Empirical essays on islamic banking : competition, stability and governance
Essais empiriques sur la banque islamique : concurrence, stabilité et gouvernance
This dissertation highlights three important issues in Islamic banks. In the first chapter, we investigate the impact of dual market competition on the differences in deposit rate setting in Islamic and conventional banks. We show that there are notable differences in the determinants of deposit rates in the two types of institution. Market competition has a significant impact on deposit rate of conventional banks but not Islamic banks. Our result, in general, suggests that although Islamic banks’ deposit seems to be similar than conventional banks, their determinants are different. In the second chapter, we continue our investigations by looking at the competition-stability issue. Does competition between Islamic and conventional banks increase banks’ stability or fragility? Our main finding suggests that competitive dual banking market is not beneficial for banks’ stability. In line with the result from the first chapter, in the next investigation, dual market competition only matters for conventional banks. In the third chapter of this dissertation, we analyze the role of Shariah Supervisory Board (SSB) on banks’ equity financing. Our result shows that Islamic banks’ equity financing is influenced by some characteristics of SSB. The presence of SSB member in the Board of Directors (BOD) or executive member has a positive impact on equity financing whereas the existence of a Shariah department in Islamic banks decreases the proportion of equity financing.
Cette thèse met en lumière trois questions importantes au regard des banques Islamiques. Dans le premier chapitre, nous examinons l'impact de la concurrence sur les différences de fixation des taux de dépôt dans les banques Islamiques et conventionnelles. Nous montrons qu'il existe des différences notables dans les déterminants des taux de dépôt dans les deux types d'institutions. La concurrence du marché a un impact significatif sur le taux de dépôt des banques conventionnelles mais pas des banques Islamiques. Notre résultat, en général, suggère que bien que le dépôt des banques Islamiques semble être similaire à celui des banques conventionnelles, leurs déterminants sont différents. Dans le deuxième chapitre, nous poursuivons nos enquêtes en examinant la question de la concurrence et de la stabilité. La concurrence entre banques Islamiques et conventionnelles augmente-t-elle la stabilité ou la fragilité des banques ? Notre principale constatation suggère que le marché concurrentiel des deux banques n'est pas bénéfique pour la stabilité des banques. Conformément au résultat du premier chapitre, lors de la prochaine enquête, la concurrence sur deux marchés ne concerne que les banques conventionnelles. Dans le troisième chapitre de cette dissertation, nous analysons le rôle du Conseil de surveillance de la Charia sur le financement par capitaux propres des banques. Notre résultat montre que le financement par capitaux propres des banques Islamiques est influencé par certaines caractéristiques de la Conseil de surveillance de la Charia. La présence d'un membre de la Conseil de surveillance de la Charia au Conseil d'administration ou d'un membre de l'exécutif a un impact positif sur le financement par actions tandis que l'existence d'un département de la Charia dans les banques Islamiques diminue la proportion de financement par capitaux propres.
2018LIMO0004.pdf (2.61 Mo)
Télécharger le fichier
2018LIMO0004_annexes.pdf (15.61 Ko)
Format : Autre
