LUTHRA : Draft ITU-T Recommendation and Final Draft International Standard of Joint Video Specification, Rapport technique JVT- G050r1, Joint Video Team (JVT), 8th meeting, 2013. ,
Terms of reference of the joint collaborative team on video coding standard development. Rapport technique, 39th meeting, 2007. ,
Description of video coding technology proposal by NTT, Panasonic and Technicolor. Rapport technique JCTVC-A114, JCT-VC, 1st meeting, 2007. ,
RAMZAN : HEVC verification test results, 2007. ,
DOI : 10.1049/ib.2014.0029
High Efficiency Video Coding (HEVC) Test Model 11 (HM11) Encoder Description, p.26, 2013. ,
DISCRETE COSINE TRANSFORM, p.19, 1990. ,
DOI : 10.1016/B978-0-08-092534-9.50007-2
CE10 : Core transform design for HEVC. Rapport technique JCTVC-G495, JCT-VC, 7th meeting, 2011. ,
Rate-distortion optimized quantization in HEVC: Performance limitations, 2015 Picture Coding Symposium (PCS), 1920. ,
DOI : 10.1109/PCS.2015.7170052
Rate-distortion methods for image and video compression, IEEE Signal Processing Magazine, vol.15, issue.6, p.22, 1998. ,
DOI : 10.1109/79.733495
Rate-distortion optimization for video compression, IEEE Signal Processing Magazine, vol.15, issue.6, p.22, 1998. ,
DOI : 10.1109/79.733497
URL : http://standard.pictel.com/ftp/q15-site/9807_Whi/q15e26.ps
Encoder improvement of unified intra prediction, p.38, 2010. ,
Fast mode decision algorithm for intra prediction in HEVC, 2011 Visual Communications and Image Processing (VCIP), p.24, 2011. ,
DOI : 10.1109/VCIP.2011.6115979
UHD-1 test sequences ,
The SVT High Definition Multi Format Test Set, p.28, 2006. ,
XIA : The SJTU 4k video sequence dataset, QoMEX, p.28, 2013. ,
Calculation of average PSNR differences between RD-curves, Proc. ITU-T SG16/Q.6 VCEG 13th Meeting, p.29, 2001. ,
Fast CU size decision and mode decision algorithm for HEVC intra coding, IEEE Transactions on Consumer Electronics, vol.59, issue.1, p.37, 2013. ,
DOI : 10.1109/TCE.2013.6490261
Fast Coding Unit size decision algorithm for intra coding in HEVC, International Conference on Consumer Electronics (ICCE), janvier 2013, p.37 ,
Fast coding unit size selection for HEVC based on Bayesian decision rule, Picture Coding Symposium (PCS), p.37, 2012. ,
Content adaptive prediction unit size decision algorithm for HEVC intra coding, Picture Coding Symposium (PCS), p.37, 2012. ,
Entropy-Based Fast Largest Coding Unit Partition Algorithm in High-Efficiency Video Coding, Entropy, vol.1, issue.12, p.104, 2013. ,
DOI : 10.1109/TCSVT.2013.2249017
IKENAGA : Fast mode and depth decision HEVC intra prediction based on edge detection and partitioning reconfiguration, International Symposium on Intelligent Signal Processing and Communications Systems (ISPACS), novembre 2013, p.109 ,
DOI : 10.1109/ispacs.2013.6704518
Fast bottom-up pruning for HEVC intraframe coding, 2013 Visual Communications and Image Processing (VCIP), p.38 ,
DOI : 10.1109/VCIP.2013.6706389
An adaptive complexity reduction scheme with fast prediction unit decision for HEVC intra encoding, 2013 IEEE International Conference on Image Processing, p.38, 2013. ,
DOI : 10.1109/ICIP.2013.6738325
A Fast Intra-Prediction Method in HEVC Using Rate-Distortion Estimation Based on Hadamard Transform, ETRI Journal, vol.35, issue.2, p.39, 2013. ,
DOI : 10.4218/etrij.09.0209.0153
Fast mode decision algorithm for intraprediction in H, AVC video coding. IEEE Transactions on Circuits and Systems for Video Technology, p.39, 2005. ,
Gradient based fast mode decision algorithm for intra prediction in HEVC, 2012 2nd International Conference on Consumer Electronics, Communications and Networks (CECNet), p.39, 2012. ,
DOI : 10.1109/CECNet.2012.6201851
Fast intra mode decision for HEVC based on direction energy distribution, 2013 IEEE International Symposium on Consumer Electronics (ISCE), p.39, 2013. ,
DOI : 10.1109/ISCE.2013.6570252
Group-Based Fast Mode Decision Algorithm for Intra Prediction in HEVC, International Conference on Signal Image Technology and Internet Based Systems (SITIS), p.39, 2012. ,
Novel Adaptive Algorithm for Intra Prediction with Compromised Modes Skipping and Signaling Processes in HEVC, IEEE Transactions on Circuits and Systems for Video Technology, p.39, 2013. ,
Gradient-based fast decision for intra prediction in HEVC, 2012 Visual Communications and Image Processing, p.40 ,
DOI : 10.1109/VCIP.2012.6410739
JEON : Fast intra mode decision of HEVC based on hierarchical structure, International Conference on Information, Communications and Signal Processing (ICICS), p.40, 2011. ,
SHIMIZU : Residue role assignment based transform partition predetermination on HEVC, International Conference on Image Processing (ICIP), septembre 2013, p.40 ,
DOI : 10.1109/icip.2013.6738416
Early TU decision method for fast video encoding in high efficiency video coding, Electronics Letters, vol.48, issue.12, p.40, 2012. ,
