Etude structure-fonction de l'hydrogénase à fer et ingénierie du métabolisme de l'hydrogène chez Clostridium acetobutylicum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Structure-function study of the FeFe-hydrogenase and hydrogen mtebolic engineering in clostridium acetobutylicum
The hydrogenase of Clostridium acetobutylicum catalyses the oxydation of reduced ferredoxin, leading to reduction of protons and dihydrogen formation. Among the three different classes of hydrogenases, the [Fe-Fe] Hydrogenases harbor a very conserved domain (H-Domain) containing the inorganic catalytic site (Cluster H). CaHydA from C. acetobutylicum possesses, in addition, the F-Domain containing four accessory iron-sulfur clusters. The involvement of accessory iron-sulfur cluster of F-Domain on the catalytic capacities of the enzyme has never been assessed. Moreover, which of the two surface iron-sulfur cluster of the F-Domain who interacts with the physiological redox partner ferredoxin is unknown. Different CaHydA mutants enzymes, modified in the Fe-S cluster composition of the F-Domain have been purified, and spectroscopically, biochemically and electrochemically characterized. These mutants enzymes, impaired in their catalytic activity both in solution and wired to an electrode, suggested, for the first time that the Fe-S clusters of the F-Domain have a long-range thermodynamic effect on the H-cluster and modulate enzyme’s functions. Moreover, it has been shown, and confirmed by molecular modelling, that the [2Fe-2S] surface cluster FS2 of the enzyme is the entry point for the electrons coming from the reduced ferredoxin.
: Chez la bactérie Clostridium acetobutylicum, la production de dihydrogène est catalysée par des hydrogénases, enzymes impliquées dans l’oxydation de la ferrédoxine réduite, qui permet la réduction des protons et la formation du gaz. Toutes les hydrogénases à fer partagent un domaine protéique très conservé (le Domaine H), hébergeant le site catalytique inorganique (le Cluster H). L’enzyme CaHydA de C. acetobutylicum, possède également le Domaine F contenant en tous quatre centres fer-soufre dits accessoires. Au cours de ces travaux, l’implication des centres fer-soufre du Domaine F sur les capacités catalytiques de l’enzyme a été étudiée, ainsi que les mécanismes de transfert d’électrons entre l’enzyme et son partenaire physiologique d’oxydoréduction principal : la ferrédoxine 2[4Fe-4S]. Différents variants ciblés de l’hydrogénase ont été créés, produits puis purifiés afin de les caractériser par une combinaison de méthodes biochimiques, électrochimiques, spectroscopiques et de modélisation moléculaire. Ceci a permis de mettre en évidence pour la première fois l’implication des centres fer-soufre accessoires du Domaine F dans les capacités catalytiques de l’enzyme. Enfin, il a été démontré que le centre [2Fe-2S] de surface FS2 de l’enzyme était le point d’entrée des électrons provenant de la ferrédoxine réduite.
2017GauquelinCharles.pdf (9.35 Mo) Télécharger le fichier
tel-01713620 , version 1 (20-02-2018)
  • HAL Id : tel-01713620 , version 1
Charles Gauquelin. Etude structure-fonction de l'hydrogénase à fer et ingénierie du métabolisme de l'hydrogène chez Clostridium acetobutylicum. Biochimie [q-bio.BM]. INSA de Toulouse, 2017. Français. ⟨NNT : 2017ISAT0018⟩. ⟨tel-01713620⟩
392 Consultations
517 Téléchargements
