Analysis of cellular proliferation and aneuploidy in sas-4 and aurA mutant in Drosophila melanogaster
Analyse de la prolifération cellulaire et de l'aneuploïdie dans les mutants sas-4 et aurA chez Drosophila melanogaster
Cellular overproliferation associated with aneuploidy is a common hallmark of cancers. Low genetic instability may be a contributing factor of tumorigenesis. Recently, it was shown on a cellular cancer model in culture that strong aneuploidy compromises cell proliferation by causing cell death. During my thesis, we have test if this hypothesis was verified in vivo by using as a model, the tumours of the larval central nervous system of D. melanogaster. We decided to use mutants involved in mitotic spindle formation and chromosome segregation (Sas-4 or AurA) to induce these tumours. To generate aneuploidy, we chose to associate these mutations with mutations in genes essential for the SAC, Mad2 or BubR1ken. We then analysed the effect of the SAC depletion on the Nb proliferation. For sas-4, loss of the SAC leads to high aneuploidy and a decrease in Nb number associated with brain size reduction. It completely undermines the ability of mutant brain to induce tumors when injected into the abdomen of healthy adult flies. In the case of aurA, nor increase of aneuploidy in tissue or decrease in nb proliferation have been observed. Moreover, the same proportion of flies injected with aurA or aurA mad2 brains developed tumours. To better understand why the aurA mutant not react as the sas-4 mutant to the SAC depletion, we undertook a detailed analysis of aurA and aurA mad2 mutants. We first observed that despite the SAC depletion, 1) there is always a delay in mitosis in aurA mad2 and 2) there is a delay between SAC satisfaction and anaphase onset in aurA. Since anaphase onset is dependent of the CycB and Securine degradation via the APC / C, we analysed the behaviour of the CycB (coupled with a GFP tag) by real-time videomicroscopy and observed a defect in the regulation of CycB degradation in aurA and in the double aurA mad2 mutant. These observations lead us to propose a new role for AurA kinase in regulating the degradation of CycB at the end of mitosis.
Une surprolifération cellulaire associée à de l’aneuploïdie est un marqueur couramment retrouvé dans les cancers et une faible instabilité génétique peut-être un élément aggravant (sinon déclencheur) de la tumorigénèse. Récemment, il a été montré sur un modèle de cellules cancéreuses en culture qu’une forte aneuploïdie compromet la prolifération cellulaire en entraînant la mort de ces dernières. Au cours de ma thèse, nous avons souhaité tester si cette hypothèse se vérifiait in vivo en utilisant comme modèle, les tumeurs du système nerveux central de la larve de D. melanogaster. Nous avons fait le choix d’utiliser des mutants pour des gènes impliqués dans la formation du fuseau mitotique et la ségrégation des chromosomes (Sas-4 ou AurA) afin d’induire ces tumeurs. Pour générer l’aneuploïdie, nous avons choisi d’associer les mutations sas-4 ou aurA avec des mutations pour des gènes essentiels du SAC, Mad2 ou BubR1ken. Nous avons ensuite analysé par immunofluorescence et microscopie l’effet de la perte du SAC sur la prolifération des Nb. Pour sas-4, la perte du SAC cause l’apparition d’une forte aneuploïdie et une baisse du nombre de Nb associée à une forte réduction de taille des cerveaux. Cela compromet totalement la capacité des cerveaux mutants à induire des tumeurs lorsqu’on les injecte dans l’abdomen de mouches adultes saines. Dans le cas d’aurA, ni hausse de l’aneuploïdie dans le tissu ni baisse de la prolifération des Nbs n’ont été observés. Par ailleurs, la même forte proportion de mouches injectées avec des cerveaux aurA ou aurA mad2 développant une tumeur a été constaté. Afin de mieux comprendre pourquoi le mutant aurA ne réagit pas comme le mutant sas-4 à la déplétion du SAC, nous avons entrepris une analyse détaillée des mutants aurA et aurA mad2. Nous avons d’abord observé que, malgré la perte du SAC, 1) il existe toujours un délai en mitose dans aurA mad2 et 2) il existe un délai entre la satisfaction du SAC et l’entrée en anaphase dans aurA. Comme l’entrée en anaphase est dépendante de la dégradation de la CycB et de la Sécurine via l’APC/C, nous avons analysé le comportement de la CycB (couplé à une étiquette GFP) par vidéo-microscopie en temps réel et observé un défaut de la régulation de la dégradation de cette dernière dans le mutant aurA ainsi que dans le double mutant aurA mad2. Ces observations nous ont permis de proposer un nouveau rôle pour la kinase AurA dans la régulation de la dégradation de la CycB en fin de mitose.
