Bio-analytical study of plants used in traditional medicine in Togo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Étude bio-analytique de plantes utilisées en médecine traditionnelle au Togo
The investigation of plants used for traditional medicine in Togo is complicated as modern techniques are not available. Computer-aided product identification from traditional usage records (CAPITURE) was evaluated in the context of an ethnobotanical survey on the traditional treatment of fungal diseases in Tchamba District (Togo). This method predicted and identified the most biologically active plants out of the 43 species survey-recorded: Pterocarpus erinaceus predicted to be more active against fungi and Daniellia oliveri against bacteria. The plants were then tested against fungi, bacteria and cancer cells. As predicted with CAPITURE, P. erinaceus was more active against fungi and D. oliveri against bacteria. Interestingly, both plants presented activity on cancer cells without being toxic to normal human cells. In a third step, using analytical chemistry, the compounds responsible for the biological activities were identified. Most of those compounds have never been reported in the plant species or in nature at all, with biological activity in the micromolar range. Finally, pharmaceutical technology was used: by nanosizing the powder of the plant organs, a better biological activity was observed in comparison to that of the organic extract. In conclusion, this research led to the discovery of new molecules with an interesting biological activity that will need further and more detailed investigation
L'étude des plantes utilisées en médecine traditionnelle au Togo est compliquée à cause de l’absence de matériel de pointe. L'identification assistée par ordinateur de produits basés sur des utilisations en médecine traditionnelle (CAPITURE) a été évaluée dans le cadre d'une enquête ethnobotanique sur le traitement traditionnel des maladies fongiques dans la Préfecture de Tchamba (Togo). Cette méthode a prédit et identifié les plantes les plus biologiquement actives parmi les 43 espèces recensées au cours de l’enquête : Pterocarpus erinaceus prédit être plus actif contre les champignons, et Daniellia oliveri contre les bactéries. Les plantes ont ensuite été testées contre les champignons, les bactéries et les cellules cancéreuses. Comme prédit par CAPITURE, P. erinaceus était plus actif contre les champignons et D. oliveri contre les bactéries. Fait intéressant, les deux plantes ont présenté une activité sur les cellules cancéreuses sans être toxique pour les cellules humaines normales. Dans une troisième étape, en utilisant la chimie analytique, les composés responsables des activités biologiques ont été identifiés. La plupart de ces composés n'ont jamais été signalés dans les espèces végétales ou dans la nature, avec une activité biologique dans la gamme micro-molaire. Enfin, en réduisant la poudre des organes végétaux à la taille de nano-particules, une meilleure activité biologique a été observée par rapport à celle de l'extrait organique. En conclusion, cette recherche a mené à la découverte de nouvelles molécules avec une activité biologique intéressante, molécules qui nécessiteront une étude approfondie et détaillée
DDOC_T_2017_0169_TITTIKPINA.pdf (4.91 Mo) Télécharger le fichier
tel-01777427 , version 1 (24-04-2018)
  • HAL Id : tel-01777427 , version 1
Nassifatou Koko Tittikpina. Bio-analytical study of plants used in traditional medicine in Togo. Analytical chemistry. Université de Lorraine; Universität des Saarlandes, 2017. English. ⟨NNT : 2017LORR0169⟩. ⟨tel-01777427⟩
262 Consultations
795 Téléchargements
