Développement d'antennes agiles en fréquence intégrant un condensateur ferroélectrique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Ferroelectric capacitors integreted within a frequency tunable antenna
The rapid growth of wireless communication has promoted the increase of the number of standards for wireless applications. This progress requests new manufacturing processes of smart devices that are able to work on several frequency bands. However, the miniaturization of antennas is accompanied by a significant reduction of the bandwidth as well as its radiation efficiency and it becomes dependent on its using context. Tunable devices can be integrated within antennas in order to overcome these main issues. Among the solutions proposed in the literature, thin-film ferroelectric materials are used to realize tunable capacitors. The use of such materials allows the design of a tunable capacitor that can be tuned by an applied electric field. The advances of these ferroelectric thin-film devices were developed in order to meet particular and extreme requirements for today's telecommunication systems (miniaturization, low cost, ease of the manufacture process, integration and good power handling). This thesis is part of ongoing research over frequency reconfigurable antennas which are based on ferroelectric materials. Two main axes were developed during this work: The development and realization of capacitors that incorporate a BST film along with their microwave characterizations within XLIM lab. The second part of our work is dedicated to the realization of the complete tunable antenna.
L’évolution rapide des communications sans fil a favorisé l’augmentation du nombre de standards alloués aux systèmes de communication fonctionnant sur différentes bandes de fréquences. Pour accompagner les derniers développements de systèmes sans fil, il est indispensable de concevoir des antennes miniatures intégrables. Cependant, la miniaturisation des antennes s’accompagne d’une réduction significative de la bande passante et de leur efficacité de rayonnement ainsi qu’à l’apparition d’un décalage fréquentiel de leurs fréquences de fonctionnement lorsqu’elles sont étudiées dans leur contexte d’utilisation. L’intégration de dispositifs accordables au sein d 'une antenne permet de répondre favorablement à ces problématiques. Parmi les solutions proposées dans la littérature, l’utilisation de matériaux ferroélectriques en couche mince permet de concevoir un condensateur accordable en fonction du champ électrique appliqué. Ces dispositifs réalisés à base de couches minces ferroélectriques ont été développés pour répondre aux exigences particulières et extrêmes des systèmes de télécommunication actuels (miniaturisation, faible coût, facilité de fabrication et d’intégration et bonne tenue en puissance). Cette thèse s’inscrit dans la continuité des recherches sur les antennes reconfigurables en fréquences à base de matériaux ferroélectriques. Deux axes principaux ont été développés au cours de ces travaux de recherche : le développement et la réalisation de condensateurs intégrant un film BST au sein du laboratoire XLIM et leurs caractérisations en hyperfréquence. La seconde partie de nos travaux concerne l’intégration de l’un de ces dispositifs accordables au sein d’une antenne miniature afin d’étudier son accordabilité en fréquence.
2017LIMO0094.pdf (13.23 Mo) Télécharger le fichier
tel-01709308 , version 1 (14-02-2018)
  • HAL Id : tel-01709308 , version 1
Mohamad Rammal. Développement d'antennes agiles en fréquence intégrant un condensateur ferroélectrique. Micro et nanotechnologies/Microélectronique. Université de Limoges, 2017. Français. ⟨NNT : 2017LIMO0094⟩. ⟨tel-01709308⟩
250 Consultations
1314 Téléchargements
