187 PARTIE I, 189 PARTIE II, p.219 ,
Synthesis and characterization of nearly monodisperse CdE (E = sulfur, selenium, tellurium) semiconductor nanocrystallites, Journal of the American Chemical Society, vol.115, issue.19, pp.8706-8715, 1993. ,
DOI : 10.1021/ja00072a025
(b) Henglein, A, Lin, X. M. Met. Nanoclusters Catal. Mater. Sci. Issue Size Control, pp.665-668, 1989. ,
Perspectives on the Physical Chemistry of Semiconductor Nanocrystals, The Journal of Physical Chemistry, vol.100, issue.31, pp.13226-13239, 1996. ,
DOI : 10.1021/jp9535506
Effect of the crystallinity of silver nanoparticles on surface plasmon resonance induced enhancement of effective absorption cross-section of dyes, Journal of Applied Physics, vol.117, issue.8, pp.83111-83112, 2014. ,
DOI : 10.1021/nl303898y
Synthesis and Characterization of Strongly Luminescing ZnS-Capped CdSe Nanocrystals, The Journal of Physical Chemistry, vol.100, issue.2, pp.468-471, 1996. ,
DOI : 10.1021/jp9530562
Digestive-Ripening Agents for Gold Nanoparticles:?? Alternatives to Thiols, Chemistry of Materials, vol.15, issue.4, pp.935-942, 2003. ,
DOI : 10.1021/cm0206439
Synthesis of Monodisperse Spherical Nanocrystals, Angewandte Chemie International Edition, vol.45, issue.25, pp.4630-4660, 2007. ,
DOI : 10.1002/3527602453
Platinum-catalyzed hydrosilylation - colloid formation as the essential step, Journal of the American Chemical Society, vol.108, issue.23, pp.7228-7231, 1986. ,
DOI : 10.1021/ja00283a016
Synthesis of CNT-supported cobalt nanoparticle catalysts using a microemulsion technique: Role of nanoparticle size on reducibility, activity and selectivity in Fischer???Tropsch reactions, Applied Catalysis A: General, vol.374, issue.1-2, pp.79-86, 2010. ,
DOI : 10.1016/j.apcata.2009.11.029
Monodispersed Nickel Nanoparticles with Tunable Phase and Size: Synthesis, Characterization, and Magnetic Properties, The Journal of Physical Chemistry C, vol.112, issue.48, pp.18793-18797, 2008. ,
DOI : 10.1021/jp805591y
Gel??ster Kohlenstoff kontrolliert die erste Phase des Nanokohlenstoffwachstums, Angewandte Chemie, vol.242, issue.14, pp.3371-3375, 2010. ,
DOI : 10.1016/j.jcat.2006.05.030
An Easily Accessed Nickel Nanoparticle Catalyst for Alkene Hydrosilylation with Tertiary Silanes, Angewandte Chemie International Edition, vol.123, issue.40, pp.12295-12299, 2016. ,
DOI : 10.1002/ange.201002767
URL : https://infoscience.epfl.ch/record/223276/files/SI.pdf
Nickel nanoparticles in hydrogen-transfer reductions: Characterisation and nature of the catalyst, Applied Catalysis A: General, vol.378, issue.1, pp.42-51, 2008. ,
DOI : 10.1016/j.apcata.2010.01.044
Size and structure control of magnetic nanoparticles by using a modified polyol process, Journal of Applied Physics, vol.93, issue.2, pp.7477-7479, 2001. ,
DOI : 10.1126/science.287.5460.1989
Nanocrystalline Nickel Nanoparticles, Advanced Materials, vol.12, issue.12, pp.878-883, 2000. ,
DOI : 10.1002/1521-4095(200006)12:12<878::AID-ADMA878>3.0.CO;2-X
Microwave-Assisted Synthesis and Magnetic Study of Nanosized Ni/NiO Materials, Chemistry of Materials, vol.18, issue.11, pp.2719-2725, 2006. ,
DOI : 10.1021/cm0511365
Monodispersed Nickel Nanoparticles with Tunable Phase and Size: Synthesis, Characterization, and Magnetic Properties, The Journal of Physical Chemistry C, vol.112, issue.48, pp.18793-412, 1912. ,
Monodisperse nickel nanoparticles prepared from a monosurfactant system and their magnetic propertiesElectronic supplementary information (ESI) available: XPS of Ni nanoparticles; plot of magnetization vs. applied field. See http://www.rsc.org/suppdata/jm/b3/b303226d/, Journal of Materials Chemistry, vol.13, issue.7, p.1510, 2003. ,
DOI : 10.1039/b303226d
