An in situ kinetic investigation of the selective dissolution mechanism of Cu alloys - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Une étude cinétique in situ du mécanisme de dissolution sélective des alliages de Cu
The selective dissolution mechanisms of Cu alloys in tap water and perspiration solution were investigated. Atomic emission spectroelectrochemistry (AESEC) was used to obtain the elemental dissolution kinetics. The first part of the thesis focused on the dissolution mechanism of Cu. Most Cu(II) species are soluble and are released into tap water, leaving behind a Cu2O film on the surface. A kinetic analysis suggests that the dissolution mechanism involves simultaneous Cu dissolution and film formation. The second part investigated the dissolution behavior of Cu-42Zn and Cu-21Zn-3Si-P. A two-stage dissolution process of dezincification was proposed: a first stage of a rapid growth of the dezincified layer and a second stage where the growth of dezincified layer was much slower. The third part concentrated on the effect of Zn content on the dissolution of Cu-Zn alloys, by investigating the dissolution behavior of alloys with various Zn content (0-45 wt%). The two-stage dissolution mechanism was further clarified. For α phase: an initial stage in which Cu and Zn are oxidized congruently, but only Zn2+ was released into water, Cu forming a Cu2O film, and a second stage where Cu was released into water in the form of Cu2+. For β' phase, the second stage is the same to the initial stage. The increase of Zn content in the alloy results in a time extension of the initial stage and retard Cu2+ release. The final part focused on the effect of Sn on Cu release from Cu-Sn alloys. The enhanced effect of Sn on Cu release was identified. However, the increase of Sn content didn’t monotonically increase the Cu release efficacy of Cu-Sn alloys, which was due to the passivity of Sn.
Les mécanismes de dissolution sélective des alliages de Cu dans l'eau du robinet et la solution de transpiration ont été étudiés. La spectroélectrochimie d'émission atomique a été utilisée. La première partie de la thèse portait sur le mécanisme de dissolution de Cu. La plupart des espèces de Cu (II) sont solubles et sont libérées dans l'eau, laissant derrière eux un film de Cu2O. Une analyse cinétique suggère que le mécanisme de dissolution implique la dissolution simultanée du Cu et la formation du film. La deuxième partie a étudié la dissolution de Cu-42Zn et Cu-21Zn-3Si-P. Un processus de dissolution en deux étapes a été proposé: une première étape d'une croissance rapide de la couche dézincitée et une deuxième étape où la croissance de la couche dézincitée était plus lente. La troisième partie s'est concentrée sur l'effet du contenu de Zn sur la dissolution des alliages de Cu-Zn. Le mécanisme de dissolution a été clarifié. Pour la phase ?: une étape initiale dans laquelle Cu et Zn sont oxydés de manière congruente, mais seulement Zn2+ a été libéré dans l'eau, Cu formant un film Cu2O et une deuxième étape où le Cu2+ a été libéré dans l'eau. Pour la phase ?', la deuxième étape est identique à la phase initiale. L'augmentation de la teneur en Zn entraîne une extension temporelle du stade initial et retardent la libération de Cu2+. La partie finale a porté sur l'effet de la libération de Sn on Cu provenant des alliages Cu-Sn. L'effet amélioré de la libération de Sn sur Cu a été identifié. Cependant, l'augmentation de la teneur en Sn n'a pas augmenté monotoniquement l'efficacité de libération de Cu des alliages de Cu-Sn, ce qui était dû à la passivité de Sn.
2017PA066251.pdf (7.55 Mo) Télécharger le fichier
tel-01691570 , version 1 (24-01-2018)
  • HAL Id : tel-01691570 , version 1
Peng Zhou. An in situ kinetic investigation of the selective dissolution mechanism of Cu alloys. Chemical Physics [physics.chem-ph]. Université Pierre et Marie Curie - Paris VI, 2017. English. ⟨NNT : 2017PA066251⟩. ⟨tel-01691570⟩
274 Consultations
385 Téléchargements
