Développement de l’imagerie métabolique par IRM-CEST : application à la maladie de Huntington - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Development of metabolic imaging using CEST-MRI : application to Huntington’s disease
Huntington's disease (HD) is a inherited neurodegenerative disease affecting the brain. This disease is characterized by clinical symptoms such as psychiatric, cognitive and motor disorders worsening over time. These deficiencies are due to an abnormal increase in the size of the CAG repeats in the gene encoding the huntingtin protein. Thisaccumulates in the brain cells and causes their death. Previous studies have shown that the metabolic profile measured in ¹H NMR spectroscopy can be altered in patients with this disease as well as major atrophy of certain structures of the brain. Hypotheses involving defects in energy metabolism have been advanced to explain partially the pathophysiology of the disease. The metabolic actors could thus be biomarkers of interest. Using a promising MRI modality called Chemical Exchange Saturation Transfer (CEST), it is possible to detect low-concentrated labile protons that are classically undetectable in MRI. It thus becomes possible to map in vivo the distribution of metabolites such as glutamate (which is a neurotransmitter) or glucose (which is the fuel of cells) which are potentially involved in neurodegenerative diseases. The methodological developments carried out during this thesis were then applied to rodent models of Huntington's disease (KI140 mice, R6/1 mice, BACHD rats) in order to identify potential biomarkers of the pathology and to evaluate the relevance of these innovative MRI methods. All of these results and methods implemented during this thesis show the potential of CEST imaging for the study of neurodegenerative diseases.
La maladie de Huntington (MH) est une maladie neurodégénérative héréditaire qui affecte le cerveau. Cette maladie est caractérisée par des signes cliniques tels que la dépression, la démence ainsi que des troubles moteurs s’aggravant au fil du temps. Ces déficiences sont dues à une augmentation anormale de la taille des répétitions CAG dans le gène codant la protéine huntingtine. Celle-ci s’accumule dans les cellules cérébrales et entraine leur mort. Des études antérieures ont démontré que le profil métabolique mesuré en spectroscopie RMN ¹H pouvait être altéré chez les patients atteints de cette maladie ainsi que des atrophies majeures de certaines structures du cerveau. Des hypothèses impliquant des défauts du métabolisme énergétique ont été avancées pour expliquer en partie la physiopathologie de la maladie. Les acteurs du métabolisme pourraient ainsi constituer des biomarqueurs d’intérêt. A l'aide d'une modalité d'IRM prometteuse appelée CEST (Chemical Exchange Saturation Transfer : Transfert de Saturation par Echange Chimique) il est possible de détecter des protons labiles faiblement concentrés qui sont classiquement indétectables en IRM. Il devient ainsi possible de cartographier in vivo la distribution de métabolites comme le glutamate (qui est un neurotransmetteur) ou le glucose (qui est le carburant des cellules) qui sont potentiellement impliqués dans les maladies neurodégénératives. Les développements méthodologiques effectués lors de cette thèse ont ensuite été appliqués à des modèles de rongeurs de la maladie de Huntington (souris KI140, souris R6/1, rats BACHD) afin d'identifier les biomarqueurs potentiels de la pathologie et d'évaluer la pertinence de ces méthodes IRM innovantes. L’ensemble de ces résultats et des méthodes mises en place durant cette thèse montrent le potentiel de l’imagerie CEST pour l’étude des maladies neurodégénératives.
74413_PEPIN_2018_archivage.pdf (9.45 Mo) Télécharger le fichier
tel-01740330 , version 1 (21-03-2018)
  • HAL Id : tel-01740330 , version 1
Jérémy Pépin. Développement de l’imagerie métabolique par IRM-CEST : application à la maladie de Huntington. Traitement du signal et de l'image [eess.SP]. Université Paris Saclay (COmUE), 2018. Français. ⟨NNT : 2018SACLS032⟩. ⟨tel-01740330⟩
587 Consultations
1490 Téléchargements
