Contribution à la mise au point d'un pilotage énergétique décentralisé par prédiction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Decentralized energy management by predictions
This work presents a data-intensive solution to manage energy flux after a low transformer voltage named microgrid concept. A microgrid is an aggregation of building with a decentralized energy production and or not a storage system. These microgrid can be aggregate to create an intelligent virtual power plant. However, many problems must be resolved to increase the part of these microgrid and the renewable resource in a energy mix. The physic model can not integrate and resolve in a short time the quickly variations. The intelligent district can be integrate a part of flexibility in their production with a storage system. This storage can be electrical with a battery or thermal with the heating and the hot water. For a virtual power plant, the system can be autonomous when the price electricity prediction is low and increase the production provided on the market when the price electricity is high. For a energy supplier and with a decentralized production building distant of a low transformer voltage, a regulation with a storage capacity enable a tension regulation. Finally, the auto-consumption becomes more and more interesting combined with a low electrical storage price and the result of the COP 21 in Paris engage the different country towards the energy transition. In these cases, a flexibility is crucial at the building level but this flexibility is possible if, and only if, the locally prediction are correct to manage the energy. The main novelties of our approach is to provide an easy implemented and flexible solution to predict the consumption and the production at the building level based on the machine learning technique and tested on the real use cases in a residential and tertiary sector. A new evaluation of the consumption is realized: the point of view is energy and not only electrical. The energy consumption is decomposed between the heating consumption, the hot water consumption and the electrical devices consumption. A prediction every hour is provided for the heating and the hot water consumption to estimate the thermal storage capacity. A characterization of Electrical devices consumption is realized by a non-intrusive disaggregation from the global load curve. The heating and the hot water are identify to provide a non intrusive methodology of prediction. Every day, the heating, the hot water, the household appliances, the cooling and the stand by are identified. Every 15 minutes, our software provide a hot water prediction, a heating prediction, a decentralized prediction and a characterization of the electrical consumption. A comparison with the different physic model simulated enable an error evaluation the error of our different implemented model.
Comment satisfaire les besoins en énergie d’une population de 9 milliards d’êtres humains en 2050, de façon économiquement viable tout en minimisant l’impact sur l’environnement. Une des réponses est l’insertion de production d’énergie propre d’origine éolienne et photovoltaïque mais leurs totales dépendances aux variations climatiques accentuent une pression sur le réseau. Les modèles prédictifs historiques centralisés et paramétriques ont du mal à appréhender les variations brutales de productions et de consommations. La révolution internet permet aujourd’hui une convergence entre le numérique et l’énergie. En Europe et depuis cinq ans, l’axe d’étude est celui de la maîtrise locale de l’électricité. Ainsi plusieurs quartiers intelligents ont été créés et les modèles utilisés de pilotage et de prédiction restent souvent la propriété des partenaires des projets. Dans cette thèse, Il s’agit de réaliser un bilan énergétique chaque heure pour prédire l’ensemble des vecteurs énergétiques d’un système. Le besoin en énergie d’un système comme une maison est décomposée en un besoin en chauffage, en un besoin en eau chaude sanitaire, en un besoin en luminaires, en besoin de ventilation et en usages spécifiques électriques utiles. Le système peut posséder une production décentralisée et un système de stockage ce qui augmentera sa capacité d’effacement. Pour le centre de pilotage, l’objectif est d’avoir une possibilité de scénarios de surproductions ou surconsommations sur un quartier donnée à court terme. Nous considérerons dans cette thèse un horizon à l’heure pour notre bilan énergétique. Cela implique une prédiction fine des différents flux énergétiques d’un système en particulier le chauffage et l’eau chaude qui représente le plus gros potentiel de flexibilité dans les bâtiments. Pour réaliser un bilan, nous devons calculer les différents flux énergétiques à l’intérieur de notre système : les déperditions par l’enveloppe et la ventilation, les gains internes solaires, des personnes et des appareils, le stockage, la production d’eau chaude sanitaire, les usages spécifiques électriques utiles. Sur certains de ces points, nous pouvons évaluer assez précisément et en fonction du temps les quantités d’énergie échangées. Pour les autres (ECS, USE, gains internes, stockage), la bibliographie nous donne que des méthodes globales et indépendantes du temps. Il n’est donc pas possible d’envisager une méthode correspondant au pas de temps souhaité. Ceci impose la mise au point d’une méthode prédictive et apprenante dont nos modèles de simulation énergétique seront le point de référence. Il n’en reste pas moins que ces modèles permettent la compréhension du comportement énergétique du système. L’outil se devra non intrusif, personnalisé, robuste et simple. Pour limiter le caractère intrusif de l’outil, il s’agit à la fois d’ajouter de l’intelligence comme par exemple l’identification des appareils utiles à partir d’un seul point de mesure mais aussi la collection et l’analyse d’informations localement. Les données privées ne sont pas transmises vers l’extérieur. Seules les informations de prédictions énergétiques sont envoyées à un niveau supérieur pour agrégation des données des quartiers. L’intelligence est également au niveau des prédictions réalisées issues de méthodes d’apprentissage comme l’utilisation des réseaux de neurones ou des arbres de décision. La robustesse est étudiée d’un point de vue technologie (plusieurs protocoles de communication ont été testés), techniques (plusieurs méthodes de collecte) et d’un point de vue du stockage de données (limiter la fréquence de collecte). La simplicité d’usage engendre une simplicité d’installation minimiser le nombre de données d’entrée tout en gardant une précision souhaitable sera notre principal axe d’optimisation.
DufourLucDiff.pdf (5.3 Mo) Télécharger le fichier
tel-01716841 , version 1 (24-02-2018)
  • HAL Id : tel-01716841 , version 1
Luc Dufour. Contribution à la mise au point d'un pilotage énergétique décentralisé par prédiction. Génie civil. Ecole des Mines d'Albi-Carmaux, 2017. Français. ⟨NNT : 2017EMAC0004⟩. ⟨tel-01716841⟩
604 Consultations
446 Téléchargements
