Diagnosis of MV Oil Filled Cable Terminations with X-Ray Imaging and Infrared (IR) Thermography, American Journal of Applied Sciences, vol.4, issue.3, pp.168-170, 2007. ,
DOI : 10.3844/ajassp.2007.168.170
URL : http://thescipub.com/pdf/10.3844/ajassp.2007.168.170
PARA- METER ESTIMATION AND INVERSE PROBLEMS, 2013. ,
Onde quasi-TEM des guides cylindriques blindés, Annales Des Télécommunications, vol.34, issue.12, pp.45-51, 1979. ,
WIRE TROUBLESHOOTING AND DIAGNOSIS: REVIEW AND PERSPECTIVES, Progress In Electromagnetics Research B, vol.49, pp.253-279, 2013. ,
DOI : 10.2528/PIERB13020115
URL : http://www.jpier.org/PIERB/pierb49/12.13020115.pdf
Chaos Time Domain Reflectometry for Online Defect Detection in Noisy Wired Networks, IEEE Sensors Journal, vol.16, issue.22, pp.168027-8034, 2016. ,
DOI : 10.1109/JSEN.2016.2606567
Engineering Electromagnetism, 1993. ,
Sparse Overcomplete Representation applied to FMCW Reflectometry for Non-uniform Transmission Lines, 2015. ,
Application of FMCW radar principle for fast inhomogeneity identification on transmission lines, 6th German Microwave Conference, 2011. ,
On-line diagnosis using Orthogonal Multi-Tone Time Domain Reflectometry in a lossy cable, 10th International Multi-Conferences on Systems, Signals & Devices 2013 (SSD13), pp.1-6, 2013. ,
DOI : 10.1109/SSD.2013.6564144
Estimation of distributed and lumped ohmic losses in electrical cables, 2016 IEEE Conference on Antenna Measurements & Applications (CAMA), 2016. ,
DOI : 10.1109/CAMA.2016.7815742
URL : https://hal.archives-ouvertes.fr/hal-01376833
Accurate detection of low entity cable faults by wavelet transform, 2004 International Symposium on Electromagnetic Compatibility (IEEE Cat. No.04CH37559), pp.936-941, 2004. ,
DOI : 10.1109/ISEMC.2004.1349951
Detection and Localization of Defects in Shielded Cables by Time-Domain Measurements With UWB Pulse Injection and Clean Algorithm Postprocessing, IEEE Transactions on Electromagnetic Compatibility, vol.46, issue.4, pp.597-605, 2004. ,
DOI : 10.1109/TEMC.2004.837842
Distributed Source Identification for Wave Equations : An offline Obeserver-Based Approach, IEEE Transactions on Automatic Control, issue.8, pp.572067-2073, 2012. ,
Application of phase detection frequency domain reflectometry for locating faults in an F-18 flight control harness, IEEE Transactions on Electromagnetic Compatibility, issue.2, pp.47327-334, 2005. ,
Field theory of guided waves, 1991. ,
Echo Response of Faults in Transmission Lines: Models and Limitations to Fault Detection, IEEE Transactions on Microwave Theory and Techniques, vol.64, issue.12, 2016. ,
DOI : 10.1109/TMTT.2016.2608774
URL : https://hal.archives-ouvertes.fr/hal-01352701
Comparison of failure detection capability of available low-voltage cable diagnostic methods, 2016 IEEE Electrical Insulation Conference (EIC), pp.346-349, 2016. ,
DOI : 10.1109/EIC.2016.7548598
Network analyzer measurement de-embedding utilizing a distributed transmission matrix bisection of a single THRU structure, ARFTG 63rd Conference, Spring 2004, pp.61-68, 2004. ,
DOI : 10.1109/ARFTG.2004.1387856
Accurate resistance, inductance, capacitance, and conductance (RLCG) from uniform transmission line measurements, 2008 IEEE-EPEP Electrical Performance of Electronic Packaging, pp.77-80, 2008. ,
DOI : 10.1109/EPEP.2008.4675881
Diagnostic de défauts d'isolement dans des lignes de transmission électriques : application aux cables de signalisation SNCF, 2015. ,
Novel Reflectometry Method Based on Time Reversal for Cable Aging Characterization, 2012 IEEE 58th Holm Conference on Electrical Contacts (Holm), pp.1-6, 2012. ,
DOI : 10.1109/HOLM.2012.6336569
URL : https://hal.archives-ouvertes.fr/hal-00813260
, Time Reversal for Soft Fault Diagnosis in Wire Networks. PIER M, pp.3145-58, 2013.
