New composite materials with permittivity gradient structured by an electric field and their application for field grading
Nouveaux matériaux composites à gradient de permittivité structurés par un champ électrique et leur application pour la gradation de potentiel
New developments in power electronics allow increasing the power density of the conversion systems. This means that the insulating materials, such as the encapsulation in power modules, are more are more stressed. If the electric field reinforcements in insulating polymers reach critical values, this can lead to a partial discharge activity, electrical treeing and eventually a complete breakdown of the insulation. The objective of this thesis is to study the appropriate matching of the dielectric properties of insulating polymer composites in order to reduce the electrical stress in the regions of field reinforcement. A new approach to minimize the reinforcements is proposed through a local structuration of the composite material allowing an auto-adaptive permittivity gradient where the largest stresses are present. This structuration is achieved thanks to the application of a DC electric field during the elaboration process of the composite material, leading to the displacement of the particles by electrophoresis. The field grading material is an epoxy matrix filled with high permittivity particles (strontium titanate SrTiO3 or barium titanate BaTiO3). Applying a DC electric field on the liquid resin containing the particles induces their accumulation on the high voltage electrode, building an accumulated layer highly concentrated in particles, conferring to this region a higher permittivity. Each region of the structured composite (accumulated layer and low concentrated region) was characterized in terms of dielectric properties (permittivity and losses). While the low concentrated region of particles keeps a permittivity close to that of homogeneous composites one, the accumulated layer exhibits a significant increase due to the increase in the local particle content. The particle concentration in each region of the structured material were precisely determined, and the related permittivity values are in good agreement with the permittivity values of the homogeneous composite materials of the same filler content. This shows that the accumulated layer was not organized in a particular way. Regarding the dielectric strength of the accumulated layer, its values are large enough for the applications and these values follow the typical power law versus thickness. Finite element methods prove that these materials are appropriate for minimizing the electric field reinforcements at the triple point, between the metal, the ceramic and the encapsulation. These results highlight the interests of these new kind of field grading materials. They could allow improving the reliability and the robustness of power modules or other electrical systems working at high field.
Les développements récents en électronique de puissance visent à augmenter la densité de puissance totale dans les systèmes de conversion d'énergie. Cela contraint alors de plus en plus les matériaux isolants, tels que l'encapsulation dans les modules de puissance. Si les renforcements de champ électrique au sein des polymères isolants atteignent des valeurs critiques, cela peut entraîner une activité de décharges partielles, des arborescences voire la rupture totale de l'isolation. L'objectif de cette thèse est d'étudier l'adaptation des propriétés diélectriques d'un polymère composite isolant afin de réduire les contraintes autour des zones de renforcements de champ électrique. Nous proposons une nouvelle approche de gradation de potentiel pour minimiser les renforcements de champ à travers une structuration locale du matériau composite sous forme d'un gradient de permittivité auto-adaptatif localisé là où les contraintes sont les plus intenses. Cette structuration est réalisée via l'application d'un champ électrique DC lors du procédé d'élaboration du matériau composite, permettant le déplacement par électrophorèse des particules. Le composite à gradient de permittivité est composé d'une matrice époxy chargée en particules à forte permittivité (titanate de strontium SrTiO3 ou titanate de baryum BaTiO3). L'action d'un champ électrique DC sur la résine liquide chargée en particules engendre leur accumulation vers l'électrode de plus fort potentiel, formant ainsi une couche fortement chargée, qui confère à cette région une permittivité plus élevée. Chaque région du composite structuré (zone de la couche accumulée et zone faiblement chargée en particules) a été caractérisée en termes de propriétés diélectriques (permittivité et pertes). Alors que la région des composites faiblement chargée en particules conserve une permittivité voisine de celle des composites homogènes, la couche accumulée présente une augmentation importante liée à l'augmentation de la densité de particules. Les concentrations en particules de chaque région du matériau structuré ont été déterminées précisément, et les valeurs de permittivités associées se corrèlent bien avec les valeurs de permittivité des matériaux composites homogènes de taux de chargement équivalent. Cela montre que la couche accumulée ne s'est pas organisée d'une façon particulière. Concernant la rigidité diélectrique de la couche accumulée, elle présente des valeurs suffisantes pour tenir les contraintes rencontrées et ses valeurs suivent la loi de puissance classique en fonction de l'épaisseur. Des simulations par éléments finis confirment l'intérêt de ces matériaux pour la minimisation des renforcements de champ électrique au niveau du point triple dans les modules de puissance. Ces résultats montrent tout le potentiel applicatif de ces nouveaux matériaux à gradient de champ. Ils pourraient permettre l'amélioration de la fiabilité et de la robustesse des modules de puissance et autres systèmes électriques travaillant sous fort champ.
