Abstract : This thesis gathers methodological contributions to the statistical analysis of large datasets in pharmacovigilance. The pharmacovigilance datasets produce sparse and large matrices and these two characteritics are the main statistical challenges for modelling them. The first part of the thesis is dedicated to the coclustering of the pharmacovigilance contingency table thanks to the normalized Poisson latent block model. The objective is on the one hand, to provide pharmacologists with some interesting and reduced areas to explore more precisely. On the other hand, this coclustering remains a useful background information for dealing with individual database. Within this framework, a parameter estimation procedure for this model is detailed and objective model selection criteria are developed to choose the best fit model. Datasets are so large that we propose a procedure to explore the model space in coclustering, in a non exhaustive way but in a relevant one. Additionnally, to assess the performances of the methods, a convenient coclustering index is developed to compare partitions with high numbers of clusters. The development of these statistical tools are not specific to pharmacovigilance and can be used for any coclustering issue. The second part of the thesis is devoted to the statistical ana- lysis of the large individual data, which are more numerous but also provides even more valuable information. The aim is to produce individual clusters according their drug profiles and subgroups of drugs and adverse effects with possible links, which overcomes the coprescription and masking phenomenons, common contingency table issues in pharmacovigilance. Moreover, the interaction between several adverse effects is taken into account. For this purpose, we propose a new model, the Multiple Latent Block Model (MLBM) which enables to cocluster two binary tables by imposing the same row ranking. Assertions inherent to the model are discussed and sufficient identifiability conditions for the model are presented. Then a parameter estimation algorithm is studied and objective model selection criteria are developed. Moreover, a numeric simulation model of the individual data is proposed to compare existing methods and study its limits. Finally, the proposed methodology to deal with individual pharmacovigilance data is presented and applied to a sample of the French pharmacovigilance database between 2002 and 2010.
Résumé : Cette thèse regroupe des contributions méthodologiques à l’analyse statistique des bases de données de pharmacovigilance. Les difficultés de modélisation de ces don- nées résident dans le fait qu’elles produisent des matrices souvent creuses et de grandes dimensions. La première partie des travaux de cette thèse porte sur la classification croisée du tableau de contingence de pharmacovigilance à l’aide du modèle des blocs latents de Poisson normalisé. L’objectif de la classification est d’une part de fournir aux pharmacologues des zones intéressantes plus réduites à explorer de manière plus précise, et d’autre part de constituer une information a priori utilisable lors de l’analyse des données individuelles de pharmacovigilance. Dans ce cadre, nous détaillons une procédure d’estimation partiellement bayésienne des paramètres du modèle et des critères de sélection de modèles afin de choisir le modèle le plus adapté aux données étudiées. Les données étant de grandes dimensions, nous proposons également une procédure pour explorer de manière non exhaustive mais pertinente, l’espace des modèles en coclustering. Enfin, pour mesurer la performance des algorithmes, nous développons un indice de classification croisée calculable en pratique pour un nombre de classes élevé. Les développements de ces outils statistiques ne sont pas spécifiques à la pharmacovigilance et peuvent être utile à toute analyse en classification croisée. La seconde partie des travaux de cette thèse porte sur l’analyse statistique des données individuelles, plus nombreuses mais également plus riches en information. L’objectif est d’établir des classes d’individus selon leur profil médicamenteux et des sous-groupes d’effets et de médicaments possiblement en interaction, palliant ainsi le phénomène de coprescription et de masquage que peuvent présenter les méthodes existantes sur le tableau de contingence. De plus, l’interaction entre plusieurs effets indésirables y est pris en compte. Nous proposons alors le modèle des blocs latents multiple qui fournit une classification croisée simultanée des lignes et des colonnes de deux tableaux de données binaires en leur imposant le même classement en ligne. Nous discutons des hypothèses inhérentes à ce nouveau modèle et nous énonçons des conditions suffisantes de son identifiabilité. Ensuite, nous présentons une procédure d’estimation de ses paramètres et développons des critères de sélection de modèles associés. De plus, un modèle de simulation numérique des données individuelles de pharmacovigilance est proposé et permet de confronter les méthodes entre elles et d’étudier leurs limites. Enfin, la méthodologie proposée pour traiter les données individuelles de pharmacovigilance est explicitée et appliquée à un échantillon de la base française de pharmacovigilance entre 2002 et 2010.