Controlled Design of Size-Tunable Monodisperse Nickel Nanoparticles, Chemistry of Materials, vol.22, issue.4, pp.1340-1349, 2010. ,
DOI : 10.1021/cm902007g
URL : https://hal.archives-ouvertes.fr/hal-00457516
A General Synthesis Strategy for Monodisperse Metallic and Metalloid Nanoparticles (In, Ga, Bi, Sb, Zn, Cu, Sn, and Their Alloys) via in Situ Formed Metal Long-Chain Amides, Chemistry of Materials, vol.27, issue.2, pp.635-647, 2015. ,
DOI : 10.1021/cm5045144
Kinetic effects of halide ions on the morphological evolution of silver nanoplates, Physical Chemistry Chemical Physics, vol.24, issue.44, pp.10286-10292, 2009. ,
DOI : 10.1039/b912985e
Doctoral Dissertation, l'Université Pierre et Marie Curie, 2011. ,
Preparation of cobalt nanoparticles by hydrogen reduction of cobalt chloride in the gas phase, Materials Research Bulletin, vol.39, issue.1, pp.63-70, 2004. ,
DOI : 10.1016/j.materresbull.2003.09.023
Water???gas-shift reaction on a Ni2P(001) catalyst: Formation of oxy-phosphides and highly active reaction sites, Journal of Catalysis, vol.262, issue.2, pp.294-303, 2009. ,
DOI : 10.1016/j.jcat.2009.01.006
P(001) Surface:?? The Importance of Ensemble Effect, Journal of the American Chemical Society, vol.127, issue.42, pp.14871-14878, 2005. ,
DOI : 10.1021/ja0540019
P nanoparticles, Energy & Environmental Science, vol.136, issue.8, pp.2347-2351, 2015. ,
DOI : 10.1021/ja502379c
Hydrogenation of naphthalene on nickel phosphide supported on silica, Asia-Pacific Journal of Chemical Engineering, vol.231, issue.5, pp.574-580, 2009. ,
DOI : 10.1016/j.jcat.2005.01.020
Converting Metals into Phosphides:?? A General Strategy for the Synthesis of Metal Phosphide Nanocrystals, Journal of the American Chemical Society, vol.129, issue.7, pp.1896-1897, 2007. ,
DOI : 10.1021/ja068502l
P Nanoparticles Based on the Nanoscale Kirkendall Effect, Inorganic Chemistry, vol.46, issue.2, pp.369-371, 2007. ,
DOI : 10.1021/ic061846s
Solvo-thermal synthesis of crystalline dinickel phosphide, Journal of Crystal Growth, vol.260, issue.1-2, pp.115-117, 2004. ,
DOI : 10.1016/j.jcrysgro.2003.08.003
A New Way to Prepare Nanocrystalline Dinickel Phosphide, Materials Research Bulletin, vol.33, issue.5, pp.669-672, 1998. ,
DOI : 10.1016/S0025-5408(98)00020-8
A simple, convenient, mild solvothermal route to nanocrystalline Cu3P and Ni2P, Solid State Ionics, vol.122, issue.1-4, pp.157-160, 1999. ,
DOI : 10.1016/S0167-2738(99)00049-1
A Mild One-Step Solvothermal Route to Metal Phosphides (Metal=Co, Ni, Cu), Journal of Solid State Chemistry, vol.149, issue.1, pp.88-91, 2000. ,
DOI : 10.1006/jssc.1999.8499
Magnetic Core???Shell Nanoparticles from Nanoscale-Induced Phase Segregation, Chemistry of Materials, vol.23, issue.8, pp.2270-2277, 2011. ,
DOI : 10.1021/cm200575g
URL : https://hal.archives-ouvertes.fr/hal-00694192
Phosphorus: An Element that could have been called Lucifer, pp.13-18, 2013. ,
Nutrition for the Middle Aged and Elderly Southport: Nova Science Publishers, Inc. ISBN 1- 60456-146-7, pp.171-171, 2008. ,
Ullmann's Encycl. Ind. Chem ISBN: 9783527306732 Advanced Inorganic Chemistry, Fifth Ed, J. J. Am. Chem. Soc, vol.26, issue.11, pp.633-677, 1947. ,
Ullmann's Encycl ISBN: 9783527306732. [6] Emsley, John. The Shocking History of Phosphorus The Story of 100 years of Phosphorus Making, Ind. Chem. John Wiley & Sons, vol.26, pp.725-745, 2000. ,
Inorganic Chemistry, Fifth Ed, J. Electrochem. Soc, issue.9, pp.167-185, 1951. ,
Ullman's Encycl. Ind. Chem, pp.325-360, 2012. ,
On the Polymorphism of White Phosphorus, Chemische Berichte, vol.1987, issue.9, pp.1235-1240, 1997. ,
DOI : 10.1002/cber.19971300911
Doctoral Dissertation (d) Rios, I. d. l.; Hamon, J. Am. Chem. Soc. Angew. Chem. Organometallics J.-R, vol.91, issue.17, pp.510-510, 1979. ,
