Inverse problems for diagnosis of electric cables from reflectometry measurement
Problèmes inverses pour le diagnostic de câbles électriques à partir de mesures de réflectométrie
Electric cables are ubiquitous in many devices and systems where they are used for data or power transmission. These connection links are most often installed for long periods of operation during which they are subject to aging and sometimes exposed to harsh environments. While electric cables fulfill important and sometimes even critical functions, they might fail due to the hard constraints they have to endure. This motivates the need for monitoring tools, in order to detect early faults and to intervene as soon as possible, before they mutate into heavier damage whose consequences can be detrimental and expensive. EDF company is very affected by this problematic insofar as it operates significant lengths of cables for energy distribution, but also in power plant for power supply of the diverse apparatus, to route data and to transmit measurement. The company has been leading several studies regarding cable aging, cable faults, and wire diagnosis methods. The CAIMAN project (Cable AgIng MANagement), sponsored by the Engineering Department of Nuclear and Thermal Projects (SEPTEN), deals with these questions. The work presented in this dissertation were led in this context and results from a collaboration with Inria (French National Institute for Research in Applied Mathematics and Computer Sciences). Starting from the observation that existing cable diagnosis methods do not offer full satisfaction, we targeted the goal of developping new tools to improve the state of the art. Existing techniques rely on a range of tests, some of which are destructive or involve in-lab investigations, but these still cannot detect some kind of faults. Among major techniques, reflectometry has the most promising results. This technique consists in the same principle as a radar. One sends a wave down a cable from one end. Then the reflected signal is analysed searching for signs of faults. Yet, this method also suffers some limitations and soft faults remain hard to detect. Researchers and industries multiply the investigations in the domain of reflectometry-based techniques, and some get interesting results. Scientists from Inria developped algorithms for cable parameter estimation from reflectometry measurements, following an inverse-problem approach. The goal of our work was to extend these methods to meet the specific needs of EDF. One of the main challenges we coped with was to take into account electric losses in the resolution of the inverse problem. Our main contribution is a method to estimate the per unit length resistance profile of a cable. This estimation reveals resistive faults that most often only produce weak reflections in reflectometry measurements. Other contributions concerns the improvement of the method based on pre-processing of the data whose role is to erase the effect of impedance mismatches. This work breaks new grounds in the domain of reflectometry-based wire diagnosis techniques.
Les câbles électriques sont présents dans de nombreux produits et systèmes où ils sont utilisés pour transmettre des données ou transporter de l'énergie. Ces liaisons sont la plupart du temps installées pour des durées d'exploitation longues au cours desquelles elles doivent subir l'usure du temps, ainsi que celle résultant d'un environnement parfois agressif. Alors que les câbles électriques assurent des fonctions essentielles et dans certains cas critiques, ils sont aussi sujets à des défaillances qui découlent des contraintes qu'ils endurent. Ceci explique la nécessité de surveiller leur état, afin de détecter au plus tôt les défauts naissants et d'intervenir avant qu'ils ne dégénèrent en dommages dont les conséquences peuvent être préjudiciable et économiquement lourdes. L'entreprise EDF est particulièrement concernée par cette problématique dans la mesure ou elle exploite des longueurs considérables de câbles pour le transport et la distribution d'électricité sur tout le territoire bien sûr, mais aussi au sein des centrales qui produisent l'électricité, pour alimenter les différents organes, et acheminer commandes et mesures. L'entreprise, attentive à ce que ces câbles soient en bon état de fonctionnement mène plusieurs travaux, d'une part pour étudier leur vieillissement et modes de dégradation, et d'autre part pour développer des méthodes et outils pour la surveillance et le diagnostic de ces composants essentiels. Le projet EDF CAIMAN (Cable AgIng MANagement) commandé par le SEPTEN (Service Etudes et Projets Thermiques Et Nucléaires) traite de ces questions, et les travaux présentés dans cette thèse ont été conduits dans ce cadre et sont le fruit d'une collaboration avec Inria (Institut National de Recherche en Informatique et Automatique). Partant du constat que les méthodes de diagnostic de câbles existantes à l'heure actuelle ne donnent pas pleine satisfaction, nous nous sommes donné pour objectif de développer des outils nouveaux. En effet, les techniques actuelles reposent sur différents moyens dont des tests destructifs, des prélèvements pour analyse en laboratoire, et des mesures sur site mais qui ne permettent pas de diagnostiquer certains défauts. Parmi les techniques non destructives, la réflectométrie, dont le principe est d'injecter un signal électrique à une extrémité du câble et d'analyser les échos, souffre aussi de certaines de ces limitations. En particulier, les défauts non-francs restent encore difficiles à détecter. Toutefois les travaux qui se multiplient autour de cette technique tentent d'en améliorer les performances, et certains obtiennent des résultats prometteurs. Les chercheurs de l'Inria qui travaillent sur le sujet ont développé des algorithmes pour exploiter des mesures de réflectométrie. En résolvant un problème inverse, les paramètres d'un modèle de câble sont estimés et servent alors d'indicateurs de l'état de dégradation du câble testé. L'objectif de cette thèse est d'étendre ces méthodes pour répondre aux besoins spécifiques d'EDF. Un des principaux défis auquel nous avons apporté une solution est la prise en compte des pertes ohmiques dans la résolution du problème inverse. Plus spécifiquement, notre contribution principale est une méthode d'estimation du profil de résistance linéique d'un câble. Cette estimation permet de révéler les défauts résistifs qui produisent souvent des réflexions faibles dans les réflectogrammes habituels. Une seconde contribution vise à améliorer la qualité des données utilisées par cette méthode d'estimation. Ainsi, nous proposons un pré-traitement des mesures dont le but est de gommer l'effet de la désadaptation des instruments aux câbles ou celui des connecteurs. Ces travaux apportent de nouveaux outils pour l'exploitation des mesures de réflectométrie et des solutions pour le diagnostic de certains défauts encore difficiles à détecter aujourd'hui.
Origin : Version validated by the jury (STAR)