Doctrine de maintenance : suivi du vieillissement des câbles électriques, 2013. ,
Time reversal of ultrasonic fields. I. Basic principles, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, vol.39, issue.5, pp.555-566, 1992. ,
DOI : 10.1109/58.156174
Spatially-resolved Measurement and Diagnostic Method for Power Cables Using Interference Characteristics of Travelling Waves, 9th international Conference on Insulated Power Cables, 2015. ,
Experimental results of a diagnostic measurement method for power cables using interference characteristics of travelling waves, 2016 IEEE Electrical Insulation Conference (EIC), pp.392-395, 2016. ,
DOI : 10.1109/EIC.2016.7548621
Innovative HF extraction procedure of the characteristic impedance for embedded planar transmission line on high conductive Si substrate, Asia-Pacific Microwave Conference, pp.606-609, 2010. ,
The use of the Pseudo Wigner Ville Transform for detecting soft defects in electric cables, 2011 IEEE/ASME International Conference on Advanced Intelligent Mechatronics (AIM), 2011. ,
DOI : 10.1109/AIM.2011.6026992
, Bibliographie
, Conference on Advanced Intelligent Mechatronics, AIM, pp.309-314
Conversions between S, Z, Y, H, ABCD, and T parameters which are valid for complex source and load impedances, IEEE Transactions on Microwave Theory and Techniques, vol.42, issue.2, pp.205-211, 1994. ,
DOI : 10.1109/22.275248
Down to the Wire, IEEE Spectrum, pp.34-39, 2001. ,
A critical comparison of reflectometry methods for location of wiring faults, Smart Structures and Systems, pp.25-46, 2006. ,
DOI : 10.12989/sss.2006.2.1.025
Frequency-domain reflectometery for on-board testing of aging aircraft wiring, IEEE Transactions on Electromagnetic Compatibility, vol.45, issue.2, pp.45306-315, 2003. ,
DOI : 10.1109/TEMC.2003.811305
An inexpensive distance measuring system for navigation of robotic vehicles. Microwave and Optical Technology Letters, pp.84-87, 2002. ,
DOI : 10.1002/mop.10241
Feasibility of spread spectrum sensors for location of arcs on live wires, IEEE Sensors Journal, vol.5, issue.6, pp.1445-1449, 2005. ,
DOI : 10.1109/JSEN.2005.858900
Spread spectrum sensors for critical fault location on live wire networks. Structural Control and Health Monitoring, pp.257-267, 2005. ,
DOI : 10.1002/stc.69
The invisible fray: a critical analysis of the use of reflectometry for fray location, IEEE Sensors Journal, vol.6, issue.3, pp.697-706, 2006. ,
DOI : 10.1109/JSEN.2006.874017
Les probl??mes aux limites dans la th??orie des ??quations aux d??riv??es partielles, Journal de Physique Th??orique et Appliqu??e, vol.XXI, issue.1, pp.202-241, 1907. ,
DOI : 10.1051/jphystap:019070060020200
Étude des irrégularités d'impédance des câbles coaxiaux par observation oscillographique des échos d'une impulsion, Annales Des Télécommunications, vol.3, issue.10, pp.317-331, 1948. ,
Recherche de défauts sur câbles d'énergie. Eyrolles, 1987. ,
Approche Bayésienne Pour les Problèmes Inverses Assessment and management of ageing of major nuclear power plant components important to saftey : PWR vessel internals, Lavoisier. [International Atomic Energy Agency International Atomic Energy Agency (IAEA), 1999. ,
The inverse scattering problem for L C R G transmission lines, Journal of mathematical physics, pp.2286-2290, 1982. ,
DOI : 10.1063/1.525307
, Locating Faults With High Resolution Using Single-Frequency TR-MUSIC Processing, IEEE Transactions on Instrumentation and Measurement, issue.10, pp.652342-2348, 2016.
, Locating Multiple Soft Faults in Wire Networks Using an Alternative DORT Implementation, IEEE Transactions on Instrumentation and Measurement, vol.65, issue.2, pp.399-406, 2016.