-phosphorylation of organic compounds by phosphorus and phosphides in the presence of metal complexes, Russian Chemical Reviews, vol.62, issue.9, pp.877-896, 1993. ,
DOI : 10.1070/RC1993v062n09ABEH000051
Reactions of Elemental Phosphorus with Organometallic Compounds, The Journal of Organic Chemistry, vol.28, issue.2, pp.471-473, 1963. ,
DOI : 10.1021/jo01037a048
Alkali-Metal Hydrogen Tetraphosphides, MIHP4?the First Salts of Bicyclo[1.1.0]tetraphosphane, Angewandte Chemie International Edition in English, vol.37, issue.8, pp.1059-1061, 1988. ,
DOI : 10.1002/nadc.19870351106
)], Organometallics, vol.17, issue.18, pp.4110-4112, 1998. ,
DOI : 10.1021/om9801148
Using a Lewis Acid Stabilized Bicyclo[1.1.0]tetraphosphabutane Anion, Angewandte Chemie International Edition, vol.84, issue.47, pp.12836-12839, 2014. ,
DOI : 10.1139/v05-245
by Metal-Mediated C???P Bond Formation, Angewandte Chemie International Edition, vol.45, issue.29, pp.7639-7642, 2014. ,
DOI : 10.1021/ma3001719
Cluster, Journal of the American Chemical Society, vol.129, issue.46, pp.14180-14181, 2007. ,
DOI : 10.1021/ja077296u
Experiments with LiBH 4 performed by S. Dreyfuss, Adamek, C.; Opelia, S.; Budzikiewicz, H, vol.52, issue.292, pp.5179-5182, 2016. ,
Tris(trimethylsilyl)phosphine. e-EROS Encyclopedia of Reagents for Organic Synthesis, 2011. ,
DOI : 10.1002/047084289x.rn01332
Iron-Catalyzed Dehydropolymerization: A Convenient Route to Poly(phosphinoboranes) with Molecular-Weight Control, Angewandte Chemie International Edition, vol.25, issue.16, pp.4836-4841, 2015. ,
DOI : 10.1021/om0604324
: A Route to Poly(alkylphosphinoboranes), Angewandte Chemie International Edition, vol.23, issue.46, pp.13782-13786, 2015. ,
DOI : 10.1063/1.555949
URL : http://onlinelibrary.wiley.com/doi/10.1002/anie.201507084/pdf
)Li: From Ditopicity to Dual Reactivity, Journal of the American Chemical Society, vol.133, issue.16, pp.6472-6480, 2011. ,
DOI : 10.1021/ja201760c
URL : https://hal.archives-ouvertes.fr/hal-00991604
Extensive drying in vacuo at 80 °C resulted in the partial decomposition of the product, as shown by the appearance of a new signal at ?1 ,
[5] Carenco, S. Doctoral Dissertation, l'Université Pierre et Marie Curie (c) Astruc, D. Transition-Metal Nanoparticles in Catalysis : From Historical Background to the State-of-the Art, Nanoclusters Catal. Mater. Sci. Issue Size Control Chem. Mater. Polte, J. CrystEngComm Z. ACS Appl. Mater. Interfaces Acc. Chem. Res. Cuenya, B. R. Thin Solid Films J.-M Inorg. Chem. Appl. Catal. A, vol.2, issue.3179, pp.233-249, 2003. ,
Transition metal phosphide semiconductors for their possible use in photoelectrochemical cells and solar chargeable battery (Saur Viddyut Kosh V), Journal of Materials Science, vol.13, issue.6, pp.2193-2201, 1986. ,
DOI : 10.1007/BF00547969
Chemie -Int, pp.54-12914, 2015. ,
Hydrodesulfurization of 4,6-dimethyldibenzothiophene over high surface area metal phosphides, Applied Catalysis A: General, vol.361, issue.1-2, pp.18-25, 2009. ,
DOI : 10.1016/j.apcata.2009.03.037
Advanced Inorganic Chemistry ,
Radical synthesis of trialkyl, triaryl, trisilyl and tristannyl phosphines from P4, New Journal of Chemistry, vol.690, issue.8, pp.1533-1536, 2010. ,
DOI : 10.1071/CH9941631
Chemie Int, Organometallics Chem. Eur. J, vol.37, issue.9, pp.2255-2257, 1998. ,
Phosphorous-Functionalized Bis(acyl)phosphane Oxides for Surface Modification, Angewandte Chemie International Edition, vol.205, issue.19, pp.4648-4652, 1997. ,
DOI : 10.1016/j.surfcoat.2011.01.006
Ion Dynamics in Confined Spaces: Sodium Ion Mobility in Icosahedral Container Molecules, Hölderich, W. Z. Anorg. Allg, pp.7465-7469, 2010. ,
DOI : 10.1002/anie.201003441