DOI : 10.1049/el.2012.0277
Fast mode decision algorithm for Residual Quadtree coding in HEVC, 2011 Visual Communications and Image Processing (VCIP), p.79 ,
DOI : 10.1109/VCIP.2011.6116062
Fast residual quad-tree coding for the emerging high efficiency video coding standard, Communications, p.41, 2013. ,
Fast mode decision for inter prediction in H.264, International Conference on Image Processing (ICIP), p.42, 2004. ,
Inter-layer intra mode coding for the scalable extension of HEVC, International Symposium on Circuits and Systems (ISCAS), p.42, 2013. ,
IZQUIERDO : An h.264/avc to hevc video transcoder based on mode mapping, International Conference on Image Processing (ICIP), p.43, 2013. ,
HANNUKSELA : Scalable HEVC (SHVC) Test Model 8 (SHM 8) Rapport technique JCTVC-S1007, pp.2014-2057 ,
HEVC Intra coding of ultra HD video with reduced complexity, 2014 IEEE International Conference on Image Processing (ICIP), pp.2014-53 ,
DOI : 10.1109/ICIP.2014.7025837
URL : https://hal.archives-ouvertes.fr/hal-00994476
Weka 3 : Data mining software in java, p.56 ,
Examplar-based inpainting based on local geometry, 2011 18th IEEE International Conference on Image Processing, p.104, 2011. ,
DOI : 10.1109/ICIP.2011.6116441
URL : https://hal.archives-ouvertes.fr/inria-00628074
Fast block partitioning method in HEVC intra coding for UHD video, 2015 IEEE 5th International Conference on Consumer Electronics, Berlin (ICCE-Berlin), p.60, 2015. ,
DOI : 10.1109/ICCE-Berlin.2015.7391205
URL : https://hal.archives-ouvertes.fr/hal-01204835
JEON : Early determination of mode decision for hevc, Picture Coding Symposium (PCS), p.73, 2012. ,
JEON : Early Skip Mode Decision for HEVC Encoder With Emphasis on Coding Quality, IEEE Transactions on Broadcasting, 2015. ,
DOI : 10.1109/tbc.2015.2419172
LEI : Early MERGE Mode Decision Based on Motion Estimation and Hierarchical Depth Correlation for HEVC, IEEE Transactions on Broadcasting, p.73, 2014. ,
CRUZ : A method for early-splitting of HEVC inter blocks based on decision trees, European Signal Processing Conference (EUSIPCO). IEEE, p.74, 2014. ,
HAMALAINEN : Efficient mode decision schemes for HEVC inter prediction, IEEE Transactions on Circuits and Systems for Video Technology, p.74, 2014. ,
DOI : 10.1109/tcsvt.2014.2308453
Coding tree pruning based CU early termination. Rapport technique JCTVC-F092, JCT-VC, 6th meeting, p.74, 2011. ,
Effective CU Size Decision for HEVC Intracoding, IEEE Transactions on Image Processing, vol.23, issue.10, p.74, 2014. ,
DOI : 10.1109/TIP.2014.2341927
SAKAIDA : Content Based Hierarchical Fast Coding Unit Decision Algorithm for HEVC, International Conference on Multimedia and Signal Processing, p.74, 2011. ,
DOI : 10.1109/cmsp.2011.167
Hierarchical Structure-Based Fast Mode Decision for H.265/HEVC, IEEE Transactions on Circuits and Systems for Video Technology, p.75 ,
DOI : 10.1109/TCSVT.2015.2395751
Fast coding unit partitioning algorithm for HEVC, 2014 IEEE International Conference on Consumer Electronics (ICCE), p.75, 2014. ,
DOI : 10.1109/ICCE.2014.6775886
Fast rate distortion optimization for the emerging HEVC standard, 2012 Picture Coding Symposium, p.75, 2012. ,
DOI : 10.1109/PCS.2012.6213262
A Novel Fast CU Encoding Scheme Based on Spatiotemporal Encoding Parameters for HEVC Inter Coding, IEEE Transactions on Circuits and Systems for Video Technology, p.75, 2015. ,
DOI : 10.1109/TCSVT.2014.2360031
Early termination of coding unit splitting for HEVC, Asia-Pacific Signal Information Processing Association Annual Summit and Conference (APSIPA ASC), p.76, 2012. ,
CU splitting early termination based on weighted SVM, EURASIP Journal on Image and Video Processing, vol.2, issue.27, p.76, 2013. ,
DOI : 10.1145/1961189.1961199
QP = 27) produit après filtrage bi-linéaire, p.44 ,
re-décomposées (SPLIT) dans le codeur de référence par rapport au partitionnement HD (extrait de la séquence park_dancers à QP = 32), p.47 ,
Performance de la pré-sélection rapide du mode de prédiction par rapport, p.54 ,
une région de la séquence wind_wool à QP = 27, p.64 ,
Liste des tableaux 1.1 Performance de la pré-sélection rapide des modes, p.25 ,
HEVC Intra coding of ultra HD video with reduced complexity, 2014 IEEE International Conference on Image Processing (ICIP), 2014. ,
Fast block partitioning method in HEVC intra coding for UHD video, 2015 IEEE 5th International Conference on Consumer Electronics, Berlin (ICCE-Berlin), 2015. ,
Déposant : France Brevets. Auteurs : N. Dhollande, X. Ducloux. An apparatus (200) for the encoding of an original video sequence (201), comprising : a conversion module (202) which converts the original video sequence (201) into a dyadic sub-sampled video sequence, Rapport d'étude Livrable ANR 2015 : HEVC encoder optimization Livrable ANR 2016 : Optimisation du Codage HEVC Inter pour Vidéos UHD Brevet d'invention WO2015121112 (A1) ,
