Role of the chemokine receptor CCR2 in the dynamic of regulatory T cells and monocytes/macrophages in response to antitumor therapies
Rôle du récepteur de chimiokines CCR2 dans la dynamique des lymphocytes T régulateurs et monocytes/macrophages en réponse aux thérapies antitumorales
Malignant and stromal cells are strong producer of the chemokine CCL2 in most human cancers. The chemokine axis CCR2/CCL2 is thus a key marker of cancer development, but is also associated with relapse following therapy. Tumour associated macrophages (TAM) and regulatory T cells (Treg) display robust immunosuppressive capacities and contribute to tumour growth. My thesis work focused on the function of the expression of the chemokine receptor CCR2 by these cell types in the context of anticancer therapies. We have shown that CCR2 controls the migration of Treg in tumoral context, in both human and mice, and that the expression of this receptor by Treg could serve as a biomarker of the response to chemotherapy. Our study indicate a novel function of CCR2, defining at the same time a new Treg subset implicated in the regulation of antitumor immunity.We have also demonstrated that pulmonary metastases are composed of both tissue resident and recruited macrophages. The presence of resident macrophages within tumours could contribute to the heterogeneity of the microenvironment of different tumour types. CCR2 is largely implicated in the relapse phase following chemotherapy, indicating a limited role for resident macrophages in this phenomenon. Meanwhile, we have demonstrated that VEGF plays a direct role in TAM survival. The combination of chemotherapy with an anti-VEGF antibody targets both resident and recruited TAM, thereby enhancing the efficacy of chemotherapy. Finally, we have shown that the CCR2/CCL2 axis is implicated in the response to radiotherapy by enhancing the recruitment of both Treg and TAM. This work provides evidences for a central role of the CCR2/CCL2 axis in mediating Treg and TAM co-localization in response to anticancer therapy, this axis could also contribute to establishment of immunosuppressive networks in tumours. Our results provide a better understanding of the immune mechanism implicated in resistance to anticancer therapies.
Une forte production de la chimiokine CCL2 par les cellules malignes et les cellules stromales a été démontrée dans la plupart des cancers humains. Ainsi, l’axe chimiokinique CCR2/CCL2 est un important marqueur du développement des cancers ; ce même axe est associé à la récurrence de tumeurs après thérapie anticancéreuses. Les macrophages associés aux tumeurs (TAM) et les lymphocytes T régulateurs (Treg) ont des capacités immunosuppressives robustes et contribue à la croissance tumorale. Durant cette thèse, je me suis intéressé à la fonction de l’expression du récepteur de chimiokine CCR2 par ces cellules dans le contexte de thérapies anticancéreuses. Nous avons montré que le récepteur de chimiokines CCR2 contrôle la migration des Treg en contexte tumoral, chez l’homme et la souris, et que son expression par les Treg peut servir de biomarqueur de la réponse à la chimiothérapie. Notre étude indique une nouvelle fonction de CCR2 et définie un nouveau sous-type de Treg impliqué dans la régulation de l’immunité antitumorale. En parallèle, nous avons pu mettre en évidence que les métastases pulmonaire sont composées à la fois de macrophages résident du tissu et de macrophages recrutés via l’axe CCR2. La présence de macrophages résidents au sein des tumeurs pourrait contribuer à l’hétérogénéité des microenvironnements de diffèrent type de tumeurs. Le récepteur CCR2 est important pour le la phase de rechute après chimiothérapie, indiquant un rôle limité des macrophages résidents dans ce phénomène. De plus, nous avons montré que le VEGF joue un rôle direct dans la survie des TAM. Ainsi, la combinaison de la chimiothérapie avec un anticorps anti-VEGF cible simultanément les TAM résidents et recrutés et permet d’augmenter l’efficacité de la chimiothérapie.
