Cosmological electromagnetic cascades as probe of the Universe
Les cascades électromagnétiques cosmologiques comme sondes du milieu intergalactique
This thesis aims at studying "cosmological electromagnetic cascades". These cascades are initiated by the absorption of very high energy gamma-rays through gamma-gamma annihilation with optical / UV background photons of the intergalactic medium. In this interaction, electron/positron pairs are produced. The newly created leptons interact with photons of the Cosmological Microwave Background producing new gamma-rays through inverse Compton scattering which can also annihilate producing a cascade of secondary particles from a single primary photon. Observationally, the development of this cascade has three effects : the observed high energy spectrum is altered, observed photons arrive with a time delay with respect to primary photons and the source appears extended. Cosmological electromagnetic cascades start to being studied in the early sixties. But it is during the 2010's with the Fermi satellite and GeV to TeV observations that the field has really started to being explored. In the fast evolving backgound of gamma-ray astronomy, understanding the cascade physics has become a crucial stake. First the observed spectrum from a distant source is altered, which directly affects the modelling of high energy sources. Secondly, the cascades develop in the extragalactic medium and are very sensitive to its composition (background light, magnetic field). This medium is hard to study because it is extremely thin. Hence the cosmological cascades are a formidable probe to access its comprehension and its origin coming from the very beginning of our Universe. Yet the cosmological cascades are a complex phenomenon which involves complicated interactions (complex cross sections) and transport of particles in an expanding Universe. Analytical expressions are rapidly limited and numerical computations are required. In this thesis a Monte Carlo simulation code has been developed aiming at reproducing the cosmological cascades. This code has been tested and validated against analytical expressions. With the simulation code, a systematic study of the parameters impacting the development of the cascade has been led. This study allows a better understanding of the cascade physics. Especially, the impact of the intergalactic medium properties (extragalactic background light, extragalactic magnetic field) on the observables has been highlighted. Finally, a second study has been done to measure the contribution of cascades to the extragalactic gamma ray background. Recent works show that a great part of the diffuse emission at very high energy is explained by unresolved sources (blazars in particular). These gamma sources (resolved and unresolved) must in principle initiate cosmological cascades which can also contribute to the extragalactic gamma ray background. Starting from a modeling of the blazars at different redshifts, absorption and contribution of the cascades have been estimated with the simulation code. The results show that the contribution of the cascades might violate the Fermi limits but the excess must be confirmed.
Cette thèse vise à étudier le phénomène dit de " cascades électromagnétiques cosmologiques ". Ces cascades sont typiquement générées dans le milieu intergalactique par l'absorption de rayons gamma sur les photons du fond optique / UV et par la production de paires électron / positron associés. Ces leptons eux-mêmes interagissent avec les photons du fond diffus cosmologique via diffusion inverse Compton pour produire de nouveaux rayons gamma qui eux même peuvent s'annihiler, générant à partir d'un unique photon primaire toute une gerbe de photons et de particules secondaires. D'un point de vue observationnel, le développement de cette cascade introduit trois effets : une déformation du spectre à haute énergie, un retard temporel dans l'arrivée des rayons gamma et une extension de la taille apparente de la source. Les cascades électromagnétiques cosmologiques ont commencé à être étudiées dans les années soixante. Mais ce n'est qu'à partir des années 2010 avec l'arrivée du satellite Fermi (entre autres) et des observations dans la bande au GeV et au TeV que la discipline a explosé. Le phénomène est particulièrement important. D'une part il altère le spectre observé des sources rendant difficile la compréhension de la physique de ces dernières. D'autre part les cascades se développant dans le milieu extragalactique, elles sont très sensibles à la composition de ce dernier (fond diffus de photons, champ magnétique). Or ce milieu étant très ténu, il est difficile à étudier. Les cascades deviennent alors une formidable sonde pour accéder à sa compréhension et pouvoir en comprendre l'origine qui remonte au commencement de l'Univers. Pourtant les cascades cosmologiques sont un phénomène complexe faisant intervenir des interactions difficiles à modéliser (sections efficaces complexes) et le transport de particules dans un Univers en expansion (cosmologie). Face à cette complexité les expressions analytiques sont vite limitées et le passage au numérique devient inévitable. Dans le cadre de cette thèse un code de simulation Monte Carlo a donc été développé visant à reproduire aussi précisément que possible le phénomène des cascades. Ce code a été testé et validé en le confrontant aux expressions analytiques. Grâce à ce code, le rôle des différents paramètres physiques impactant le développement de la cascade a été étudié de manière systématique. Cette étude a permis de mieux comprendre la physique du phénomène. En particulier, l'impact des propriétés du milieu extragalactique (fond diffus extragalactique, champ magnétique extragalactique) sur les observables a été mis en évidence. Finalement, une seconde étude a été menée pour mesurer la contribution des cascades au fond gamma extragalactique. Des travaux récents montrent qu'une grande partie de l'émission diffuse à très haute énergie provient de sources ponctuelles non résolues (blazars en particulier). Ces sources gamma (résolues et non résolues) doivent en principe initier des cascades qui peuvent contribuer au fond diffus. En partant d'une modélisation de l'émission des blazars à différents redshifts, l'absorption et la contribution des cascades ont alors été calculées à l'aide du code Monte Carlo. Les résultats montrent que la contribution des cascades au fond gamma extragalactique pourrait violer les limites Fermi mais l'excès doit encore être confirmé.