Câbles d'énergie : Théorie de l'échométrie, 2006. ,
Elements of soliton theory, 1980. ,
Diagnostics of control and instrumentation cables in nuclear power plant via time-frequency domain reflectometry with optimal reference signal, 9th international Conference on Insulated Cables, 2015. ,
Efficient reconstruction of dispersive dielectric profiles using time domain reflectometry (TDR) Hydrology and Earth System Sciences, pp.209-232, 2006. ,
DOI : 10.5194/hess-10-209-2006
URL : https://www.hydrol-earth-syst-sci.net/10/209/2006/hess-10-209-2006.pdf
Méthodes de diagnostic filaire embarqué pour des réseaux complexes, 2010. ,
On line wire diagnosis using Multicarrier Time Domain Reflectometry for fault location, 2009 IEEE Sensors, pp.751-754, 2009. ,
DOI : 10.1109/ICSENS.2009.5398542
On the Quasi-TEM Modes in Inhomogeneous Multiconductor Transmission Lines, IEEE Transactions on Microwave Theory and Techniques, vol.29, issue.8, pp.812-817, 1981. ,
DOI : 10.1109/TMTT.1981.1130452
Noise-Domain Reflectometry for Locating Wiring Faults, IEEE Transactions on Electromagnetic Compatibility, vol.47, issue.1, pp.97-104, 2005. ,
DOI : 10.1109/TEMC.2004.842109
Inverse Scattering Experiments for Electric Cable Soft Fault Diagnosis and Connector Location, PIERS Online, pp.1932-1936, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00776082
Experimental Validation of the Inverse Scattering Method for Distributed Characteristic Impedance Estimation, IEEE Transactions on Antennas and Propagation, vol.63, issue.6, pp.632532-2538, 2015. ,
DOI : 10.1109/TAP.2015.2417215
URL : https://hal.archives-ouvertes.fr/hal-01231807
A time-domain optimization technique for the simultaneous reconstruction of the characteristic impedance, resistance and conductance of a transmission line, Journal of Electromagnetic Waves and Applications, vol.10, issue.4, pp.581-601, 1996. ,
Comparison between Frequency Domain and Time Domain Methods for Parameter Reconstruction on Nonuniform Dispersive Transmission Lines, Progress In Electromagnetics Research, vol.43, pp.1-37, 2003. ,
DOI : 10.2528/PIER03020301
Propagation Modes, Equivalent Circuits, and Characteristic Terminations for Multiconductor Transmission Lines with Inhomogeneous Dielectrics, IEEE Transactions on Microwave Theory and Techniques, vol.21, issue.7, pp.450-457, 1973. ,
DOI : 10.1109/TMTT.1973.1128032
The discrete-time quadrature subsample estimation of delay, IEEE Transactions on Instrumentation and Measurement, vol.51, issue.1, pp.133-137, 2002. ,
DOI : 10.1109/19.989916
The Finite-Difference Time-Domain ( FDTD ) Algorithm ,
, Review of Federal Programs for Wire System Safety, National Science and Technology Council National Science and Technology Council, 2000.
Numerical optimization, 2006. ,
DOI : 10.1007/b98874
An optimization approach to the frequency-domain inverse problem for a nonuniform LCRG transmission line, IEEE Transactions on Microwave Theory and Techniques, vol.44, issue.8, pp.441503-1507, 1996. ,
DOI : 10.1109/22.536038
Electromagnetic Waves and Antennas, Orfanidis, 2008. ,
Analysis of multiconductor transmission lines, 2008. ,
DOI : 10.1109/9780470547212
Développement d'un nouvelle méthode de détermination des profils de teneur en eau dans les sols par inversion d'un signal TDR, 1997. ,
