Conception et réalisation de détecteurs dédiés à l'analyse de couches minces par spectrométrie Mossbauer : application à l'étude des propriétés magnétiques de films d'oxydes multiferroïques. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Development of detectors dedicated to thin films studies by Mössbauer spectrometry : application to characterization of magnetics properties of multiferroics oxides films
Florian Appert
This work is devoted to the development of two Mössbauer detectors dedicated to thin films studies by conversion electron Mössbauer spectrometry (CEMS), and to their use for the characterization of bismuth ferrite BiFeO3 (BFO) epitaxials thin films. The first designed instrument is composed of a proportional counter and a thermoelectric module. It allows CEMS acquisitions of Mössbauer spectra from 245 to 375K with an external magnetic field upto 1.4 T. The second device is based on a commercial channeltron™ and a continuous flow cryostat allowing measurements downto 4 K. The CEMS measurements have been performed on (110) and (001) oriented BFO layers with various thickness deposited on LaAlO3 et SrTiO3 substrates. Beyond a critical thickness, the (110) BFO exhibits a mixing of collinear and cycloidal magnetic phases. The collinear phase shows an anisotropy axis [001] direction which is located in the sample plane. The cycloid propagation plane have been found to be perpendicular to the sample plane. Both epitaxial strain and size effects have been proposed to explain the cycloid destabilization in the thinner films. In (001) BFO thin films, exhibiting a BFO tetragonal phase, the CEMS measurements have shown that the magnetic ordering temperature tends to decrease with the layer thickness.
Ce travail de thèse porte sur la réalisation de deux instruments adaptés à l’étude de couches minces par spectrométrie Mössbauer du 57Fe par électrons de conversion (CEMS) et à leur utilisation pour la caractérisation de films épitaxiés de ferrite de bismuth BiFeO3 (BFO). Le premier dispositif est constitué d’un compteur proportionnel couplé à un module thermoélectrique. Il permet l’acquisition de manière simple et économique de spectres Mössbauer sur une gamme de température variant de 245 à 375K et sous une induction magnétique externe allant jusqu’à 1,4 T. Un second dispositif a été développé sur la base d’un channeltron™et d’un cryostat à circulation d’hélium pour des acquisitions allant jusqu’à 4 K. Les analyses CEMS ont été réalisées sur des couches minces de différentes épaisseurs de BFO (110) et (001) épitaxiées sur LaAlO3 et SrTiO3. Au-delà d’une épaisseur critique, les couches de BFO (110) présentent un mélange de phases magnétiques colinéaire et cycloïdale. La phase colinéaire présente un axe d’anisotropie suivant [001] dans le plan de la couche et lamodulation cycloïdale se propage dans un plan perpendiculaire à celui-ci. Des effets combinés de contraintes et dimensionnalité ont été avancés pour expliquer la déstabilisation de la cycloïde pour les couches les plus fines. Dans les couches minces de BFO (001) présentant une phase tétragonale de BFO, les mesures CEMS ont montré que la température de mise en ordre magnétique se rapproche de l’ambiante lorsque l’épaisseur des couches diminue.
appertflorian2.pdf (28.85 Mo) Télécharger le fichier
tel-01778403 , version 1 (25-04-2018)
  • HAL Id : tel-01778403 , version 1
Florian Appert. Conception et réalisation de détecteurs dédiés à l'analyse de couches minces par spectrométrie Mossbauer : application à l'étude des propriétés magnétiques de films d'oxydes multiferroïques.. Science des matériaux [cond-mat.mtrl-sci]. Normandie Université, 2017. Français. ⟨NNT : 2017NORMR133⟩. ⟨tel-01778403⟩
247 Consultations
93 Téléchargements
