Contribution of the atom probe tomography to the structural and magnetic study of the magnetic 6H-SiC semiconductor implanted with iron : towards a magnetic semiconductor at room temperature
Apport de la sonde atomique tomographique dans l'étude structurale et magnétique du semi-conducteur magnétique 6H-SiC implanté avec du fer : vers un semi-conducteur magnétique à température ambiante
Great hopes are placed on diluted magnetic semiconductors (DMS) for new components of spintronics. The challenge is to develop materials with both semiconducting and ferromagnetic properties. The aim of this work is to carry out a detailed nanostructural and magnetic study of the Fe: SiC candidate promising system to become a magnetic semiconductor diluted at room temperature. However, the magnetic properties observed in (6H-SiC) implanted with transition metals (TM) depend strongly on the material microstructure (content and nature of the dopant, precipitation of the dopant, etc.). In order to understand all the nanostructural and magnetic mechanisms, we studied the Fe: SiC system at the atomic scale using atom probe tomography (APT) and Mössbauer spectrometry. p and n single crystalline 6H-SiC near (0001)-oriented samples were submitted to multi-step implantations with 56Fe and 57Fe ions at different energies and fluences leading to an iron concentration (Cat =6 and 4%) at a depth between 20 nm and 120 nm from the sample surface. In this work, we were able to follow the effect of the nanostructure of the Fe: SiC system as a function of the iron concentration and the temperatures of implantations and annealing. We have established new results: nature and size of the nanoparticles, precise evaluation of the number of iron atoms diluted in the SiC matrix. The ferromagnetic and paramagnetic contributions are identified and clearly explained by the coupling of experimental techniques such as APT, Mössbauer spectrometry, SQUID (Superconducting Quantum Interference Device) magnetometry. We were able to put the material in optimal conditions for obtaining a DMS at room temperature. Indeed, the implanted samples (4% Fe) at 380°C more than 90% Fe atoms were distributed homogeneously. These Fe atoms are the main source of the ferromagnetic properties measured by SQUID and Mössbauer spectrometry at 300 K. These experimental results highlight the possibility of obtaining a new (DMS) at room temperature.
Dans la réalisation de nouveaux composants innovants de la spintronique, de grands espoirs sont placés sur les semi-conducteurs magnétiques dilués (DMS). L’enjeu technologique est de développer des matériaux ayant à la fois des propriétés semi-conductrices et ferromagnétiques. Le but de ce travail est de réaliser une étude nanostructurale et magnétique détaillée du système Fe :SiC candidat prometteur pour devenir un semi-conducteur magnétique dilué à température ambiante. Cependant les propriétés magnétiques du matériau (6H-SiC) implanté avec des métaux de transitions (MT) dépendent fortement de sa microstructure (concentration et nature du dopant, précipitation du dopant…). Afin d’appréhender l’ensemble des propriétés nanostructurales et magnétiques, nous avons étudié le système Fe :SiC à l’échelle de l’atome en utilisant la sonde atomique tomographique (SAT) couplée à la spectrométrie Mössbauer 57Fe. Des monocristaux 6H-SiC (0001) de type p et n (~10+18/cm3) ont été multi-implantés en 56Fe et 57Fe à différentes énergies et différentes fluences conduisant à une concentration atomique de (6% et 4%) de 20 à 120 nm de la surface. Dans le cadre de ce travail, nous avons pu suivre l’effet de la nanostructure du système Fe :SiC en fonction de la concentration de fer et des températures d’implantation et de recuit. Nous avons établi de nouveaux résultats : nature et dimension des nanoparticules, évaluation précise du nombre d’atomes de fer dilué dans la matrice SiC. Les différentes contributions ferromagnétiques et paramagnétiques sont identifiées et clairement expliquées grâce au couplage de techniques expérimentales comme la SAT, la spectrométrie Mössbauer, la magnétométrie SQUID (Superconducting Quantum Interference Device). Nous avons réussi à déterminer des conditions optimales pour l’obtention d’un DMS à température ambiante. En effet dans les échantillons implantés 4% Fe à 380°C, plus de 90% des atomes de Fe sont dilués. Ces atomes de Fe dilués contribuent majoritairement aux propriétés ferromagnétiques mesurées par SQUID et par spectrométrie Mössbauer à 300 K. Ces différents résultats expérimentaux mettent en lumière la possibilité de réalisation d’un nouveau (DMS) à température ambiante