Eigenmodes of the time reversal operator: A solution to selective focusing in multiple-target media, Wave Motion, vol.20, issue.2, pp.20151-163, 1994. ,
DOI : 10.1016/0165-2125(94)90039-6
Assessment of the Influence of Losses on the Performance of the Electromagnetic Time Reversal Fault Location Method, IEEE Transactions on Power Delivery, issue.i, pp.89771-89772, 2016. ,
VNA calibration, IEEE Microwave Magazine, vol.9, issue.3, pp.86-99, 2008. ,
DOI : 10.1109/MMM.2008.919925
On addressing the practical issues in the extraction of RLGC parameters for lossy multiconductor transmission lines using S-parameter models, 2008 IEEE-EPEP Electrical Performance of Electronic Packaging, pp.259-262, 2008. ,
DOI : 10.1109/EPEP.2008.4675929
A fast TDR-inversion technique for the reconstruction of spatial soil moisture content, Hydrology and Earth System Sciences, vol.9, issue.5, pp.481-492, 2005. ,
DOI : 10.5194/hess-9-481-2005
URL : https://hal.archives-ouvertes.fr/hal-00298659
Multiple emitter location and signal parameter estimation, IEEE Transactions on Antennas and Propagation, vol.34, issue.3, pp.276-280, 1986. ,
DOI : 10.1109/TAP.1986.1143830
Wiring Diagnostics Via $\ell_1$-Regularized Least Squares, IEEE Sensors Journal, vol.10, issue.7, pp.1218-1225, 2010. ,
DOI : 10.1109/JSEN.2009.2037823
A Model-Based Probabilistic Inversion Framework for Characterizing Wire Fault Detection Using TDR, IEEE Transactions on Instrumentation and Measurement, vol.60, issue.5, pp.1654-1663, 2011. ,
DOI : 10.1109/TIM.2011.2105030
On the validity of bisection-based thru-only de-embedding, 2010 International Conference on Microelectronic Test Structures (ICMTS), pp.66-71, 2010. ,
DOI : 10.1109/ICMTS.2010.5466857
Remaining Useful Life Estimation of Electric Cables in Nuclear Power Plants, Chemical Engineering Transactions, vol.33, pp.877-882, 2013. ,
Développement d'une méthodologie dédiée à la réflectométrie en vue du diagnostic filaire, 2010. ,
Detection of Defects in Wiring Networks Using Time Domain Reflectometry, IEEE Transactions on Magnetics, vol.46, issue.8, pp.462998-3001, 2010. ,
DOI : 10.1109/TMAG.2010.2043720
URL : https://hal.archives-ouvertes.fr/hal-00447317
Analysis of spread spectrum time domain reflectometry for wire fault location, IEEE Sensors Journal, vol.5, issue.6, pp.1469-1478, 2005. ,
DOI : 10.1109/JSEN.2005.858964
Fault Location on Aircraft Wiring Using Spread Spectrum Time Domain Reflectometry, 2005. ,
A de-embedding technique for interconnects, Topical Meeting on Electrical Performance of Electronic Packaging, pp.129-132, 2001. ,
Optimal State Estimation, Optimal Control and Estimation, pp.299-419, 1994. ,
, , 2005.
AN EFFICIENT INVERSE SCATTERING ALGORITHM AND ITS APPLICATION TO LOSSY ELECTRIC TRANSMISSION LINE SYNTHESIS, Progress In Electromagnetics Research Letters, vol.24, pp.77-90, 2011. ,
DOI : 10.2528/PIERL11010706
URL : https://hal.archives-ouvertes.fr/hal-00777380
An Inverse Scattering Approach to Soft Fault Diagnosis in Lossy Electric Transmission Lines, IEEE Transactions on Antennas and Propagation, vol.59, issue.10, pp.593730-3737, 2011. ,
DOI : 10.1109/TAP.2011.2163772
URL : https://hal.archives-ouvertes.fr/hal-00777454
Inverse Problem Theory and Methods for Model Parameter Estimation, 2004. ,
DOI : 10.1137/1.9780898717921
, The MathWorks, 2017.
