of vector surveillance and control strategies.
Aedes aegypti est le vecteur principal de la dengue et du virus Zika. La surveillance et le contrôle vectoriels constituent des armes de première ligne pour lutter contre les arboviroses transmises par ce moustique. Dans ce cadre, cette thèse propose un modèle conceptuel (MODE) qui permet de reproduire in silico l'environnement dynamique d'Aedes aegypti aux échelles auxquelles sont organisées (échelle de la ville - MODE-macro) et menées (échelle du quartier -- MODE-micro) les campagnes de lutte anti-vectorielles. L'environnement ainsi généré peut (1) être intégré à un modèle à base d'agents qui permet alors de simuler le système pathogène complexe de la dengue ou du Zika (environnement - vecteur - hôte - virus) et (2) être utilisé pour cartographier l'aléa environnemental du risque vectoriel dans la ville. Le modèle conceptuel MODE repose sur une approche phénoménologique transposable dans le temps et dans l'espace : il peut être appliqué dans différents contextes urbains, à différentes périodes et à différentes échelles. Afin de garantir sa généricité spatio-temporelle, les modèles informatiques MODE-micro (échelle du quartier) et MODE-macro (échelle de la ville) ont été implémentés dans le but de générer des environnements dynamiques à partir de données libres ou aisément accessibles. Dans ce travail, les potentialités de MODE ont été évaluées à Delhi (Inde) et Bangkok (Thaïlande). Les connaissances issues de l'étude des relations dynamiques, multifactorielles et non-linéaires entre l’environnement et le vecteur devraient permettre d’améliorer les stratégies de surveillance et de contrôle.
these_renaud_misslin.pdf (45.47 Mo) Télécharger le fichier
tel-01690559 , version 1 (23-01-2018)
  • HAL Id : tel-01690559 , version 1
Renaud Misslin. Modélisation de l'environnement d'un moustique vecteur de maladies : l'exemple d'Aedes aegypti à Delhi (Inde) et Bangkok (Thaïlande). Géographie. Normandie Université, 2017. Français. ⟨NNT : 2017NORMR031⟩. ⟨tel-01690559⟩
421 Consultations
125 Téléchargements
