Corrélation composition chimique-structure-propriétés de réductibilité / mobilité de l’oxygène / catalyse d’oxydation au sein d’oxydes à base de cérium, zirconium et de praséodyme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2018
Correlation between chemical composition-structure-properties of reducibility and oxygen mobility with the oxidation of automotive pollutants by (Ce, Zr, Pr) mixed oxides
This work describes characterizations of Ce1-x-yZrxPryO2-z mixed oxides to link their chemical composition-structure with their reducibility/oxygen mobility. These latter properties were correlated with their catalytic activity for the oxidation of CO and propane, both in stoichiometric (gasoline) and lean-burn (Diesel) conditions. The determination of the quantity of rare earth at the +4 oxidation degree, especially for Pr4+, has been of paramount importance. Actually, the higher the Pr4+ rate, the more reducible is the oxide and the better is the oxygen mobility. The evaluation of the diffusion coefficient of the oxygen D* highlighted high values, similar to those of the best reported oxygen ionic conductors at low temperature. Isotopic exchanges showed that the oxygen exchange rate increases with the Pr loading in the oxide. The catalytic activity for propane combustion of these oxides increases with their oxygen mobility. Finally, CZP45 (Ce0,45Zr0,1Pr0,45O2-x) exhibits the best pre-quoted properties as well as the highest catalytic activity. Therefore, CZP45 has been impregnated with Pd. The activity of Pd-CZP45 catalyst was compared with two industrially catalysts containing the same Pd content supported either on ?-Al2O3 (Diesel) or Ce0,5Zr0,5O2-x (gasoline). In Diesel conditions, Pd-CZP45 shows a better low-temperature catalytic activity than Pd-?-Al2O3 for propane oxidation after an initial step of reduction. We have attributed these remarkable performances to the presence of Pd2+/Pd° clusters finely dispersed on the oxide CZP45 and to its ability to adsorb and conduct oxygen
Ces travaux de thèse ont pour vocation d'étudier des oxydes mixtes Ce1-x-yZrxPryO2-z afin de corréler composition chimique-structure avec les propriétés de réductibilité/mobilité ionique de l'oxygène associées aux performances catalytiques pour l'oxydation du CO et du propane, en conditions essence et Diesel. La connaissance de la quantité de terres rares au degré d'oxydation +4 a été déterminante. Notamment, plus le taux de Pr4+ est important, plus le composé est réductible et plus la mobilité de l'oxygène s'accroît. L'évaluation du coefficient de diffusion de l'oxygène D* a montré que sa valeur devenait élevée, rivalisant ainsi avec les meilleurs conducteurs ioniques de l'oxygène à basse température. Les échanges isotopiques de l'oxygène permettent de montrer que la vitesse d'échange croît quand le taux de Pr augmente. L'étude de la combustion du propane sur ces oxydes a montré qu'une bonne mobilité de l'oxygène permettait d'améliorer les performances catalytiques. Ainsi, l'oxyde de composition Ce0,45Zr0,1Pr0,45O2-x (CZP45) présente les meilleures propriétés pré-citées et l'activité catalytique la plus élevée. L'oxyde CZP45 a donc été imprégné de Pd afin d'être comparé à deux catalyseurs utilisés industriellement et à iso-teneur en Pd, dispersée sur ?-Al2O3 (Diesel) et Ce0,5Zr0,5O2-x (essence). En régime Diesel, Pd-CZP45, après une étape initiale de réduction, présente une meilleure activité catalytique à basse température que Pd-?-Al2O3 pour l'oxydation du propane. Nous avons expliqué ces excellentes performances par la présence de clusters de Pd2+/Pd° finement dispersés sur l'oxyde (CZP45) et par la capacité du catalyseur à adsorber et conduire l'oxygène
TH2018FRIZONVINCENT.pdf (18.99 Mo) Télécharger le fichier
tel-01774961 , version 1 (24-04-2018)
  • HAL Id : tel-01774961 , version 1
Vincent Frizon. Corrélation composition chimique-structure-propriétés de réductibilité / mobilité de l’oxygène / catalyse d’oxydation au sein d’oxydes à base de cérium, zirconium et de praséodyme. Catalyse. Université de Lyon, 2018. Français. ⟨NNT : 2018LYSE1030⟩. ⟨tel-01774961⟩
581 Consultations
139 Téléchargements