Estimation non destructive d ' un profil de teneur en eau dans un ouvrage en béton par réfléctométrie fréquentielle Circuit de validation Pré-diffusion, 2015. ,
Health Monitoring of Power Cable via Joint Time-Frequency Domain Reflectometry, IEEE Transactions on Instrumentation and Measurement, vol.60, issue.3, pp.1047-1053, 2011. ,
DOI : 10.1109/TIM.2010.2058730
Multiconductor Transmission-line Theory in the TEM Approximation, IBM Journal of Research and Development, vol.16, issue.6, pp.604-611, 1972. ,
DOI : 10.1147/rd.166.0604
Numerical Solution of Initial Boundary Value Problems Involving Maxwell's Equations in Isotropic Media, Antennas and Propagation, vol.14, issue.3, pp.302-307, 1966. ,
($f$) Models for Transmission Lines From Measured $S$ -Parameters, IEEE Transactions on Electromagnetic Compatibility, vol.52, issue.1, pp.189-198, 2010. ,
DOI : 10.1109/TEMC.2009.2035055
Statistical detection and isolation of additive faults in linear time-varying systems, Automatica, vol.50, issue.10, pp.502527-2538, 2014. ,
DOI : 10.1016/j.automatica.2014.09.004
URL : https://hal.archives-ouvertes.fr/hal-01081899
Inverse Scattering for Soft Fault Diagnosis in Electric Transmission Lines, IEEE Transactions on Antennas and Propagation, vol.59, issue.1, pp.141-148, 2011. ,
DOI : 10.1109/TAP.2010.2090462
URL : https://hal.archives-ouvertes.fr/inria-00365991
Diagnosis of inhomogeneous insulation degradation in electric cables by distributed shunt conductance estimation, Control Engineering Practice, vol.21, issue.9, pp.1195-1203, 2013. ,
DOI : 10.1016/j.conengprac.2013.04.006
URL : https://hal.archives-ouvertes.fr/hal-00776924
, Table des figures 1
Différents types de câbles et leurs domaine d'application (Source : nexans.fr) ,
, , p.11
, , p.13
Quelques Exemple de défauts visibles dans l'aéronautique (National Business Aviation Association -USA), p.14 ,
Définition de la tangente delta : tan(?), p.16 ,
, , p.17
Simulation d'un réflectogramme (TDR) pour un câble affecté d'un défaut d'impédance ,
, Simulation d'un réflectogramme (TDR) avec des réflexions multiples 20
, , p.30
Modèle RLCG(z) pour une ligne non-uniforme, p.30 ,
, , p.31
, , p.31
, Discrétisation du domaine de calcul pour la méthode FDTD (Source : [Smail, p.37, 2010.
Graphe supérieur : profil de la capacité C(z) d'un câble. Graphe inférieur : simulation du réflectogramme pour ce câble, p.38 ,
Simulation dans le domaine temporel (méthode FDTD) -Tension et réflectogramme au cours du temps dans un câble de 5 m possédant une discontinuité du paramètre C, p.40 ,
Algorithme de simulation de la propagation des ondes et du réflectogramme dans le domaine temporel, p.41 ,
z) dans le domaine fréquentiel (f = 200M Hz) Graphe inférieur : Module (bleu) et phase (rouge) de la tensionûtension?tensionû(z, ?) Graphe supérieur : profil de l'impédance caractéritique, p.43 ,
, Table des figures
, Coefficient de réflexion ?(z, ?) simulé pour 0 Hz ? f ? 200 MHz sur un câble de 20 m affecté par un défaut entre 5 m et 6 m (capacité linéique cinq fois plus grande que la capacité nominale), p.44
Algorithme de simulation de la propagation des ondes et du coefficient de réflexion dans le domaine fréquentiel, p.45 ,
diagnostic de câbles par résolution d'un problème inverse, p.51 ,
, , p.59
signal injecté (succession de deux impulsions), p.74 ,
, , p.74
, , p.75
, R(x)) sur l'impédance apparente (Z(z)), Effet des pertes, p.81
, Méthode d'estimation du profil de résistance linéique R(z), p.82
Expérience 1 : câble RG214 de 40 m affecté d'un défaut résistif localisé de 49, p.84 ,
, , p.84
Expérience 2 : câble RG214 de 25 m affecté d'un défaut résistif localisé de 18, p.85 ,
, , p.86
, Résultat pour l'estimation d'un défaut résistif réparti, p.86
Profil de résistance linéique simulé pour l'estimation des paramètres S avec trois mesures, p.93 ,
, Estimation de S 22 et S 12 S 21 à partir de mesures à un port, p.93
, Représentation d'un quadripôle et notation des tensions et courants 96
, Estimation du profil R(z) sans réadaptation ni usage du zero-padding101
, Estimation du profil R(z) sans réadaptation et avec zero-padding 101
Estimation du profil R(z) avec réadaptation et sans usage du zeropadding, p.102 ,
, Estimation du profil R(z) avec réadaptation et usage du zero-padding103
Effet de la procédure de réadaptation sur l'estimation du profil de résistance linéique R(z) ,
, , p.104
, , p.105
, , p.106
, , p.107
Optimisation du paramètre S 11 (? = 0), p.113 ,
