Prevalence and risk factors for toxoplasmosis in pigs and characterization of natural evolution of infection in a pig model
Prévalence et les facteurs du risque pour la toxoplasmose chez les porcs et caractérisation d'évolution d'infection naturelle en modèle des porcs
The parasite from the phylum Apicomplexa, Toxoplasma gondii is adapted for infection of all warm-blooded animals including humans. Postnatal infection occurs through ingestion of i) tissue cysts present in muscles of infected animals, or ii) environmentally resistant forms - oocysts via contaminated water, fruits and vegetables. Disease is generally benign, but infection may have serious consequences for the developing foetus in the case of maternal infection in pregnancy and in immunosuppressed individuals. Along with sheep and poultry, T. gondii parasites are mostly isolated from pig meat. In intensive systems with various levels of confinement, intensity of T. gondii infection is still considerably lower than in outdoor or organic farms throughout Europe. Poor rodent control and presence of cats on intensive farms are major sources of T. gondii infection for pig. When straw is used for bedding, it can contain oocysts or even rodent carcasses, and if the food silos or distributers are opened, pig nutrition can be contaminated. In contrast to intensive farming, in outdoor and organic farms, pigs are exposed to environmental T. gondii contamination through soil, food, and water sources. So far, routine surveillance of pigs for T. gondii infection has not been established anywhere in the World, neither in the slaughterhouse nor on the farm-levels. Thus the sources of pig infection on the farms are still unknown. Moreover, it is unknown how big the role of the meat from T. gondii infected pigs is in human nutrition...
Dans le phylum des Apicomplexa le parasite Toxoplasma gondii est adapté à l'infection de tous les animaux à sang chaud y compris l'homme. L'infection se produit après la naissance par l'ingestion de kystes i) présents dans les muscles des animaux infectés, ou ii) des formes résistantes de l'environnement – les oocystes contaminants l'eau, les fruits et légumes, les coquillages. La maladie est généralement bénigne, mais l'infection peut avoir des conséquences graves pour le développement du fœtus dans le cas de l'infection maternelle pendant la grossesse et chez les individus immunodéprimés.Hormis les muscles et organes de moutons et de volaille, le parasite T. gondii est principalement isolé de la viande de porc. Dans les systèmes intensifs avec différents niveaux de confinement, l'intensité de l'infection par T. gondii est toujours considérablement plus basse que dans les élevages en plein air ou biologique pour toute l'Europe. L’absence de lutte contre les rongeurs et la présence de chats dans les exploitations intensives est les principales sources de l'infection par T. gondii chez le porc. Lorsque la paille est utilisée comme litière, elle peut contenir des oocystes ou carcasses de rongeurs, et si les silos ou les distributeurs d’alimentation sont ouverts, l'alimentation du porc peut être contaminée. Contrairement à l'agriculture intensive, dans les exploitations en plein air ou ayant le statut de « porc biologique » les animaux sont exposés à une contamination environnementale par T. gondii (pâture, nourriture et eau). Jusqu'à présent, la surveillance systématique des porcs vis à vis de l'infection par T. gondii n'a été établie dans aucun pays et il n’existe pas de contrôle à l'abattoir ou à la ferme (même si une visite sanitaire a été instaurée en 2015 en France). Aussi, les sources d'infection dans les élevages restent méconnues et le rôle de la viande de porc dans la contamination humaine est à définir....
